Thread Number: 44598
NorgeAmanaTag Pump |
Post# 654735   1/20/2013 at 15:30 (4,111 days old) by DADoES (TX, U.S. of A.)   |   | |
A PAV5157AWW was given to me. Has a bad pump (and belt). The original pump has an integral mounting plate. I find two replacement choices: with plate (35-6465) and without plate (35-6780, says it's a revision that mounts directly to the base so I assume it will also work). Cheaper price on 35-6465. Is there a specific benefit to the non-plate style? |
Post# 654778 , Reply# 1   1/20/2013 at 18:23 (4,110 days old) by goatfarmer (South Bend, home of Champions)   |   | |
Post# 656024 , Reply# 3   1/26/2013 at 13:39 (4,105 days old) by redcarpetdrew (Fairfield, CA)   |   | |
There are older pav's (and M/W's) that the drain hose comes out of a rectangular access panel on the back and the pump output on one type of pump is angled up so as to clear the hole for the drain hose. The other one will not clear the hole. On washers like mav's where the pump is up front or pav(t)'s where the drain hose comes out a hole on the other side of the machine from where the pump mounts, it's not as critical.
RCD |
Post# 656053 , Reply# 4   1/26/2013 at 15:01 (4,105 days old) by DADoES (TX, U.S. of A.)   |   | |
There are older pav's (and M/W's) that the drain hose comes out of a rectangular access panel on the back and the pump output on one type of pump is angled up so as to clear the hole for the drain hose.This is my situation, thanks for detailing that difference. Leastwise the pump I need is the cheaper one! Matched pair is from kin-folk. They called a several months prior, said the washer was making an occasional grinding or rattling noise. The wife had long wanted an HE machine (read: frontloader), so they weren't much interested in repair. A few days later the noise cleared up. I advised to let the machine go until it dies, which happened a couple months later. Jammed-up on spin but supposedly (I didn't observe the situation) agitated. They cranked the belt, it turned one way, jammed the other. Bought replacements, gave me the old pair. My surprise at finding a simple pump failure. |
Post# 656083 , Reply# 5   1/26/2013 at 17:06 (4,104 days old) by redcarpetdrew (Fairfield, CA)   |   | |
That's what kills me. The retrofitted pump WITHOUT the metal base costs more than the pump with the metal base. Ahhh, the pricing idiosyncrasies of WhirlTag... Feel lucky that they just haven't nla'd the pump flat out! BUT give it time... Soon enough we'll be shooting these for lack of parts.
Meanwhile, in Beltsville, someone's pulse just quickened at the thought... LOL! RCD |
Post# 656120 , Reply# 7   1/26/2013 at 19:23 (4,104 days old) by redcarpetdrew (Fairfield, CA)   |   | |
It sure did. That's why I laugh. The only metal on that pump is the drive pulley, drive shaft and the bearing set yet that pump usually sells for more than the older one. Go figure. If you look at the lower end of that pump, you can see how the pump seal and bearing is different from the older one where that wavy metal (crown bearing?) could come loose, pop up and catch on the base plate. What kills me is customers who say that the pump locked up "all of a sudden" when you know it made a hellava racket as the metal scraped against the baseplate for a while before it locked up... The other pump, on the other hand, doesn't look like they did anything about the bearing issue...
RCD |
Post# 656507 , Reply# 8   1/28/2013 at 12:56 (4,103 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 656550 , Reply# 10   1/28/2013 at 15:51 (4,103 days old) by goatfarmer (South Bend, home of Champions)   |   | |
