Thread Number: 43532
Beko WME7247: Poor rinsing |
Post# 640021 , Reply# 4   11/18/2012 at 16:20 (4,173 days old) by aegokocarat (United Kingdom)   |   | |
Hey George, Im not brave enough to do that lol, it uses enough water for my liking, but Im wondering if the spin drains are what cause the poor rinsing. |
Post# 640024 , Reply# 5   11/18/2012 at 16:52 (4,173 days old) by marthalover4eve ()   |   | |
this there a waitrose near you they sell filetti that is a babys powder try that |
Post# 640047 , Reply# 8   11/18/2012 at 18:46 (4,173 days old) by paulc (Edinburgh, Scotland)   |   | |
Post# 640049 , Reply# 9   11/18/2012 at 18:47 (4,173 days old) by ronhic (Canberra, Australia)   |   | |
Ok...well a couple of things from the above.
If you are using vanish in your loads, it is particularly harsh on materials AND skin. I'd suggest stopping that and just use a decent detergent. In my experience here in Oz, with softer water, Vanish is not particularly easy to rinse out. Secondly, if you are washing 5 pyjama sets a week, then they are hardly 'dirty' - generally worn once and possibly after you have bathed of an evening - so going against clean skin. You may need to reduce your detergent dose to 1/2. Finally, clean the filter out on the machine and check there are no kinks in the hose....and watch the full cycle. To my knowledge, Beko don't do spin drains....and my mothers F&P rebadged Beko needed a control board replacing straight out of the box - it wasn't pumping out properly and then heading into spin between rinses. This gave the impression of a 'spin drain'. |
Post# 640054 , Reply# 11   11/18/2012 at 19:02 (4,173 days old) by aegokocarat (United Kingdom)   |   | |
Before I forget, I find the wash performance very good, just the rinsing isnt very good. |
Post# 640148 , Reply# 12   11/19/2012 at 05:11 (4,172 days old) by mrboilwash (Munich,Germany)   |   | |
Hi
in your video the Beko is very effective at handling the sudslock after the first rinse but it seems to do nothing about it after the second rinse. So disappointing, I would be frustrated with that rinse performance as well ! I wonder if it might be just a bug of the synthetic and daily quick cycles. I know it`s not going to be the best solution, but have you thought about using the normal cotton cycles instead and maybe just reduce the spinspeed a little when washing synthetics ? |
Post# 640153 , Reply# 13   11/19/2012 at 05:35 (4,172 days old) by mrboilwash (Munich,Germany)   |   | |
Post# 640185 , Reply# 14   11/19/2012 at 09:59 (4,172 days old) by aegokocarat (United Kingdom)   |   | |
The pump isnt that weak on it, I rekon it sounds weak because the drain hose comes out of the top right hand corner on the back of the machine... |
Post# 640223 , Reply# 17   11/19/2012 at 12:05 (4,172 days old) by glenfieldmathk1 (Glenfield-Leicester-UK)   |   | |
Sorry think I am loosing it with slang all of a sudden, what does IIRC mean?? I know what CBA and IKR etc but whats IIRC?? Yes you should have read the reviews:) I missunderstood your point about vanish - yes one scoop should be enough of normal detergent. |
Post# 640232 , Reply# 18   11/19/2012 at 13:25 (4,172 days old) by aegokocarat (United Kingdom)   |   | |
If I Remember Correctly is what IIRC stands for. Tom :) |
Post# 640243 , Reply# 19   11/19/2012 at 14:36 (4,172 days old) by ronhic (Canberra, Australia)   |   | |
Post# 640255 , Reply# 20   11/19/2012 at 14:59 (4,172 days old) by aegokocarat (United Kingdom)   |   | |
Hey Ronhic, a vanish scoop holds 60 mils, normaly when I do a half scoop its about 30 mils Tom |
Post# 640513 , Reply# 21   11/20/2012 at 17:13 (4,171 days old) by robliverpool (england Liverpool)   |   | |
I had the same problem with my 6 week old beko. Great rinse levels but just wasnt getting all the soap out. I realised I was using twice the amount I needed and reduced the amount of powder and its a lot better. I dont think the beko has a detergent recovery system but have noticed I get great results with less powder.
I uploaded a video onto youtube about five weeks ago and done the link on here. Cant do it now as I'm using my phone but will re post link with the last rinse and you can see there is loads of soap remaining in the water. |
Post# 640518 , Reply# 22   11/20/2012 at 17:31 (4,171 days old) by aegokocarat (United Kingdom)   |   | |
I dont understand why it wont rinse well, I use the same ammount of powder in the samsung and Ive had no trouble. Will be experimenting with it saturday. Tom |
Post# 640662 , Reply# 23   11/21/2012 at 12:53 (4,170 days old) by aegokocarat (United Kingdom)   |   | |
Ive used it today on the longest wash (cottons 40*c is almost 2:30) It rinsed better on the longest cycles. So Im gonna use those from now on. Tom |
Post# 640667 , Reply# 24   11/21/2012 at 13:01 (4,170 days old) by Hoover1100 (U.K.)   |   | |
If you are using the short programmes, it skips a rinse, so yes this will explain the issues you were having... |
