Thread Number: 43055
KitchenAid Toploader |
Post# 633326   10/21/2012 at 19:49 (4,201 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 633332 , Reply# 1   10/21/2012 at 20:19 (4,201 days old) by whirlykenmore78 (Prior Lake MN (GMT-0500 CDT.))   |   | |
Post# 633345 , Reply# 2   10/21/2012 at 21:01 (4,201 days old) by DirectDriveDave ()   |   | |
Good stuff there! Ahh, all those mechanical dials.... |
Post# 633349 , Reply# 3   10/21/2012 at 21:39 (4,201 days old) by gansky1 (Omaha, The Home of the TV Dinner!)   |   | |
They should pop the lid out before trying to sell it, what are these people thinking? LOL
This (is) a very nice machine, Whirlpool put many step-up features in the KitchenAid laundry that made the Sunday-Ad Kenmo' look like a hillbilly cousin. Probably the finest made of it's time. Galvanized cabinets; porcelain top and lid; bronze bushing motor and dryer drum rollers; gentler agitation; six-rib belt on the dryer (three or four rib on WP-KM); full 2 year entire product warranty... on and on. For the money, stepping up to KA laundry was a big jump for essentially a bargain price. They did have some problems with timers around this era, but not sure which model it was. This TOL model also came in Ebony - a sexy beast with that gleaming white tub and agitator! |
Post# 633366 , Reply# 4   10/22/2012 at 01:14 (4,201 days old) by whirlykenmore78 (Prior Lake MN (GMT-0500 CDT.))   |   | |
Post# 633491 , Reply# 5   10/22/2012 at 17:58 (4,200 days old) by tecnopolis (Ocala/Dunnellon, Florida 34481)   |   | |
Post# 633492 , Reply# 6   10/22/2012 at 17:59 (4,200 days old) by tecnopolis (Ocala/Dunnellon, Florida 34481)   |   | |
Post# 633496 , Reply# 7   10/22/2012 at 18:47 (4,200 days old) by Iowegian ()   |   | |
Wow! If it wasn't so far away, I'd snag it in a minute. Wonder if it has auto temp control to temper the cold wash selection... |
Post# 633532 , Reply# 8   10/22/2012 at 20:07 (4,200 days old) by whirlcool (Just North Of Houston, Texas)   |   | |
These didn't have auto temp control. When you selected HOT you got water heater hot. For warm cold & hot are mixed. And it even has warm rinse options too! |
Post# 633699 , Reply# 10   10/23/2012 at 12:35 (4,199 days old) by Tomturbomatic (Beltsville, MD)   |   | |
If you want rinse temps of 60 or so, all you have to do is set it for warm rinses and turn the hot tap way down to almost off after the wash fill. I have done that for years with my KA & Maytag washers to get cooler than warm, but warmer than cold rinses any time of the year. |
Post# 633706 , Reply# 11   10/23/2012 at 13:03 (4,199 days old) by geoff (Cape Coral, FL)   |   | |
I have this same machine only one model year ahead. I bought it new in 2006. This machine does have temp control. it has 6 temperature selections, 4 of them are standard, hot\cold, warm\cold, warm\warm, and cold\cold. The other two settings are SensorSure Warm\cold and SensorSure Cold\Cold. The ATC warm is set at 95 degrees and the ATC cold is set at 70. BTW, don't be fooled by the "warm" rinse. The warm rinse is set at 70 degrees, the same as the ATC cold setting. I set mine on warm\warm year round. If it needs warm it will add it, if the tap temp is above 70 it will fill with tap cold. In the dead of winter it will rinse with almost 75% warm water. In summer, tap cold.
Post# 633722 , Reply# 12   10/23/2012 at 13:55 (4,199 days old) by limitededition ()   |   | |
The washer does have tempassure the kitchaid lingo for ATC, it also has six temperture setting and it does have HOT water not Hot water the HOT is water heater HOT |
Post# 633761 , Reply# 14   10/23/2012 at 17:06 (4,199 days old) by geoff (Cape Coral, FL)   |   | |
Post# 633763 , Reply# 15   10/23/2012 at 17:18 (4,199 days old) by geoff (Cape Coral, FL)   |   | |
Post# 633773 , Reply# 16   10/23/2012 at 17:41 (4,199 days old) by DADoES (TX, U.S. of A.)   |   | |
Maybe whirlpool got their act together by 2006.The Whirlpool direct-drive washer design, of which KA toploaders have always been, was put on the market in the early 1980s ... so they'd been produced for 14 years by 1996, and continued until sometime within the last year for a total of more than 30 years ... with very little mechanical changes. My 1991 KA is still perfectly usable (although to be fair it has been used very little since 2004). Has had two repairs, motor coupler and agitator dogs. My parents 1994 KA was taken out of service a couple months ago for a broken timer. It went for 18 years with the coupler replaced twice, the agitator dogs once and the pump once just for good measure, and the lid switch bypassed. Replacement timer is available but I had a 1999 Kenmore 90 fully refurbed and ready to go, waiting for someone to need it. |
Post# 634845 , Reply# 21   10/28/2012 at 08:16 (4,195 days old) by mrb627 (Buford, GA)   |   | |
Post# 634847 , Reply# 22   10/28/2012 at 08:56 (4,195 days old) by dadoes (TX, U.S. of A.)   |   | |
Post# 634849 , Reply# 23   10/28/2012 at 09:15 (4,195 days old) by super32 (Blackstone Massachusetts)   |   | |
Post# 634868 , Reply# 24   10/28/2012 at 12:52 (4,194 days old) by dadoes (TX, U.S. of A.)   |   | |
KAWE960(W) would be the TOL to my KAWE760W. W designates 1990 model year. There was also a KAWE860W, which I believe added a 2nd rinse option (to the Normal cycle) and probably five temp choices (incl warm/warm) instead of four (no warm/warm). My machine (and presumably also 860 and 960) uses the 3rd (lowest) speed for low-speed agitation (on Delicate/Knits cycle & 4-min shift on Perm Press). Highest motor speed is *not* used for agitation at all, only for drain and spin. High-speed agitation is medium motor speed. Utilizing the larger-base agitator with a 3-speed motor on medium speed (1140 RPM, 2-speed equivalent of low) for high agitation and low motor speed (850 RPM, ex-low compared to 2-speeders) for low agitation is one of KA's distinctions of the time. KAWE760W agitation, switching from high speed to low. |
Post# 634869 , Reply# 25   10/28/2012 at 12:53 (4,194 days old) by dadoes (TX, U.S. of A.)   |   | |
Normal cycle starts the final spin with 2 mins medium speed, then changes to 4 mins high speed. Delicate is medium speed final spin, no changes. Perm Press has a final spin of 2 mins on low (850 RPM motor), 2 minutes medium (1140 RPM motor), and 2 minutes high (1725 RPM motor). (it does not normally do a spin-drain) |
Post# 634911 , Reply# 28   10/28/2012 at 17:49 (4,194 days old) by super32 (Blackstone Massachusetts)   |   | |
Dados, you are correct about the agitation speed, I forgot about the slow agitation. Now that I think back, I remember thinking it was strange they had/advertised "3 speed" but it only had 2 agitate speeds and 3 spin speeds depending on the cycle. Usually if some one is bragging about 3 speeds aren't they usually 3 was and 3 spin?
Post# 635168 , Reply# 30   10/29/2012 at 18:29 (4,193 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 635170 , Reply# 31   10/29/2012 at 18:33 (4,193 days old) by super32 (Blackstone Massachusetts)   |   | |
Post# 635180 , Reply# 32   10/29/2012 at 19:01 (4,193 days old) by dadoes (TX, U.S. of A.)   |   | |
Post# 635213 , Reply# 33   10/29/2012 at 20:53 (4,193 days old) by dadoes (TX, U.S. of A.)   |   | |
Post# 635217 , Reply# 34   10/29/2012 at 21:06 (4,193 days old) by StrongEnough78 (California)   |   | |
Post# 635265 , Reply# 35   10/30/2012 at 06:00 (4,193 days old) by mrb627 (Buford, GA)   |   | |
Post# 635642 , Reply# 36   11/1/2012 at 06:26 (4,191 days old) by geoff (Cape Coral, FL)   |   | |
Post# 635654 , Reply# 37   11/1/2012 at 07:46 (4,191 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 635669 , Reply# 38   11/1/2012 at 08:57 (4,191 days old) by Tomturbomatic (Beltsville, MD)   |   | |
Vern, I can assure you that the turnover is fabulous. |
Post# 635773 , Reply# 39   11/1/2012 at 18:59 (4,190 days old) by StrongEnough78 (California)   |   | |
That's what I've heard but have been dying to see it! Lol. And there have been a lot of those for sale here in Fresno. If only I were able. There was one set a few months ago that was absolutely beautiful. Almond color with all the options. They took very good care of the set. It just puzzles me to why they were selling it.
Post# 635774 , Reply# 40   11/1/2012 at 19:00 (4,190 days old) by StrongEnough78 (California)   |   | |
Post# 635788 , Reply# 41   11/1/2012 at 19:33 (4,190 days old) by geoff (Cape Coral, FL)   |   | |
This first video is our king size sheets on the "Sweaters" cycle, which is Slow agaitaion/fast spin. I am using this because they are very delicate fleece sheets. I did though switch it to Cotton/Towels to show you the Fast/Fast agitation. This is on "Large" water level, one level before the max, "Super". I do promise to do a fully loaded vid in the future, But for now, Enjoy!!!!
CLICK HERE TO GO TO geoff's LINK |
Post# 635790 , Reply# 42   11/1/2012 at 19:36 (4,190 days old) by geoff (Cape Coral, FL)   |   | |
Post# 635795 , Reply# 43   11/1/2012 at 19:56 (4,190 days old) by StrongEnough78 (California)   |   | |
Post# 635806 , Reply# 44   11/1/2012 at 20:31 (4,190 days old) by geoff (Cape Coral, FL)   |   | |
Post# 635811 , Reply# 45   11/1/2012 at 21:09 (4,190 days old) by super32 (Blackstone Massachusetts)   |   | |
Post# 635830 , Reply# 46   11/1/2012 at 22:53 (4,190 days old) by StrongEnough78 (California)   |   | |
Post# 635878 , Reply# 47   11/2/2012 at 07:53 (4,190 days old) by mrb627 (Buford, GA)   |   | |
Post# 635884 , Reply# 48   11/2/2012 at 08:19 (4,190 days old) by geoff (Cape Coral, FL)   |   | |
Post# 635886 , Reply# 49   11/2/2012 at 08:32 (4,190 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 635891 , Reply# 50   11/2/2012 at 09:20 (4,190 days old) by geoff (Cape Coral, FL)   |   | |
Post# 635910 , Reply# 51   11/2/2012 at 12:17 (4,189 days old) by geoff (Cape Coral, FL)   |   | |
Post# 635911 , Reply# 52   11/2/2012 at 12:18 (4,189 days old) by geoff (Cape Coral, FL)   |   | |
Post# 635913 , Reply# 53   11/2/2012 at 12:19 (4,189 days old) by geoff (Cape Coral, FL)   |   | |
Post# 635914 , Reply# 54   11/2/2012 at 12:19 (4,189 days old) by geoff (Cape Coral, FL)   |   | |
Post# 635922 , Reply# 55   11/2/2012 at 13:00 (4,189 days old) by geoff (Cape Coral, FL)   |   | |
Here is a video of a full load of darks. It is a little dark (no pun intended) so I shot many different angles to give more perpective. Enjoy!!
Post# 635991 , Reply# 56   11/2/2012 at 18:44 (4,189 days old) by StrongEnough78 (California)   |   | |
Post# 636002 , Reply# 57   11/2/2012 at 19:24 (4,189 days old) by Iowegian ()   |   | |
Wow, nice machine and in great condition, too! Looks like it has every cycle/option a person could ever need. |
Post# 636013 , Reply# 58   11/2/2012 at 19:59 (4,189 days old) by StrongEnough78 (California)   |   | |
Post# 636027 , Reply# 59   11/2/2012 at 21:07 (4,189 days old) by toploader55 (Massachusetts Sand Bar, Cape Cod)   |   | |
Post# 636034 , Reply# 60   11/2/2012 at 21:33 (4,189 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 636036 , Reply# 61   11/2/2012 at 21:38 (4,189 days old) by StrongEnough78 (California)   |   | |
Post# 636116 , Reply# 62   11/3/2012 at 09:58 (4,188 days old) by super32 (Blackstone Massachusetts)   |   | |
Post# 636131 , Reply# 63   11/3/2012 at 12:03 (4,188 days old) by geoff (Cape Coral, FL)   |   | |
Cotton/Towels: Fast/Fast.
Medium agitation followed by stepped spins of medium to fast. Knits/Permanent Press: High/Low Medium agitation followed by medium spins only, no steps. Sweaters: Low/High Slow agitation followed by stepped spins of medium to fast. Delicate: Low/Low Slow agitation followed by medium spins only, no steps. *Wool/Handwash: Ultra Low/Ultra Low Slow intermittent agitation followed by a stepped spin of Ultra Low (850 Rpm motor speed) to medium 1140 RPM motor speed). *300 RPM spin speed stepped to 450 RPM spin speed for the last 4 minutes |
Post# 636138 , Reply# 64   11/3/2012 at 12:32 (4,188 days old) by geoff (Cape Coral, FL)   |   | |
Post# 636148 , Reply# 65   11/3/2012 at 13:39 (4,188 days old) by mrb627 (Buford, GA)   |   | |
Post# 636219 , Reply# 66   11/3/2012 at 20:07 (4,188 days old) by electronicontrl (Grand Rapids, MI)   |   | |
When I bought my KAWE860WWH2 washer and KGYE760WWH0 dryer at a 2nd hand store in 2008, the washer had a "Kenmore" dual-action agitator. When I found the original-style turquoise agitator on E-Bay I was happy to replace it. Then I discover the roll over was lousy with that turquoise agitator. The Kenmore agitator gave better rollover. But the action looks even better with the agitator Geoff has.
Post# 636220 , Reply# 67   11/3/2012 at 20:10 (4,188 days old) by electronicontrl (Grand Rapids, MI)   |   | |
Post# 636225 , Reply# 68   11/3/2012 at 20:43 (4,188 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 636239 , Reply# 69   11/3/2012 at 22:40 (4,188 days old) by electronicontrl (Grand Rapids, MI)   |   | |
Post# 636240 , Reply# 70   11/3/2012 at 22:50 (4,188 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 636254 , Reply# 71   11/3/2012 at 23:59 (4,188 days old) by StrongEnough78 (California)   |   | |
Post# 636277 , Reply# 72   11/4/2012 at 03:06 (4,188 days old) by mrb627 (Buford, GA)   |   | |
Post# 636280 , Reply# 73   11/4/2012 at 03:37 (4,188 days old) by geoff (Cape Coral, FL)   |   | |
Post# 636380 , Reply# 74   11/4/2012 at 09:35 (4,187 days old) by mrb627 (Buford, GA)   |   | |
Post# 636390 , Reply# 75   11/4/2012 at 09:57 (4,187 days old) by StrongEnough78 (California)   |   | |
Post# 636404 , Reply# 76   11/4/2012 at 11:19 (4,187 days old) by geoff (Cape Coral, FL)   |   | |
Post# 636475 , Reply# 77   11/4/2012 at 13:12 (4,187 days old) by StrongEnough78 (California)   |   | |
Post# 637011 , Reply# 78   11/6/2012 at 12:04 (4,185 days old) by mrb627 (Buford, GA)   |   | |
