Thread Number: 44509
My Haier frontloaders help |
Post# 653632   1/15/2013 at 21:21 (4,117 days old) by bpetersxx (laf in on the banks of the Wabash River)   |   | |
I have a problem with both my Haier frontloaders
My xqg50-11 washer dryer has 2 problems :
The dryer will not heat because the protective fuse keeps blowing
I got a new fuse and thermostat to replace the blown out ones but I am wondering if I should replace the heater as well
I do not know why it is blowing fuses like it is
the repair instructions say to replace the fuse and the thermostat because when the fuse goes out the thermostat is fried as well
Also the inner tub is loose I can take a hold if it and it will rock a little bit
I am worried the bearings are going out on it or the spider is broken
it does not make too much noise when it operates
I wanted to talk the yoke off the back that has the bearings in it but I cannot get the drive pulley off the screw that holds it on will not come off all I did is try to chew out the slot on it
my xqg50-qf802 has an electrical problem:
the door lock makes a pop occasionally will make a pop sound and smoke comes out of it
It works fine otherwise
Can messing with the pressure switch do that as I have been experimenting with adjusting it to lower the water level I wash small loads in it and it will not balance
I would like to get them working as I cannot find any frontloaders that have a regular timer system on them just electronic ones
Post# 654036 , Reply# 2   1/17/2013 at 19:57 (4,115 days old) by bpetersxx (laf in on the banks of the Wabash River)   |   | |
1 I'll try to multitester on the wiring
2 Just a little movement in the tub no noise in any case 3 May replace the lock and keep the old on attached if I can to the cabinet Now if I can fugure out if the bleach is dispensing at the right time in the WD combo unit Thw washer I named the POS machine I was adding it top the tub at the first rinse to make sure the bleach was rinsed out by the fourth rinse |
Post# 654349 , Reply# 3   1/18/2013 at 22:00 (4,114 days old) by bpetersxx (laf in on the banks of the Wabash River)   |   | |
Post# 687166 , Reply# 4   7/3/2013 at 18:45 (3,948 days old) by bpetersxx (laf in on the banks of the Wabash River)   |   | |
update
the XQG50-11 developed a new quirk The dry portion of the washer dryer will not terminate at times I have to wiggle the wash dial Also it will not tumble at time either dial wiggling as well for it So I will have to osrt out the no heat and the timer issues at a later time sorry no pics right at this time only youtube videos |
