Thread Number: 43483
Filtrator help needed. |
Post# 639376   11/16/2012 at 08:50 (4,172 days old) by joelippard (Hickory)   |   | |
I'm having a bad run of luck with my dryers. Now the Filtrator is down. I have reason to believe that the reset button is faulty. I want to replace this button and I have a spare but how do I access this properly? As you can see here I have removed the top, it does not appear that the back panel portion behind the controls is removable. This switch has these odd looking grommets in place with screws coming through the other side. I do not have a filtrator service manual and need to know to to properly access and replace this button.
Thanks, Joe |
Post# 639448 , Reply# 1   11/16/2012 at 16:17 (4,172 days old) by joelippard (Hickory)   |   | |
Post# 639655 , Reply# 2   11/17/2012 at 11:12 (4,171 days old) by joelippard (Hickory)   |   | |
Finally figured it out myself. For the archives: You must remove the timer and temperature knobs, then the pilot lamp cover, then the chrome trim piece, underneath it are the screws that hold in the reset switch assembly. Luckily I had a spare reset button. The whole thing took about 30 minutes and now we're back to Filtrating again. |
Post# 639768 , Reply# 3   11/17/2012 at 18:28 (4,171 days old) by golittlesport (California)   |   | |
Post# 639857 , Reply# 4   11/17/2012 at 23:21 (4,170 days old) by joelippard (Hickory)   |   | |
