Thread Number: 43304
need advice on removing a Vari-Flex agitator |
Post# 636818 , Reply# 1   11/5/2012 at 17:35 (4,183 days old) by Pulsator (Saint Joseph, MI)   |   | |
I can't remember for sure but I don't think there is any other kind of bolt, pin, or clip holding it in... What I ended up doing was sealing the bolt hole on top temporarily (I think I used a thick plastic baggy and duct tape) and then poured boiling water over the top of the agitator where the spline is. That softened the plastic a bit and caused it to expand enough that I was able to get it off (with a bit of force) and then I clean the spline and applied petroleum jelly to it to keep the agitator from getting stuck again. |
Post# 636887 , Reply# 2   11/5/2012 at 20:56 (4,183 days old) by bendixmark (Winchester Mass)   |   | |
Disconnect the hot hose and let it pour over the agitator spline for a few minutes and then give it a good pull.That almost never fails. |
Post# 638218 , Reply# 3   11/11/2012 at 11:30 (4,177 days old) by bajaespuma (Connecticut)   |   | |
