Thread Number: 43428
Kitchen Aid top load dishwasher $ 50 |
Post# 638562   11/12/2012 at 16:40 (4,179 days old) by xpanam (Palm Springs California )   |   | |
Any one in Newington NH? Looks to be in good shape, missing side racks.
CLICK HERE TO GO TO xpanam's LINK on Nh Craigslist |
Post# 638569 , Reply# 1   11/12/2012 at 16:53 (4,179 days old) by westingman123 ()   |   | |
Must...control...urge...to buy |
Post# 638574 , Reply# 2   11/12/2012 at 17:18 (4,179 days old) by Travis ()   |   | |
Go ahead Keith HOARDER!
Post# 638575 , Reply# 3   11/12/2012 at 17:26 (4,179 days old) by toploader55 (Massachusetts Sand Bar, Cape Cod)   |   | |
Post# 638576 , Reply# 4   11/12/2012 at 17:26 (4,179 days old) by maytag63 (South Berwick, Maine)   |   | |
Post# 638673 , Reply# 5   11/12/2012 at 23:23 (4,179 days old) by sudsmaster (SF Bay Area, California)   |   | |
I have that same dishwasher - it's the KD2P, made about 1958.
$50 is a great deal. The washer running on wash for only a minute could be due to a variety of causes. I'm thinking perhaps the water valve at the bottom might be stuck, or there's a timer issue. Mine would continuously drain during the water addition for washing, because the valve that controlled the shift between draining and washing was stuck. A little WD40 and some coaxing got it back into operation. As will cycling the timer a few times to free up the stuck valve. Could also be a stuck timer; that might be more difficult to fix but this unit is worth it just because it's so cool looking and well made (heavy gauge steel, porcelain coated inside and out). I'd get it if it were within driving distance... |
Post# 638688 , Reply# 6   11/13/2012 at 01:45 (4,178 days old) by xpanam (Palm Springs California )   |   | |
Post# 638708 , Reply# 7   11/13/2012 at 07:32 (4,178 days old) by bajaespuma (Connecticut)   |   | |
Post# 638839 , Reply# 8   11/13/2012 at 19:04 (4,178 days old) by sudsmaster (SF Bay Area, California)   |   | |
Can you rent one?
It might also fit in a big SUV. The machine itself is no bigger than a top loader washer, with nicely rounded edges (SUV interior friendly). But the motor/pump housing below is cast iron, and the whole thing is fairly heavy (although I've seen a guy pick one up and carry it upstairs unassisted). Removing the cast iron spray arm will help to lighten the load. If you do get it, please take some closeup shots of the lid hinges. I made some replacements for mine out of billet stainless steel, but I need to get another look at the detail that locks the lid in the up position. I resorted to very strong springs to do that, but it means the as soon as you open the lid, it will raise up. |
Post# 638913 , Reply# 9   11/13/2012 at 22:38 (4,178 days old) by bajaespuma (Connecticut)   |   | |
That's one of the reasons I want to buy this one. One of the hinges on mine is bent ever so slightly that the cover doesn't open properly and stays up and out of the way. The steel on those friggin' hinges is so thick that I don't think I could straighten it out without a trip to Krypton for some big strong men. |
Post# 639079 , Reply# 11   11/14/2012 at 15:47 (4,177 days old) by stevet (West Melbourne, FL)   |   | |
I bet the drain valve is leaking and the water runs out which makes the Hurricane lose all its power! Maybe it is stuck or just something caught in it or a bad o-ring! |
Post# 639097 , Reply# 12   11/14/2012 at 17:41 (4,177 days old) by toploader55 (Massachusetts Sand Bar, Cape Cod)   |   | |
Post# 639112 , Reply# 13   11/14/2012 at 19:47 (4,177 days old) by stevet (West Melbourne, FL)   |   | |
Only 4 valves left in the country! Part number 77818 List price is 298.90 Yikes.. Did the whole machine cost that much when new? |
Post# 639114 , Reply# 14   11/14/2012 at 19:50 (4,177 days old) by toploader55 (Massachusetts Sand Bar, Cape Cod)   |   | |
Post# 639120 , Reply# 15   11/14/2012 at 19:58 (4,177 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 639187 , Reply# 17   11/15/2012 at 07:17 (4,176 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Hi Rex, no I have never seen a Mini-Van with a lift gate, but the lift height is pretty low and since most machines can be safely moved on there side they make a good light duty mover. But if you are really serious then an enclosed truck with a power lift gate is by far the best way, like the 15' Chevy box truck we have. The mini-vans are a lot faster, more fuel efficient, safer and fun to drive however and I may be making an 8 hour drive this weekend to get one classic appliance so I will be taking the mini-van.
With the rear seats removed I use the really beefy straps to firmly strap down the appliance to the seat anchor points on the floor so the appliance cannot shift and either get damaged or kill me in a fast stop or minor accident. |
Post# 639201 , Reply# 18   11/15/2012 at 09:49 (4,176 days old) by Tomturbomatic (Beltsville, MD)   |   | |
Death by dishwasher. In a van. Was it tricked out? No, just turned over. |
