Thread Number: 44504
My Hoover 3314L Photos |
Post# 653543 , Reply# 1   1/15/2013 at 15:58 (4,116 days old) by wight_rabbit ()   |   | |
Back of Appliance |
Post# 653544 , Reply# 2   1/15/2013 at 15:59 (4,116 days old) by wight_rabbit ()   |   | |
Pipe for Fill Hose?????? |
Post# 653545 , Reply# 3   1/15/2013 at 16:00 (4,116 days old) by wight_rabbit ()   |   | |
Wash Tub Fly Wheel, Belt and Motor - I had not changed the belt at this point. |
Post# 653547 , Reply# 4   1/15/2013 at 16:01 (4,116 days old) by wight_rabbit ()   |   | |
Wash Tub and Pulsator |
Post# 653800 , Reply# 6   1/16/2013 at 18:49 (4,115 days old) by Yogitunes (New Jersey)   |   | |
Post# 653857 , Reply# 7   1/17/2013 at 00:38 (4,115 days old) by SeamusUK (Dover Kent UK)   |   | |
Post# 653863 , Reply# 8   1/17/2013 at 02:50 (4,115 days old) by vacbear58 (Sutton In Ashfield, East Midlands, UK)   |   | |
Martin
The simple answer is that this model does not have a filler port, there was a permanently attached hose which entered the machine alongside the drain hose, if you look up at the second picture above showing the rear of the machine you may see (and from the angle of the photos its not entirely clear) that the entry hole and retaining clip are somewhat larger than they need to be. The filler hose was made of the same type of tubing as the drain hose. This was the only UK model to use this arrangement of hose, although I expect that the Canadian Rinse-O-Matic (see link - scroll down) would have used a similar arrangement. Al CLICK HERE TO GO TO vacbear58's LINK |
Post# 653943 , Reply# 9   1/17/2013 at 15:00 (4,114 days old) by TwinTubber (Toronto)   |   | |
You SOLD your Hoover 0632? Why??? I thought you loved that little machine. Even if you like the colour of mine more ;) |
Post# 653946 , Reply# 10   1/17/2013 at 15:03 (4,114 days old) by TwinTubber (Toronto)   |   | |
Thanks for using my pics and link! I'm flattered. I should let you know however, that those pics are now copyrighted and not available for redistribution. HA HA HA HA HA :) Couldn't resist. |
Post# 653965 , Reply# 12   1/17/2013 at 16:48 (4,114 days old) by Yogitunes (New Jersey)   |   | |
Post# 653969 , Reply# 13   1/17/2013 at 16:57 (4,114 days old) by barcoboy (Canada)   |   | |
Post# 654118 , Reply# 17   1/18/2013 at 07:59 (4,113 days old) by ozzie908 (Lincoln UK)   |   | |
Post# 654342 , Reply# 20   1/18/2013 at 21:35 (4,113 days old) by barcoboy (Canada)   |   | |
Post# 654418 , Reply# 24   1/19/2013 at 07:56 (4,112 days old) by matchboxpaul (U.K)   |   | |
Post# 654419 , Reply# 25   1/19/2013 at 07:57 (4,112 days old) by matchboxpaul (U.K)   |   | |
Post# 654420 , Reply# 26   1/19/2013 at 07:57 (4,112 days old) by matchboxpaul (U.K)   |   | |
Post# 654421 , Reply# 27   1/19/2013 at 07:58 (4,112 days old) by matchboxpaul (U.K)   |   | |
Post# 654423 , Reply# 28   1/19/2013 at 07:59 (4,112 days old) by matchboxpaul (U.K)   |   | |
Post# 654424 , Reply# 29   1/19/2013 at 08:02 (4,112 days old) by matchboxpaul (U.K)   |   | |
Post# 654425 , Reply# 30   1/19/2013 at 08:02 (4,112 days old) by matchboxpaul (U.K)   |   | |
Post# 654426 , Reply# 31   1/19/2013 at 08:03 (4,112 days old) by matchboxpaul (U.K)   |   | |
Post# 654427 , Reply# 32   1/19/2013 at 08:03 (4,112 days old) by matchboxpaul (U.K)   |   | |
Post# 654428 , Reply# 33   1/19/2013 at 08:04 (4,112 days old) by matchboxpaul (U.K)   |   | |
Post# 654429 , Reply# 34   1/19/2013 at 08:05 (4,112 days old) by matchboxpaul (U.K)   |   | |
Post# 654430 , Reply# 35   1/19/2013 at 08:05 (4,112 days old) by matchboxpaul (U.K)   |   | |
Post# 654431 , Reply# 36   1/19/2013 at 08:06 (4,112 days old) by matchboxpaul (U.K)   |   | |
Post# 654432 , Reply# 37   1/19/2013 at 08:06 (4,112 days old) by matchboxpaul (U.K)   |   | |
retrofitting of the interlock... |
Post# 654433 , Reply# 38   1/19/2013 at 08:07 (4,112 days old) by matchboxpaul (U.K)   |   | |
Post# 654434 , Reply# 39   1/19/2013 at 08:08 (4,112 days old) by matchboxpaul (U.K)   |   | |
Post# 654435 , Reply# 40   1/19/2013 at 08:11 (4,112 days old) by matchboxpaul (U.K)   |   | |
thats your lot, for the next page in the service manual is for the next series of machines, that ushered in the letter 'T'. Hope the above is of help to owners. Paul |
Post# 654795 , Reply# 41   1/20/2013 at 19:19 (4,111 days old) by optima (Cumbria England)   |   | |
Post# 654967 , Reply# 42   1/21/2013 at 15:17 (4,110 days old) by sesteve (London, UK)   |   | |
Thanks Paul - Very helpful for when I get round to restoring my 3314L which hopefully will be soon. Might do my T5024 first though as ebayed my working T5090 so need to get another HMDL up and running to play with.
I love the letter to all the Hoover dealers. You wouldn't get that now :( Cheers Stephen |
Post# 654978 , Reply# 43   1/21/2013 at 16:26 (4,110 days old) by sesteve (London, UK)   |   | |
Post# 654980 , Reply# 44   1/21/2013 at 16:28 (4,110 days old) by sesteve (London, UK)   |   | |
Post# 654982 , Reply# 45   1/21/2013 at 16:29 (4,110 days old) by sesteve (London, UK)   |   | |
Post# 654983 , Reply# 46   1/21/2013 at 16:31 (4,110 days old) by sesteve (London, UK)   |   | |
Post# 654984 , Reply# 47   1/21/2013 at 16:32 (4,110 days old) by sesteve (London, UK)   |   | |
Post# 654985 , Reply# 48   1/21/2013 at 16:34 (4,110 days old) by sesteve (London, UK)   |   | |
Post# 654987 , Reply# 49   1/21/2013 at 16:35 (4,110 days old) by sesteve (London, UK)   |   | |
Post# 657577 , Reply# 50   2/2/2013 at 05:11 (4,099 days old) by chestermikeuk (Rainhill *Home of the RailwayTrials* Merseyside,UK)   |   | |
can you imagine trying to stuff that in the spinner when soaking wet, would weigh a ton!! Thanks to Paul for posting, my manuals are in a garage in stafford have found out!!
Wight Rabbit , how are you getting on with the restoration?? I think you have on of the earlier models with the larger diameter empty hose, in the later production runs it changed to the slightly slimmer size that are on all the later models!! |
Post# 657591 , Reply# 51   2/2/2013 at 08:09 (4,098 days old) by ozzie908 (Lincoln UK)   |   | |
How they have changed their minds if you read the above thread re fabric softener they recommend you rinse nappies in it to make them softer, now correct me if I am wrong but surely the whole point of a nappy is to absorb as much as possible and we all know that fabric softener makes them less so !!
How times change? Austin |
