Thread Number: 4355
Guys I have a problem |
Post# 99701 , Reply# 1   12/24/2005 at 13:22 (6,694 days old) by christfr (st louis mo)   |   | |
sounds like a bad water inlet valve on the hot side. the little rubber disc has pooped out.. you can either find a rebuild kit or just replace the valve pair. easy fix dont fret over it.. there are many universal valve assys out there that will work just fine some parts stores might still have the orig.. dont worry i have done lots of valves its an easy fix
Post# 99704 , Reply# 2   12/24/2005 at 13:31 (6,694 days old) by automagic ()   |   | |
Thanks for the advice Chrisfr!! Quick follow up question, where do I find universal valve assys? Can I go to the Home Depot for something like this? Thanks Donnie |
Post# 99705 , Reply# 3   12/24/2005 at 13:43 (6,694 days old) by automagic ()   |   | |
Do I have to open up the whole machine to fix this or is it something that that will just pop in place? Donnie |
Post# 99707 , Reply# 4   12/24/2005 at 14:02 (6,694 days old) by christfr (st louis mo)   |   | |
get the mod # off the back of the machine and call your local appliance parts store or go on line and do some surfing. use the model # and try a search first. if that fails start looking for universal valve sets. there is a place called repair clinic on the web or parts select that you can try or contact dave at www.DavesRepair.com... he should be able to find you a set that will work just fine. all you have to do is slide the machine out and on the back side youll see where the hoses go in, thats where the valves are. there should be a screw that holds the plate on. it all comes out the back side. just remember to unplug the machine so there is no risk of shock. get the new valve set and then remove the cover on the back of the machine and youll get the idea. youll have to unattach the inlet hoses and then remove the cover then unattach the fill hose and unplug the two wires at each valve. then just reinstall everything on the new valve. just take your time and youll be fine
Post# 99708 , Reply# 5   12/24/2005 at 14:08 (6,694 days old) by automagic ()   |   | |
Thanks for you help Christfr Donnie |
Post# 99812 , Reply# 6   12/25/2005 at 09:30 (6,693 days old) by unimatic1140 (Minneapolis)   |   | |
Hi Donnie, yes a bad water valve is a very common problem in all washers no matter the brand or when they were made. What I would do is remove the valve from the washer and take it to any good appliance parts store so they can match up a generic version of the valve. The original most likely will not be available, but a generic will work just as well. It's very easy to remove a Frigidaire water valve. 1. Pull the machine out and unplug it and remove the two fill hoses. 2. Remove the screw from the water valve mounting bracket, then pull the bracket out from the bottom. It's probably hinged on the top with metal posts that pull out. 3. Remove the wires, since there are two sets of wires and they have to go back together in with the same set you might want to tape each of the two sets together so you remember which is which. 4. Remove the inlet hose clamp and hose. 5. Remove the screws that attach the valve to the bracket. Replace in the reverse order. If the holes in the new valve don't line up exactly in the bracket that is OK, you might have to retrofit it slightly, I do this all the time. These pictures might help... |
Post# 100492 , Reply# 7   12/29/2005 at 11:15 (6,689 days old) by automagic ()   |   | |
Robert thank you for the instructions and the diagrams. I went out of town the day after Xmas and just got back. I still need to get to the parts store. I'll let everyone who how the repair goes... Donnie |
Post# 100892 , Reply# 9   12/31/2005 at 07:26 (6,688 days old) by jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
Post# 100899 , Reply# 10   12/31/2005 at 09:13 (6,688 days old) by toggleswitch (New York City, NY)   |   | |
