Thread Number: 43422
maytag e2l parts id |
Post# 639130 , Reply# 1   11/14/2012 at 20:24 (4,152 days old) by stan (Napa CA)   |   | |
Post# 639143 , Reply# 2   11/14/2012 at 21:11 (4,152 days old) by qsd-dan (West)   |   | |
Post# 639797 , Reply# 4   11/17/2012 at 19:39 (4,149 days old) by msgt1942 ()   |   | |
Here is the inside of the e2l |
Post# 639842 , Reply# 6   11/17/2012 at 22:16 (4,149 days old) by shankstr (St. Louis, Missouri)   |   | |
Try Phil for parts he's a good guy. Philip Hornyak - ovidny@gmail.com |
Post# 640025 , Reply# 9   11/18/2012 at 16:55 (4,148 days old) by qsd-dan (West)   |   | |
Post# 641094 , Reply# 10   11/23/2012 at 19:50 (4,143 days old) by msgt1942 ()   |   | |
Thanks to gsd-dan shankstr and wringer for your help i bought 3 old maytags that i am doing a home restoration i know literally nothing about them but i like them. |
Post# 641095 , Reply# 11   11/23/2012 at 19:54 (4,143 days old) by msgt1942 ()   |   | |
Working on this one as well |
Post# 641099 , Reply# 12   11/23/2012 at 20:13 (4,143 days old) by Kenmore71 (Minneapolis, MN)   |   | |
If am reading my wringer serial number charts correctly, that machine was "born" in Dec. of 1949. Maytag used aluminum agitators after the war until sometime in 1950 when they went to a red bakelite agitator. Also, your machine should have the earlier cast aluminum tub as opposed to the later spun tub. The cast tubs were considerably thicker and they hold the water hot for a long time! I have an E2L (no pump) from June of 1948 and it has the cast tub and the aluminum agitator.
Post# 641104 , Reply# 13   11/23/2012 at 20:37 (4,143 days old) by qsd-dan (West)   |   | |
Wow, already on the ball. That Model 31 looks great! Decals are available if you want it to look factory fresh.
Looks like your E2L is probably a '49 or '50. Your gray ghost with the non riveted tub is a Model 31 (if the motor is original) Probably a '36 or '37 as it's a later production model via the serial #. Engine looks like 92 to me. Your gray ghost with the riveted tub is a Model 80. Looks like a later model as well, given the serial #. It's probably a '26 or '27. Very nice lineup! You have the perfect set up too. One wringer/washer to wash and the 2 for rinses (wringers require 2 rinses after a wash). Your wife may think you're crazy, but wait until you start cranking out loads of clean laundry at record speed. She'll quickly grow to love 'em ;>) Here's a site that gives a bit more detailed info. CLICK HERE TO GO TO qsd-dan's LINK |
Post# 641302 , Reply# 14   11/24/2012 at 17:00 (4,142 days old) by msgt1942 ()   |   | |
Qsd-dan thanks for the sticker idea i found one on ebay and also some for the engine the engine has a metal plate stamped with model 31 above the carburetor |
Post# 641303 , Reply# 15   11/24/2012 at 17:02 (4,142 days old) by msgt1942 ()   |   | |
Here is the crown i did with stell wool and sandpaper |
Post# 641577 , Reply# 16   11/25/2012 at 16:35 (4,141 days old) by msgt1942 ()   |   | |
Well i got several parts from phil and for the wringer on my e2l and it works but rollers only go in one direction they wont reverse what could be the problem? |
Post# 643238 , Reply# 18   12/1/2012 at 17:24 (4,135 days old) by msgt1942 ()   |   | |
I guess as long as the wringer works in one direction i will leave well enough alone it still wrings clothes well here are updated pics. 2 down one to go |
Post# 643239 , Reply# 19   12/1/2012 at 17:25 (4,135 days old) by msgt1942 ()   |   | |
Here is the model 31 |
Post# 643240 , Reply# 20   12/1/2012 at 17:33 (4,135 days old) by msgt1942 ()   |   | |
Pic |
Post# 643253 , Reply# 21   12/1/2012 at 18:48 (4,135 days old) by msgt1942 ()   |   | |
This is the one i have left will start on it soon qsd-dan called it a grey ghost or are both my old maytags grey ghost? |
Post# 643254 , Reply# 22   12/1/2012 at 18:49 (4,135 days old) by msgt1942 ()   |   | |
Shoul i paint this one all grey? |
Post# 643537 , Reply# 23   12/2/2012 at 18:24 (4,134 days old) by msgt1942 ()   |   | |
Qsd-dan here it is with the sticker |
Post# 643553 , Reply# 24   12/2/2012 at 18:51 (4,134 days old) by qsd-dan (West)   |   | |
Post# 643929 , Reply# 26   12/4/2012 at 01:31 (4,133 days old) by stan (Napa CA)   |   | |
Post# 643972 , Reply# 27   12/4/2012 at 09:14 (4,132 days old) by wringer (x)   |   | |
beauty she is !! You have done a marvelous job restoring her. Now I can't wait to see your further work on the others. Great going !! Jim |
Post# 645123 , Reply# 28   12/8/2012 at 22:52 (4,128 days old) by bradross (New Westminster, BC., Canada)   |   | |
Like Stan, I'd like to know what type of paint you used. You've done a fantastic job - and believe me, I know from experience the amount of work it takes! I used Valspar paint from Lowe's, which I'm mostly pleased with - but it took about 2 weeks for the paint to really cure hard.
Hope you'll be posting some pics of the tub interior and agitator. |
Post# 675751 , Reply# 30   4/27/2013 at 06:36 (3,988 days old) by wringer (x)   |   | |
I just read this thread again and am wondering how you did on the remaining old gal? Let us know, when you have time, about it. You did a beautiful job on the first two. Jim |
Post# 676298 , Reply# 31   4/29/2013 at 19:23 (3,986 days old) by stan (Napa CA)   |   | |
