Thread Number: 44225
Whirlpool dishwasher gasping for water |
Post# 649946   12/30/2012 at 13:40 (4,127 days old) by Pulsator (Saint Joseph, MI)   |   | |
My boyfriend's mother has a Whirlpool dishwasher from I'm guessing the late 80s or early 90s and it seems to be having a problem. My boyfriend says its done this since they got it but I'm wondering if there is something wrong? You know the classic (at least to me) Whirlpool dishwashers fill and run the wash pump at the same time and gasps for water until enough fills the sump until they can get a good burst of water through the spray arms and then begin building up again until they get another burst? Aren't they supposed to fill until they no longer gasp for water and can keep a constant flow of water pressure to the spray arms? This machine does not for any of the fills for washes or rinses. The water level doesn't even touch the heating element and the machine gasps for water throughout the entire cycle. Is it time filled? Is there something to be adjusted? I've already taken the water valve off and inspected it for blockages but its clean as a whistle! The machine gets water less than a foot away from the water heater which is set to its absolute hottest setting, could something have been damaged by how hot the water is? I'm at a loss for what's wrong! If I add around a gallon of water to the tub it stops gasping, sounds much better, and cleans better. Even then, the float switch has not been lifted enough to click its switch!
Post# 649948 , Reply# 1   12/30/2012 at 13:41 (4,127 days old) by Pulsator (Saint Joseph, MI)   |   | |
Post# 649949 , Reply# 2   12/30/2012 at 13:43 (4,127 days old) by Pulsator (Saint Joseph, MI)   |   | |
Post# 649951 , Reply# 3   12/30/2012 at 13:50 (4,127 days old) by mrb627 (Buford, GA)   |   | |
Post# 649954 , Reply# 4   12/30/2012 at 14:14 (4,127 days old) by Yogitunes (New Jersey)   |   | |
Malcolm beat me to it....and he knows what he's talking about
but yes, start checking from the valve, thru the tubing, and the valve, as well as any tubing from the valve to the airgap....your checking to make sure you have full pressure all the way thru.... but most likely, as we all have found once and again, the screen in the valve is clogged.....since it has been doing it since day one, most likely no one flushed the pipes before installing.... I just installed a new faucet for my MIL, within seconds of turning on the spigots, the water dwindled down to a trickle.......grit and such clogged the valves, the spring unit for the sprayer, and the aireator!.....live and learn |
Post# 649964 , Reply# 5   12/30/2012 at 15:04 (4,127 days old) by dustin92 (Jackson, MI)   |   | |
All I can guess is a clogged fill valve screen, or just not enough water pressure to the machine. Our Kenmore ultra wash (basically the same machine) was doing the same thing, just needed the fill screen cleaned. Ours fills before the motor ever starts though. |
Post# 649966 , Reply# 6   12/30/2012 at 16:08 (4,127 days old) by e2l-arry (LAKEWOOD COLORADO)   |   | |
Sometimes it's just a bad inlet valve. I had a Kenmore that always gasped. Never had enough water. The screen and valve looked fine but I ordered a new one from Sears anyway. It's not an expensive part so I thought I'd give it a try. That solved the problem. Larry |
Post# 649967 , Reply# 7   12/30/2012 at 16:12 (4,127 days old) by appnut (TX)   |   | |
Post# 649980 , Reply# 8   12/30/2012 at 17:21 (4,127 days old) by magic_clean (Florida)   |   | |
heating element should be submerged with the "full" 2.2 gallon fill. Sounds like you are not getting enough water. That machine was manufactured the 17th week of 1989! |
Post# 650020 , Reply# 10   12/30/2012 at 20:32 (4,126 days old) by appnut (TX)   |   | |
Post# 650804 , Reply# 13   1/3/2013 at 15:50 (4,123 days old) by roto204 (Tucson, AZ)   |   | |
Sometimes you can get away with adjusting restrictors, but Roger once had a machine that underfilled because--guess what--there was a chunk of crud at the end of the fill hose, where it meets the cabinet. Not in the squeaky clean valve. You never know...
Once the obstruction was removed from the hose, it worked as advertised. We run into this a lot here, where the lime from the water crystallizes on the ends of things, and builds up an obstruction over time. |
Post# 650844 , Reply# 14   1/3/2013 at 19:55 (4,122 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Jamie replace the inlet valve, I am surprised so many of you guys are suggesting cleaning the inlet valve screen after Jamie already said he did this?. After repairing DWs for almost 40 years I have found that poor filling performance is more than 90% of the time caused by a bad inlet valve, just replace it and stop wasting time and risk causing a flood by fooling around with an old valve. |
Post# 808937 , Reply# 15   2/12/2015 at 15:56 (3,353 days old) by GELaundry4ever (Nacogdoches, TX, USA)   |   | |
Iremember the time when my baby sitter started her whirlpool dishwasher, it would make that gasping noise when it filled. This was when I was a child. I can tell you that the dishwasher was not to be messed with! |
Post# 809203 , Reply# 16   2/14/2015 at 01:26 (3,351 days old) by laundromat (Hilo, Hawaii)   |   | |
Mine is a convertible. When I first got it, it did the same thing. While trouble shooting, I removed the intake unscrewing the hose from the male threading. In its screen filter,I found residue back up food particles. I removed them and it works great now. I did this three or four years ago. Not recently. No need to.
