Thread Number: 44540
Hotpoint Supermatic Plus 9404, we have a problem :( |
Post# 654102 , Reply# 1   1/18/2013 at 06:34 (4,088 days old) by kenmoreguy89 (Valenza Piemonte, Italy- Soon to be US immigrant.)   |   | |
Sorry I didn't understand is the filter on the tub and that is clogged or the pump itself? If so you might try to remove the spout and tub filter and stuck a fill, drain or general hose to a tap and stuck it the spout hole and let water go through this at max power (hot+warm) in the reverse way.....maybe it can help push down the clogging to the tub hole... just to say....would this tecnique be applied? This post was last edited 01/18/2013 at 06:52 |
Post# 654104 , Reply# 2   1/18/2013 at 06:44 (4,088 days old) by kenmoreguy89 (Valenza Piemonte, Italy- Soon to be US immigrant.)   |   | |
Anyway if this is the same principle of filter flo pump is driven by the motor, and the same pump tha drain water is the same unit that recirculate it into the wash, in filter flo pump is divided in 2 chambers, one for recirculating water and one for drain....motor turns 2 ways...one druring wash and other to spin, so during spin you get drain pumping and during wash water recirculating, each chamber do have the propellers respectively in opposite direction each other.... |
Post# 654105 , Reply# 3   1/18/2013 at 06:54 (4,088 days old) by vacbear58 (Sutton In Ashfield, East Midlands, UK)   |   | |
Post# 654106 , Reply# 4   1/18/2013 at 07:01 (4,088 days old) by kenmoreguy89 (Valenza Piemonte, Italy- Soon to be US immigrant.)   |   | |
Post# 654117 , Reply# 5   1/18/2013 at 07:50 (4,088 days old) by keymatic3203 (Cardiff UK)   |   | |
I've responded to your question under your photo in the 3314L thread as your photo with the back off shows the sumphose with a filter. mathew |
Post# 654186 , Reply# 6   1/18/2013 at 12:33 (4,087 days old) by andyvivo (Essex)   |   | |
Chris, Have you lifted the agitator off and checked the sump hose guard? Andy |
