Thread Number: 43224
HELP!!! FILTER FLO MOTOR BURNING UP!!! |
Post# 635730   11/1/2012 at 14:44 (4,165 days old) by geextrarinse (Hudson Valley, New York )   |   | |
Hey everybody! Well, this is something I haven't encountered so I wanted to seek advice before I proceeded.
I was away and a friend was staying at my apt. He was reluctant to use the older washer and dryer but I told him it would be fine. And of course, as luck would have it, he called and told me he had to shut it off because it was smoking. He unplugged it . I got home today and removed the back panel and turned it on to spin. The motor started up but sounded strained and then began to smoke so badly that the entire room was filled with thick smoke. I was alarmed but not panicked as I know everything is fixable. Now this is my precious 69 3-speed from John Lefever. The clutch does need work but I've always just run it on full speed. The clutch has been a bit loud and clackety. I'm thinking its binding up and putting too much strain on the motor? I am servicing to replace the motor and will hav to rebuild the clutch, which has been in my list of things to do anyway. What should I do in the mean time? Use a two speed motor and clutch or a single speed? Could it be something else? Suggestions please! THANK YOU! |
Post# 635733 , Reply# 1   11/1/2012 at 15:10 (4,165 days old) by Yogitunes (New Jersey)   |   | |
If the motor is SMOKIN'....I would say that does need replacement, and might want to replace the relay also....
they all used a single speed motor, its the clutch that changes the speeds.... as far as clutches, if you have a single speed, that would be the quickest and simplest to replace for now....then as you get the 3speed re-built, then that can go in place of the single... you might find that you'll like the kick-ass washing of the single speed clutch, and not go back...just a thought |
Post# 635734 , Reply# 2   11/1/2012 at 15:17 (4,165 days old) by swestoyz (Cedar Falls, IA)   |   | |
Post# 635741 , Reply# 3   11/1/2012 at 15:45 (4,165 days old) by goatfarmer (South Bend, home of Champions)   |   | |
Post# 635751 , Reply# 4   11/1/2012 at 16:52 (4,165 days old) by geextrarinse (Hudson Valley, New York )   |   | |
I haven't had time to really take it apart and have a good look. The clogged pump did cross my mind. Still though, with the way it was smoking, it was definitely burning up. I'm going to want to change it out anyway. I have an old parts dealer here that prob has a few motors around. Ill swing by tomorrow and see what I can come up with. I think switching to a single speed for the time being is my best bet. Then when I have a chance, I can look into rebuilding the three speed. The single speed is pretty much all I use now anyway.
Post# 635756 , Reply# 5   11/1/2012 at 17:30 (4,165 days old) by coldspot66 (Plymouth, Mass)   |   | |
Make sure you match the correct relay with whatever motor you use. If you caught it right away, you may have just needed a new relay. |
Post# 635766 , Reply# 6   11/1/2012 at 18:28 (4,165 days old) by cfz2882 (Belle Fourche,SD)   |   | |
probably the relay is faulty and caused the motor burnout-when the motor in my filter flo ground to a halt with failed bushing,it did not smoke-just tripped the thermal protector. |
Post# 635917 , Reply# 7   11/2/2012 at 12:34 (4,164 days old) by geextrarinse (Hudson Valley, New York )   |   | |
Post# 635918 , Reply# 8   11/2/2012 at 12:38 (4,164 days old) by geextrarinse (Hudson Valley, New York )   |   | |
Post# 635920 , Reply# 9   11/2/2012 at 12:45 (4,164 days old) by geextrarinse (Hudson Valley, New York )   |   | |
Post# 635923 , Reply# 10   11/2/2012 at 13:19 (4,164 days old) by cfz2882 (Belle Fourche,SD)   |   | |
i'd swap out the relay-repairman is probably thinking of the centrifugal switch used in most other washer motors. The motors that smoked could still be good. |
Post# 635930 , Reply# 11   11/2/2012 at 14:01 (4,164 days old) by geextrarinse (Hudson Valley, New York )   |   | |
Post# 636033 , Reply# 12   11/2/2012 at 21:32 (4,164 days old) by arbilab (Ft Worth TX (Ridglea))   |   | |
Post# 636044 , Reply# 14   11/2/2012 at 22:59 (4,164 days old) by arbilab (Ft Worth TX (Ridglea))   |   | |
Post# 636046 , Reply# 15   11/2/2012 at 23:05 (4,164 days old) by cfz2882 (Belle Fourche,SD)   |   | |
so those dishwashers would stop filling once the impeller grabbed water and put a load on the motor?-neat idea! |
Post# 636057 , Reply# 16   11/3/2012 at 00:00 (4,164 days old) by arbilab (Ft Worth TX (Ridglea))   |   | |
Post# 636098 , Reply# 17   11/3/2012 at 08:41 (4,163 days old) by Jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
Not sure if Roberts AW-6 did , he never lets me look under her skirt!
Relays can become dirty with oil and gunk. If they do then they don't drop out and keep the start windings energized which will cause A LOT of smoke. Sometimes all they need is a good cleaning with contact cleaner. BUT GE relays can only be installed UPRIGHT , they depend on gravity to drop out. There will be alittle arrow on the relay, don't miss that. Your motor maybe toast it may not. Also I think some GE's have a capacitor in series but if that goes the motor won't start at all, it'll just humm. I'd start by cleaning the relay; when you shake it up and down you should hear a rattle if its clean. Otherwise you've got a bound up tranny somewhere. Have fun. jet |
Post# 636154 , Reply# 18   11/3/2012 at 14:32 (4,163 days old) by geextrarinse (Hudson Valley, New York )   |   | |
It was indeed the Relay! I swapped it out and now I'm back in business! I didn't realize that could cause such problems. Well, learning from experience is always the best- even if its sometimes the hard way.
I'm so grateful to this group and website for the knowledge and experience available here. :-) |
Post# 636155 , Reply# 19   11/3/2012 at 14:39 (4,163 days old) by gansky1 (Omaha, The Home of the TV Dinner!)   |   | |
Post# 636160 , Reply# 20   11/3/2012 at 15:06 (4,163 days old) by redcarpetdrew (Fairfield, CA)   |   | |
