Thread Number: 44485
HOOVER A8506 Energy Control 1100 |
Post# 653330   1/14/2013 at 16:29 (4,118 days old) by optima (Cumbria England)   |   | |
Post# 653331 , Reply# 1   1/14/2013 at 16:32 (4,118 days old) by wight_rabbit ()   |   | |
Very Nice! |
Post# 653333 , Reply# 2   1/14/2013 at 16:33 (4,118 days old) by optima (Cumbria England)   |   | |
Post# 653334 , Reply# 3   1/14/2013 at 16:39 (4,118 days old) by optima (Cumbria England)   |   | |
Post# 653336 , Reply# 4   1/14/2013 at 16:48 (4,118 days old) by optima (Cumbria England)   |   | |
Post# 653340 , Reply# 5   1/14/2013 at 16:58 (4,118 days old) by optima (Cumbria England)   |   | |
Post# 653342 , Reply# 6   1/14/2013 at 17:11 (4,118 days old) by vacbear58 (Sutton In Ashfield, East Midlands, UK)   |   | |
Post# 653344 , Reply# 7   1/14/2013 at 17:20 (4,118 days old) by thelaundrylab (Hampshire UK)   |   | |
Post# 653356 , Reply# 8   1/14/2013 at 17:51 (4,118 days old) by optima (Cumbria England)   |   | |
Post# 653360 , Reply# 9   1/14/2013 at 18:01 (4,118 days old) by electron1100 (England)   |   | |
Post# 653366 , Reply# 10   1/14/2013 at 18:23 (4,118 days old) by thelaundrylab (Hampshire UK)   |   | |
Post# 653486 , Reply# 11   1/15/2013 at 09:13 (4,118 days old) by fido ()   |   | |
Is it really warped like that or is it some fancy lens effect? |
Post# 653496 , Reply# 12   1/15/2013 at 10:47 (4,118 days old) by electron1100 (England)   |   | |
Post# 653498 , Reply# 13   1/15/2013 at 10:54 (4,118 days old) by chestermikeuk (Rainhill *Home of the RailwayTrials* Merseyside,UK)   |   | |
Its when ya show an Camra to an Oovahhh for a phota!!, goes all gooey eyed at the thought!!
Craig, great pic up there, what a well built wesher, and they worked great, I saw one fitted into a kitchen with a cut out into the worktop for the vent, madam just got the vent pipe from under the sink and plugged it in, voila, perfect fit!! |
Post# 653500 , Reply# 14   1/15/2013 at 11:01 (4,118 days old) by electron1100 (England)   |   | |
Post# 653501 , Reply# 15   1/15/2013 at 11:03 (4,118 days old) by electron1100 (England)   |   | |
Post# 653529 , Reply# 16   1/15/2013 at 15:25 (4,117 days old) by optima (Cumbria England)   |   | |
Fido,
Sorry about the quality of my so called (warped) Photos i've seen plenty worse on here but i'm not a camera expert far from it. I have one camera & i haven't a clue about Lens Distortion. Did a water test on the Hoover tonight & it's 100% water tight, it heats to the correct temperatures & the timer advances fine. Just waiting for these 2 parts (currently out of stock) then i will plumb The Mean Machine in. |
Post# 653568 , Reply# 17   1/15/2013 at 16:50 (4,117 days old) by optima (Cumbria England)   |   | |
Post# 653571 , Reply# 18   1/15/2013 at 17:03 (4,117 days old) by electron1100 (England)   |   | |
i have this picture management program and it has a "Barrel distortion" feature that allows you to remove the distortion caused by the lens, this is common on all phone/not expensive cameras.
You see it costs sod all to make a multi mega pixel camera but the expensive part is the lens, the more expensive the camera the more accurately the lens will be made, shaped and finished, the less image distortion you will get. |
Post# 653575 , Reply# 19   1/15/2013 at 17:11 (4,117 days old) by optima (Cumbria England)   |   | |
Post# 653578 , Reply# 20   1/15/2013 at 17:22 (4,117 days old) by optima (Cumbria England)   |   | |
Post# 653744 , Reply# 22   1/16/2013 at 14:04 (4,117 days old) by matchboxpaul (U.K)   |   | |
Instruction manual cover... |
Post# 654029 , Reply# 23   1/17/2013 at 19:35 (4,115 days old) by optima (Cumbria England)   |   | |
Post# 654107 , Reply# 24   1/18/2013 at 07:04 (4,115 days old) by electron1100 (England)   |   | |
Hello Craig
if the tub isnt sitting square in the cabinet then you have whats known as a twisted drum, this is caused by the rubber suspension mounts going soft, the result of this is the tub wont sit squarly, it affects spin performance, it is a very common age related problem on Hoovers of this design, but it is a relatively easy job to do, and the parts are still available. Two tools 1/2"/13mm open ended spanner and a good pair of mole grips and some Molykote DX paste to grease up the parts. And of course a Hoover Suspension kit if you need any more help etc dont hesitate to ask Gary |
Post# 654691 , Reply# 25   1/20/2013 at 12:20 (4,113 days old) by optima (Cumbria England)   |   | |
Post# 654713 , Reply# 26   1/20/2013 at 13:29 (4,113 days old) by electron1100 (England)   |   | |
ah well if the nut has come loose then by all means it should be ok, the rubber doesnt look distorted or perished, it is a bit odd that the nut is loose as the ones used have built in threadlocks on them, you should be able to tighten down the nut as far as it will go (runs out of threaded section). The tub will drop on its suspension when it has filled up with water with a load in it, this is more pronounced on the high level rinse cycle Gary |
Post# 654769 , Reply# 27   1/20/2013 at 17:57 (4,112 days old) by optima (Cumbria England)   |   | |
