Thread Number: 44355
Kenmore Elite Calypso Washer 110.2106 stuck/stall at any random timer countdown, without any error c |
Post# 651821 , Reply# 1   1/8/2013 at 08:05 (4,097 days old) by Yogitunes (New Jersey)   |   | |
Options and things to try first....
unplug the machine, but not for a few minutes, more like days, at least 2 or 3...you may have a static charge built up.....2 things to also do on a regular basis, keep unplugged when not in use, and attach a grounding wire from the machine to the cold water line.... second, is to unplug all the terminals on the computer boards, again for a day or two, then plug everything back in and see what happens.... which generation do you have 0, 1,or 2?.......number 2 has all the bugs worked out...others still may have issues..... also, if you do replace the boards, replace BOTH at the same time, otherwise the virus will transfer back and forth.... been there done that on several of mine.....no error code, but the machine would come on all by itself and run a cycle.....stranger things have happened! keep us posted...... |
Post# 651912 , Reply# 3   1/8/2013 at 18:15 (4,096 days old) by Yogitunes (New Jersey)   |   | |
its a little harder to check model numbers of a Kenmore compared to the Whirlpool....for a Whirly, its either a KQO, KQ1, or KQ2......
the only way to know a Kenmore for me is the control panel, if yours looks like this pic, then its the most updated version...otherwise its hit or miss of yours, maybe follow this link to see when yours was built, that may also be an indication.... it took almost 3 days unplugged for mine to get rid of the static charge.....since then, never an issue, as long as I keep it unplugged when not in use... also check your service sheet, it may help with some problems.......this Kenmore instructed me to unplug all the terminals, wait, and then plug back in, and then everything started back up as usual..... CLICK HERE TO GO TO Yogitunes's LINK |
Post# 653283 , Reply# 4   1/14/2013 at 13:05 (4,090 days old) by bpetersxx (laf in on the banks of the Wabash River)   |   | |
Post# 654907 , Reply# 6   1/21/2013 at 10:32 (4,084 days old) by Yogitunes (New Jersey)   |   | |
Post# 655222 , Reply# 7   1/22/2013 at 20:18 (4,082 days old) by bpetersxx (laf in on the banks of the Wabash River)   |   | |
Post# 656205 , Reply# 9   1/27/2013 at 08:15 (4,078 days old) by DADoES (TX, U.S. of A.)   |   | |
