Thread Number: 43743
POD 11/30/12 MAYTAG HOH DRYER |
Post# 642964 , Reply# 1   11/30/2012 at 17:16 (4,161 days old) by mrb627 (Buford, GA)   |   | |
Post# 642971 , Reply# 2   11/30/2012 at 17:56 (4,161 days old) by qsd-dan (West)   |   | |
Depends on the load. Maybe if it was an underloaded load from a short tub.
I do have a 7'X 8' fleece blanket that's dry in 8-10 minutes in an HOH. Takes my '81 Kenmore a little more than 20 minutes. I'd say the average full load (mixture of shirts/pants/socks) from a '66-'06 tall tub 2 belt Maytag washer takes about 40 minutes to dry in an electric HOH. |
Post# 642986 , Reply# 3   11/30/2012 at 19:04 (4,161 days old) by Tomturbomatic (Beltsville, MD)   |   | |
And electric HOHs are faster than the gas version. |
Post# 643111 , Reply# 4   12/1/2012 at 08:31 (4,161 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Were never very fast and it was probably the only gas dryer where the drying speed was even a little slower in the gas versions. On the electric models they only had a 4800 watt heating element which is 800 watts less than a WP or KM electric dryer, so right out of the starting gate they were going to lose. This coupled with a blower that didn't always run at full speed and too small a lint screen that would get restricted during the first load and a very sensitive hi limit thermostat [ necessary because of the heaters close proximity to a load of eventually dry clothing ] they could never turnout really large loads fast.
HOH were never a great design and MT realized [ without being forced to change by the Department Of Energy or any other government entity ] that it was not a great design and changed voluntarily, they did the same thing with the ill designed reverse rack dishwashers that most customers hated. |
Post# 643189 , Reply# 5   12/1/2012 at 13:41 (4,161 days old) by Kenmore71 (Minneapolis, MN)   |   | |
I would agree that the HOH dryer was not a great dryer in terms of general performance. One of my daily drivers is a 1967 DG806. A large load of heavy cottons from my A806 generally takes an hour to dry in the gas HOH. My other two dryers are a 2002 gas WP and a 1994 electric Maytag DC. The same load as above takes 40 min in the gas WP and about 45 minutes in the electric DC. I had an electric HOH hooked up for a short time would agree that the gas version is a slightly poorer performer than the electric version. The electric could do the same load in 55 minutes! The one thing that the HOH does do nicely is bulky things like comforters and pillows. A comforter will dry completely without turning in a HOH dryer while it will need to be turned every 15-20 minutes in the WP if you expect to get it dry. On the other hand, the HOH is a piss-poor performer with modern wrinkle-resistant cotton dress shirts. The WP with its HUGE drum and the fact that it's upper RH corner exhaust seems to pull lighter weight items like dress shirts all the way to the top of the drum and then drop them in front of the heat stream wins hands down for these!!!
Incidentally, I don't remember anyone asking for a review of the design or performance of the Maytag RR dishwasher in this thread. |
Post# 643256 , Reply# 8   12/1/2012 at 18:59 (4,160 days old) by Volvoguy87 (Cincinnati, OH)   |   | |
I'm using electronic control Maytag HoH dryers right now and I must politely disagree. I find that the electric versions (I have no experience with gas versions) are quite good. The electronic moisture sensor system is the best I've ever used, by far. I find that a load from the A806 dries in 40-45 minutes, a bit longer for jeans or towels. I think the Whirlpool 29" dryer is a generally superior design, but the Maytag HoH is a solid performer in my book.
Dave |
Post# 643264 , Reply# 9   12/1/2012 at 19:45 (4,160 days old) by qsd-dan (West)   |   | |
Wrinkling issues in the HOH's stem from a short cool down period with the original 120F cool down thermostat. A trick I found to eliminate all wrinkling issues was installing an adjustable cool down thermostat. I use a Gemline and set it all the way down to 90F. This gives a 10 minute cool down during the winter months before shutting off. During the summer, I just glance at my watch when I hear the bell chime and remove the clothes 10 minutes later. The dryer will only continue to run in "air fluff" mode for a while until shutting off if one forgets.
Post# 643266 , Reply# 10   12/1/2012 at 19:50 (4,160 days old) by Tomturbomatic (Beltsville, MD)   |   | |
The HOH electronic dryness control is quite good, but no one was saying it is not. I put the adjustable cool down thermostat in my 806 in 1981 and it definitely is an improvement. |
Post# 643296 , Reply# 11   12/1/2012 at 22:21 (4,160 days old) by Kenmore71 (Minneapolis, MN)   |   | |
Dan, I would agree with you that SOME wrinkling issues in HOH stem from a short cool-down period. I did an experiment in this regard a while back. For a while I put a toggle switch on the back of the control panel that by-passed the cool-down stat completely and set up an infinite "press-care" situation. I didn't find that my wrinkle resistant dress-shirts to be appreciably less wrinkled. For those, at least, the WP does the best job. (The Maytag SOH is, incidentally, in the middle on this issue.} I just don't think that the drum is big enough and that the clothes circulation pattern varies enough in the HOH to really work the wrinkles to tumble out of TODAY'S wrinkle resistant cotton fabrics.
I will say, though, if you jam a HOH full of towels or jeans that it will eventually get them all dry. I'm not sure that a drum of that size with a different airflow pattern could do that! Mark. |
Post# 643313 , Reply# 12   12/2/2012 at 00:12 (4,160 days old) by qsd-dan (West)   |   | |
Post# 643367 , Reply# 14   12/2/2012 at 08:04 (4,160 days old) by polkanut (Wausau, WI )   |   | |
Funny I should find this thread after my experience Friday. This last Friday I decided to change out my summer mattress pad for my electric one now that "winter" has come to WI. Well, I washed & rinsed the summer pad in my J2L so that I could run it through the wringer because there's always an air pocket where water gets trapped. I then spun it in my A806s to remove more water, and then into the DE606 it went. Now mind you, this pad is quite thick & bulky, but in about 35 minutes it was for the most part dry with only one small corner just barely moist. I was most impressed. Hats off to Newton, IA. This post was last edited 12/02/2012 at 10:43 |
Post# 643451 , Reply# 15   12/2/2012 at 14:13 (4,160 days old) by mrb627 (Buford, GA)   |   | |
Post# 643474 , Reply# 16   12/2/2012 at 14:54 (4,159 days old) by cadman (Cedar Falls, IA)   |   | |
Post# 643652 , Reply# 19   12/3/2012 at 03:49 (4,159 days old) by MikeKLondon (London)   |   | |
Hi Sorry but what is HOH?? |
Post# 643666 , Reply# 21   12/3/2012 at 08:05 (4,159 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
HOH dryers could be very quite dryers but with Maytag's spotty quality control the last several years of production of the HOH dryer did not guarantee you a quite smooth running dryer. I started working for MT in 1973 , we were selling and servicing MT appliances and quite a few MT HOH dryers had fairly severe noise problems from the get go. We often had to replace poorly balanced motors and blowers and tighten and add washers to rear panel screws to reduce annoying vibrations.
And everyone I am not just picking on Maytag products, I would not have any Whirlpool built dryer as a daily driver that was built before 1966, these earlier WP built dryers were not only inefficient, had small capacity's and often had noise problems. I try to share my experiences sharing from selling and repairing appliances for over 40 years for our companies over 50,000 customers so that everyone that is interested in these cool older appliances can get realistic reviews about how these appliances worked, how reliable they were and what it took to fix and rebuild them. |
Post# 643671 , Reply# 22   12/3/2012 at 08:24 (4,159 days old) by danemodsandy (The Bramford, Apt. 7-E)   |   | |
Post# 643706 , Reply# 24   12/3/2012 at 11:34 (4,159 days old) by tecnopolis (Ocala/Dunnellon, Florida 34481)   |   | |
Post# 643707 , Reply# 25   12/3/2012 at 11:35 (4,159 days old) by tecnopolis (Ocala/Dunnellon, Florida 34481)   |   | |
Post# 643711 , Reply# 26   12/3/2012 at 11:41 (4,159 days old) by tecnopolis (Ocala/Dunnellon, Florida 34481)   |   | |
Post# 643713 , Reply# 27   12/3/2012 at 11:46 (4,159 days old) by tecnopolis (Ocala/Dunnellon, Florida 34481)   |   | |
Post# 643714 , Reply# 28   12/3/2012 at 11:46 (4,159 days old) by Tomturbomatic (Beltsville, MD)   |   | |
What Halo of Heat dryer are you using that provides a 10 minute cooldown? I have never seen a HOH with the timer dial so marked and on the electronic control dryers the cooldown was thermostatic. Even the Perma Press cycle on my mom's SOH only had a 7 minute cooldown. |
Post# 643720 , Reply# 29   12/3/2012 at 12:17 (4,159 days old) by akronman (Akron/Cleveland Ohio)   |   | |
