Thread Number: 43061
My Filter Flo Washer |
Post# 633489 , Reply# 1   10/22/2012 at 17:39 (4,175 days old) by robertge ()   |   | |
Also the agitator has the Part number 7387 D68, but I suspect it is not the original part. Thanks again for any light in this issue. |
Post# 633490 , Reply# 2   10/22/2012 at 17:45 (4,175 days old) by StrongEnough78 (California)   |   | |
Either one of those agitators will work in your machine. They look identical to me, I would go with the least expensive of the 2 since they are the same and both New In Box. And the ramped GE Activator will perform much better than the agitator you currently have in there. And out of curiousity, what do you mean exactly when you say your agitator is dead? Is is stripped out where it mounts?
Post# 633494 , Reply# 3   10/22/2012 at 18:21 (4,175 days old) by bajaespuma (Connecticut)   |   | |
Post# 633600 , Reply# 5   10/23/2012 at 00:40 (4,175 days old) by norgechef (Saint George New Brunswick )   |   | |
The agitation gears in the transmission are stripped.....your agitator is fine its a new transmission that you need.....i hope you didn't already buy an agitator! |
Post# 633687 , Reply# 6   10/23/2012 at 11:39 (4,174 days old) by robertge ()   |   | |
This is a close-up picture of the transmission's gear, it's full of grease, I don't know why. :( Should it be changed? |
Post# 633688 , Reply# 7   10/23/2012 at 11:43 (4,174 days old) by robertge ()   |   | |
And this is a pic from the inside of the Activator: Thanks for your interest, I haven't bought any parts. |
Post# 633700 , Reply# 8   10/23/2012 at 12:36 (4,174 days old) by robertge ()   |   | |
Here is the close-up of the transmission's gear, now clean. This is a very amazing forum. Never knew something like this existed until I googled for GE FilterFlo parts. |
Post# 633704 , Reply# 9   10/23/2012 at 12:46 (4,174 days old) by akronman (Akron/Cleveland Ohio)   |   | |
Can you clearly hear and see the motor running the entire time it's supposed to agitate, or does the motor only run during spin? If the motor always runs, you've got internal tranny/agitator gear problems. If the motor only runs during spin, check all the wiring for a bad connection or broken wire.
And can a GE expert tell us what the relay on these GE's does? I believe the relay for GE's is unique, most other motors are directly powered. |
Post# 633720 , Reply# 11   10/23/2012 at 13:46 (4,174 days old) by akronman (Akron/Cleveland Ohio)   |   | |
Post# 633740 , Reply# 12   10/23/2012 at 15:16 (4,174 days old) by StrongEnough78 (California)   |   | |
Post# 633789 , Reply# 13   10/23/2012 at 18:39 (4,174 days old) by d-jones (Western Pennsylvania (Pittsburgh Area))   |   | |
Shot gunning parts is a very expensive way to fix anything. Take the time to learn how the machine functions and then try to logically eliminate potential causes for the problem you're seeing. If you want to perform your own maintenance one thing you may want to track down is a proper service manual for the machine you have. A good service manual will not only provide you with proper service and replacement procedures, but will also provide a good general understanding of how the machine operates under normal circumstances, and what systems are involved in each of those operations. Once you understand those things, then it becomes much easier to figure out why it's NOT doing something. Just a thought.
Post# 633794 , Reply# 14   10/23/2012 at 18:51 (4,174 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
You need to run the washer filled with water [ too the lowest level ] without the agitator installed, if the agitator shaft you pictured is moving back and forth you need a new agitator or I you are a little more motivated just the agitator drive block, it can be replaced separately and is still available and cheap. I am going to bet that your agitator drive block is stripped and you do need one or if you like a complete agitator. |
Post# 634050 , Reply# 15   10/24/2012 at 20:19 (4,173 days old) by robertge ()   |   | |
Thanks for the wise advices, I'll try to make a full video of the machine. Right now I'm using a manual washer, like in the 19th century. I'll let you know if I can fix the problem. |
Post# 634559 , Reply# 16   10/26/2012 at 19:40 (4,171 days old) by bpetersxx (laf in on the banks of the Wabash River)   |   | |
