Thread Number: 43518
Jet Action |
Post# 639865   11/18/2012 at 02:02 (4,148 days old) by Jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
Post# 639870 , Reply# 1   11/18/2012 at 05:21 (4,148 days old) by toploader55 (Massachusetts Sand Bar, Cape Cod)   |   | |
Post# 639901 , Reply# 2   11/18/2012 at 08:23 (4,147 days old) by Jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
Post# 639903 , Reply# 3   11/18/2012 at 08:30 (4,147 days old) by appnut (TX)   |   | |
Post# 639909 , Reply# 4   11/18/2012 at 08:40 (4,147 days old) by Jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
Post# 639971 , Reply# 5   11/18/2012 at 13:08 (4,147 days old) by mickeyd (Hamburg NY)   |   | |
Did not know the 1010 was accomplished in three stages. Our 65 did it in two. The 3 stage is so cool and exciting. Learn something new every day. Did the 65 spin at less than 1010?
Also intrigued by the hurl back in the 1-18 at the third minute of the vid. Is it even more dramatic and fulsome at high water levels?
So glad you've trained the solenoid robot to call the Unbalanced Load Police after the wash spin so that the rinse spin will be oh so nice and smooth. |
Post# 639974 , Reply# 6   11/18/2012 at 13:20 (4,147 days old) by Jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
Post# 639977 , Reply# 7   11/18/2012 at 13:32 (4,147 days old) by nmassman44 (Brooksville Florida)   |   | |
Post# 639978 , Reply# 8   11/18/2012 at 13:39 (4,147 days old) by appnut (TX)   |   | |
Mikey, what model was your 1965 Frigidaire? Only the Imperial and Custom Imperial had the rapid 1010 dry I do believe? One on of my mom's best friends had a WCI65 and it did the 1010 target in 3 stages. Another friend of my mom's had a WCD65. It just had two spin speeds. The Custom Imperial actually had 4 spin speeds.
Post# 640079 , Reply# 9   11/18/2012 at 20:05 (4,147 days old) by joelippard (Hickory)   |   | |
Post# 640120 , Reply# 10   11/19/2012 at 00:25 (4,147 days old) by PhilR (Quebec Canada)   |   | |
As others said, the Rollermatic Rapidry models had 4 spin speeds 300-450-675-1010 RPM and the 1010 speed was achieved in 3 steps:
-The first one being the 300 RPM with the motor on slow speed -Then 675 with the high speed solenoid energized but the motor still on slow speed, -Finally 1010 as the motor gets on high speed. The 450 RPM spin is achieved on Rapidry models on some settings with the motor on high speed but the high spin speed solenoid not energized. |
Post# 640121 , Reply# 11   11/19/2012 at 00:28 (4,147 days old) by pdub (Portland, Oregon)   |   | |
