Thread Number: 4479
Modern compact/portable washers |
Post# 101652 , Reply# 1   1/4/2006 at 08:56 (6,685 days old) by toggleswitch (New York City, NY)   |   | |
Post# 101983 , Reply# 5   1/6/2006 at 07:15 (6,683 days old) by toggleswitch (New York City, NY)   |   | |
If you have 24 inches and can put the machine near the sink, something to consider might be a T/L BOL WP or KM. One water level One cycle One wash/rinse temp: warm/cold If you will be connecting it to a sink/faucet, then one temp makes no diff. Locking casters(*wheels*) may even be an option. Adding these to a BOL may still be much less expesnive than a compact portable. Plus side: a full-sized load in a compact cabinet. |
Post# 102470 , Reply# 8   1/8/2006 at 11:44 (6,681 days old) by bpetersxx (laf in on the banks of the Wabash River)   |   | |
Post# 102472 , Reply# 9   1/8/2006 at 11:56 (6,681 days old) by toggleswitch (New York City, NY)   |   | |
Post# 102605 , Reply# 12   1/9/2006 at 08:03 (6,680 days old) by toggleswitch (New York City, NY)   |   | |
BTW- There are also "Y" hoses and rigid "pipe-like" connectors that feed both sides (hot/cold) of the solenoid from ONE fill hose, to do the snap-coupler at the faucet routine. When I am in a rental apt for a few years in the near future I was thinking of getting a 24 inch wide (60cm) T/L-er while I still can. No point in taking my Frigidaire F/L-er with me, these 9 or equivalent)will be plentiful here in the US in the future. [Now, any thoughts in gettin a reluglar (110/220v 30a line)electric dryer and working out a Franken-dry situation by putting a 110v heating element in it? ] |
Post# 102633 , Reply# 14   1/9/2006 at 10:49 (6,680 days old) by toggleswitch (New York City, NY)   |   | |
yup.. a 220 volt line (with our system, on this continent)is basically two 110 volt lines. (They are two different hot-legs, however. If from the same hot-leg the voltage will be ZERO, rather than 220v.) They can share one ground wire safely. Won't get more techincal here; but each hot leag is basically a different *phase* (purposely out-of-synch with the other). |
Post# 102642 , Reply# 15   1/9/2006 at 11:20 (6,680 days old) by rayjay (Carteret, New Jersey)   |   | |
This explains it better, but still a little confused. So...could you use 2 110 lines to run the electric dryer? Or, you woun't be able to do because of the two diferent hot legs? |
Post# 102646 , Reply# 16   1/9/2006 at 11:54 (6,680 days old) by toggleswitch (New York City, NY)   |   | |
In theory yes. But they would have to be fed from the panel box(conusmer-unit => uk) in a certaian way.. Specifically.. meaning one from the black (incoming)wire, and one from the red. Can't take both from the same *hot-leg* (color). Also an American clothes dryer neeads heavier(thicker) wire to handle the required 30 amp draw; most househodd wiring is not of that grade/capacity. |
Post# 102649 , Reply# 17   1/9/2006 at 12:02 (6,680 days old) by toggleswitch (New York City, NY)   |   | |
Ray: Sounds like a three-wire cable was split to use 220 volts for the heater, then ONE side of the ciruit(one hot [color] + the neutral [white]) to get 110v for your outlets. This is not dangerous even though there MAY be a more preferred wiring method. My advice? Don't fret, at all. PERFECTY SAFE, IMHO. |
Post# 102650 , Reply# 18   1/9/2006 at 12:04 (6,680 days old) by rayjay (Carteret, New Jersey)   |   | |
Now I think I understand better. This is interesting. Thanks for the explanation. You are going to make a "wire" man out of me. LOL |
Post# 102828 , Reply# 19   1/10/2006 at 10:35 (6,679 days old) by toggleswitch (New York City, NY)   |   | |
Post# 102829 , Reply# 20   1/10/2006 at 10:36 (6,679 days old) by toggleswitch (New York City, NY)   |   | |
Post# 102832 , Reply# 21   1/10/2006 at 10:45 (6,679 days old) by toggleswitch (New York City, NY)   |   | |
Post# 103032 , Reply# 22   1/11/2006 at 15:37 (6,677 days old) by bpetersxx (laf in on the banks of the Wabash River)   |   | |
Post# 103033 , Reply# 23   1/11/2006 at 15:37 (6,677 days old) by bpetersxx (laf in on the banks of the Wabash River)   |   | |
Post# 103040 , Reply# 24   1/11/2006 at 17:13 (6,677 days old) by whirlcool (Just North Of Houston, Texas)   |   | |
out of the box???? |
Post# 103041 , Reply# 25   1/11/2006 at 17:28 (6,677 days old) by bpetersxx (laf in on the banks of the Wabash River)   |   | |
Post# 103043 , Reply# 26   1/11/2006 at 17:46 (6,677 days old) by bpetersxx (laf in on the banks of the Wabash River)   |   | |
Post# 103044 , Reply# 27   1/11/2006 at 17:53 (6,677 days old) by bpetersxx (laf in on the banks of the Wabash River)   |   | |
Post# 103046 , Reply# 28   1/11/2006 at 18:01 (6,677 days old) by bpetersxx (laf in on the banks of the Wabash River)   |   | |
Post# 103081 , Reply# 29   1/11/2006 at 20:19 (6,677 days old) by bpetersxx (laf in on the banks of the Wabash River)   |   | |
Post# 103082 , Reply# 30   1/11/2006 at 20:20 (6,677 days old) by bpetersxx (laf in on the banks of the Wabash River)   |   | |
Post# 103224 , Reply# 32   1/12/2006 at 15:38 (6,676 days old) by bpetersxx (laf in on the banks of the Wabash River)   |   | |
Post# 103382 , Reply# 36   1/13/2006 at 12:33 (6,676 days old) by designgeek ()   |   | |
Yow!, I just wrote another full-length article there, without even trying:-) Hard to tell when typing in this little "Message" composing box, ha ha... |
Post# 103453 , Reply# 38   1/13/2006 at 17:47 (6,675 days old) by bpetersxx (laf in on the banks of the Wabash River)   |   | |
Post# 103487 , Reply# 39   1/13/2006 at 19:56 (6,675 days old) by bpetersxx (laf in on the banks of the Wabash River)   |   | |
Post# 103489 , Reply# 40   1/13/2006 at 19:58 (6,675 days old) by bpetersxx (laf in on the banks of the Wabash River)   |   | |
Post# 103491 , Reply# 41   1/13/2006 at 19:59 (6,675 days old) by bpetersxx (laf in on the banks of the Wabash River)   |   | |
Post# 103494 , Reply# 42   1/13/2006 at 20:02 (6,675 days old) by bpetersxx (laf in on the banks of the Wabash River)   |   | |
Post# 103495 , Reply# 43   1/13/2006 at 20:03 (6,675 days old) by bpetersxx (laf in on the banks of the Wabash River)   |   | |
Post# 103496 , Reply# 44   1/13/2006 at 20:04 (6,675 days old) by bpetersxx (laf in on the banks of the Wabash River)   |   | |
Post# 103499 , Reply# 45   1/13/2006 at 20:06 (6,675 days old) by bpetersxx (laf in on the banks of the Wabash River)   |   | |
Post# 103500 , Reply# 46   1/13/2006 at 20:06 (6,675 days old) by bpetersxx (laf in on the banks of the Wabash River)   |   | |
Post# 103502 , Reply# 47   1/13/2006 at 20:08 (6,675 days old) by bpetersxx (laf in on the banks of the Wabash River)   |   | |
Post# 103503 , Reply# 48   1/13/2006 at 20:08 (6,675 days old) by bpetersxx (laf in on the banks of the Wabash River)   |   | |
Post# 103504 , Reply# 49   1/13/2006 at 20:09 (6,675 days old) by bpetersxx (laf in on the banks of the Wabash River)   |   | |
Post# 103506 , Reply# 50   1/13/2006 at 20:11 (6,675 days old) by bpetersxx (laf in on the banks of the Wabash River)   |   | |
Post# 103662 , Reply# 52   1/14/2006 at 20:00 (6,674 days old) by bpetersxx (laf in on the banks of the Wabash River)   |   | |
Post# 105701 , Reply# 53   1/25/2006 at 19:09 (6,663 days old) by brettsomers ()   |   | |
it seems to work well... im just doing my first load now... very quiet... more later if yall are interested |
Post# 106100 , Reply# 54   1/27/2006 at 07:52 (6,662 days old) by designgeek ()   |   | |
Yeah, say more. |
Post# 106728 , Reply# 55   1/30/2006 at 02:28 (6,659 days old) by norgeman ()   |   | |
The Danby washer from what I can see from the pictures is a very well built machine. It should last you many years of use. Happy washing! CLICK HERE TO GO TO norgeman's LINK |
