Thread Number: 44875
lg not heating again |
Post# 658249 , Reply# 1   2/5/2013 at 16:00 (4,091 days old) by dyson2drums (United Kingdom)   |   | |
Post# 658253 , Reply# 2   2/5/2013 at 16:15 (4,091 days old) by micks1979 ()   |   | |
cheers for reply lg has changed the pcb4 times and the element 4 times now they are giving me my money back again. do you know the heating phase on yours ? |
Post# 658286 , Reply# 3   2/5/2013 at 17:41 (4,091 days old) by dyson2drums (United Kingdom)   |   | |
I don't know the heating phase tbh. How did you check? I know it heats when the jet is off and when it's on a 60oc wash the door can't open after a while as it's too hot to open for safety reasons.
What temperature does your machine heat to? (For example on cottons 40 or 60 etc) What are your plans now? From what I remember you previously had a dyson like we did which was amazing! |
Post# 658444 , Reply# 6   2/6/2013 at 11:45 (4,090 days old) by logixx (Germany)   |   | |
Post# 658454 , Reply# 7   2/6/2013 at 12:54 (4,090 days old) by electron1100 (England)   |   | |
Post# 658455 , Reply# 8   2/6/2013 at 12:55 (4,090 days old) by electron1100 (England)   |   | |
Post# 658473 , Reply# 10   2/6/2013 at 14:29 (4,090 days old) by dave886 (united kingdom)   |   | |
@electron1100 don't worry i've done this a few times on here. :) |
Post# 658474 , Reply# 11   2/6/2013 at 14:32 (4,090 days old) by dave886 (united kingdom)   |   | |
have you ever had a unbalanced error with the 11kg LG? |
Post# 658476 , Reply# 12   2/6/2013 at 14:36 (4,090 days old) by micks1979 ()   |   | |
i did to start with they changed the pcb saying they knew there was a fault.since then on spin its perfect |
Post# 658498 , Reply# 15   2/6/2013 at 15:34 (4,090 days old) by logixx (Germany)   |   | |
Post# 658499 , Reply# 16   2/6/2013 at 15:40 (4,090 days old) by micks1979 ()   |   | |
i could do that with my dyson. not seen any of the engineers do anything like that on the lg all they used was thermometer. |
Post# 658511 , Reply# 17   2/6/2013 at 16:42 (4,090 days old) by dave886 (united kingdom)   |   | |
is there anyways to find out the temperature on a samsung while on the main was cycle? |
Post# 658518 , Reply# 18   2/6/2013 at 17:03 (4,090 days old) by dyson2drums (United Kingdom)   |   | |
Yeah, on the dyson you held in the temperature and soil type button as you switch it on and then start a wash and it'd display everything on the display.
The LG washing machine at grans (WM12220FD, it has a green led countdown display) also shows the temperature when you hold in the time delay and opt.2 button. However our LG washing machines have a big lcd display so don't do that. Looking forward to hear what LG say to you tomorrow. |
Post# 658524 , Reply# 19   2/6/2013 at 17:21 (4,090 days old) by micks1979 ()   |   | |
next time u wash check your temp. |
Post# 659151 , Reply# 20   2/9/2013 at 10:21 (4,087 days old) by pierreandreply4 (St-Bruno de montarville (province of quebec) canada)   |   | |
Post# 659153 , Reply# 21   2/9/2013 at 10:29 (4,087 days old) by dyson2drums (United Kingdom)   |   | |
Yesterday I was washing a load of new towels, I put them on Cottons 60, it deicided to do 3 rinses as it was a bigger load but not full capacity.
It said it will take 1 hour and 38 minutes, when it got to 1 hour the heating phase had finished and the recirculation spray started. What I did was put in the service mode and the temperature read out was 47 degrees cecius. What did LG's head office say? |
Post# 659294 , Reply# 22   2/9/2013 at 22:53 (4,086 days old) by spinspeed (Far North New South Wales Australia (originally London UK))   |   | |
Interesting thread guys. I have the LG WD14060SD6. 10 kg capacity with steam wash. I have been suspicious for some time now that it is not heating the water correct temp. It is hot and cold fill but it is hooked up to cold faucet only. Today I did a 40c wash with a fairly full load set to cotton wash. Half way thru I opened the door and the water was only tepid, I would say not much above 30C. The results are pretty good so not complaining but a little miffed it lies and doesn't wash at the set temp. I also note that the recirculation only works when the tub is turning, it stops when the tub stops.
I am pretty pleased with the machine though. Simon |
Post# 659313 , Reply# 23   2/10/2013 at 02:37 (4,086 days old) by Haxisfan (Europe - UK / Italy)   |   | |
The older Hoover (Nextra 2004) heats the water to the correct temperature, as I checked the temperature myself. As for the new Hoover (Dynamic - bought last Xmas), on some programs, it won't be able to reach the set temperature if the user does not follow the loading guidelines, this is because it has a smaller heating element (1500W as opposed to 2250w of the other Hoover) and it needs a certain amount of time to heat the water. E.g. there's a program called A59' which is a rapid cycle designed for medium loads, this is supposed to bring the temperature up to 60 degrees providing that the load does not exceed half of the washer capacity.
I used it with a biggish load and I found that the washer disregarded the bigger size of the load and after its set wash time drained the main wash water regardless of the temperature it'd reached (this was only around 50). This cycle is also present in the older Hoover and no matter how full the washer is it always manages to reach 60 degrees in its allocated 38 minutes. The manual in the newr Hoover, states that the actual temperatures might not always correspond the temperature declared by the program. Having said that, there's an option called 'Stain Blaster' that is supposed to heat the water to the declared temperature and keep it there by switching the heater on and off as necessary. Have you perused your LG manual from top to bottom? You might find that this behaviour is similarly described black and white ;-) |
Post# 659339 , Reply# 24   2/10/2013 at 07:00 (4,086 days old) by pierreandreply4 (St-Bruno de montarville (province of quebec) canada)   |   | |
Post# 659348 , Reply# 25   2/10/2013 at 07:56 (4,086 days old) by micks1979 ()   |   | |
try cottons 40 with steam it wont heat at all its a joke lg dont know what to do i have 2 guys coming tomorrow to look at it |
Post# 659360 , Reply# 26   2/10/2013 at 09:17 (4,086 days old) by dyson2drums (United Kingdom)   |   | |
Post# 659361 , Reply# 27   2/10/2013 at 09:18 (4,086 days old) by dyson2drums (United Kingdom)   |   | |
Post# 659363 , Reply# 28   2/10/2013 at 09:25 (4,086 days old) by dyson2drums (United Kingdom)   |   | |
Yesterday I decided to do a load of whites on Cottons 60. I used the 'intensive' option. From what I see it heated the water pretty much to the temperature selected. The cycle duration was 2:13.
1) At 1:39 it finished heating and the shower spray came on. 2) I stopped the machine and put it in service mode and the temperature read out was 56 degrees celcius. I will try Cottons 40 with steam and see what happens. From my findings so far I think if you use the 'intensive' option it heats fully and heats to a lower temperature on standard washes. Would love to hear what the 2 guys have to say tomorrow. |
Post# 659365 , Reply# 29   2/10/2013 at 09:25 (4,086 days old) by dyson2drums (United Kingdom)   |   | |
Post# 659368 , Reply# 30   2/10/2013 at 09:54 (4,086 days old) by pierreandreply4 (St-Bruno de montarville (province of quebec) canada)   |   | |
from what i am seeing i think that your washer as the atc function and it might affect the heating performance or your washer is hot and cold fill and what cycle do you use normaly? normal/casual gentle or have you tough that it might be a defect in your washer.
what i would suggest you try is 1 start your washer with no clothes the temp you use for a normal load and let it run a full cycle after the heating part of your cycle i would suggest you stop and open your washer door and check the water tempature with a termomiter if it reads your reg temp then its not your washer water heater or it might be that the washer as a sensor that check if fabric can stand hot water as sometime the washer might send cold water to cool down the heated water to preven damage of fabric. |
Post# 659460 , Reply# 31   2/10/2013 at 16:43 (4,086 days old) by micks1979 ()   |   | |
how did u get into the service mode dyson2drums? the other 2 machines i still have they told me to dispose of them when i was refunded so will try it with them all. i have tried it with no clothes its just the same. |
Post# 659462 , Reply# 32   2/10/2013 at 16:46 (4,086 days old) by lavamat_jon (UK)   |   | |
Pierre, the European LGs (as with most of our washers) are cold fill only and heat their own water.
Jon |
Post# 659466 , Reply# 33   2/10/2013 at 17:03 (4,086 days old) by dyson2drums (United Kingdom)   |   | |
Post# 659470 , Reply# 34   2/10/2013 at 17:15 (4,086 days old) by micks1979 ()   |   | |
will give it a bash have you done a cottons 40 yet |
Post# 659485 , Reply# 35   2/10/2013 at 17:54 (4,086 days old) by dyson2drums (United Kingdom)   |   | |
Post# 659668 , Reply# 37   2/11/2013 at 16:23 (4,085 days old) by dyson2drums (United Kingdom)   |   | |
Are you using steam wash with all the washes?
The washes I did that I took pictures of and posted in above posts were standard non steam washes. I did a cottons 40 with steam but had to pop out so will try do another tomorrow. This must be frustrating, wonder what LG, Which and Watchdog have to say. |
Post# 659679 , Reply# 38   2/11/2013 at 16:40 (4,085 days old) by micks1979 ()   |   | |
dont use steam now on any wash and not using the machine until its sorted so off to work with 7 loads in the morning. |
Post# 659825 , Reply# 39   2/12/2013 at 07:05 (4,084 days old) by dyson2drums (United Kingdom)   |   | |
Hello again
I've just done a small load on Cottons 40 with steam that consisted of a cardigan, pair of trousers and a top. The machine detected the load and decided to take 1:14 and do only do 2 rinses. I had to pop out but when I came back the shower spray was on so the steam wash phase was completed and the heating phase was also completed. I stopped the machine and put it into service mode. The steam temperature was 98 as it had finished the steam phase approximately 10 minutes before I got to it and the water temperature was 34 degrees celcius. I also opened the door and felt the water which was warm. |
Post# 659924 , Reply# 40   2/12/2013 at 15:20 (4,084 days old) by micks1979 ()   |   | |
guess what! cant fix the machine beyond repair money back and dispose of machine. not got the energy for another lg so hotpoint or hoover in black. |
Post# 659933 , Reply# 41   2/12/2013 at 15:38 (4,084 days old) by dyson2drums (United Kingdom)   |   | |
That's LG's response then I see!
My aunt bought a Hotpoint ultima WMUD942K in black a few months ago and it's an amazing machine. Very quiet, decent drum size, flexible programs and handy options like time saver, extra rinses and much more. Was over last weekend so did 4 loads in it, it performs very well and the water levels vary on every load. The new models (same model number) seem to have Cotton Standard 60, 40 and 20 programs instead of Cottons 90, 60 and 40. However you can select higher temperatures such as 90 by using the variable temperature button. All the best with what you decide to purchase. |
Post# 659939 , Reply# 42   2/12/2013 at 16:11 (4,084 days old) by micks1979 ()   |   | |
cheers still keep an eye on yours! im not letting it go with lg just need a washing machine thats heats water lol so i now have 3 lg machines what a waste. |
Post# 659941 , Reply# 43   2/12/2013 at 16:14 (4,084 days old) by dyson2drums (United Kingdom)   |   | |
Post# 659984 , Reply# 44   2/12/2013 at 19:50 (4,084 days old) by pierreandreply4 (St-Bruno de montarville (province of quebec) canada)   |   | |
Post# 661661 , Reply# 46   2/22/2013 at 12:20 (4,074 days old) by chestermikeuk (Rainhill *Home of the RailwayTrials* Merseyside,UK)   |   | |
Post# 661734 , Reply# 48   2/22/2013 at 17:50 (4,074 days old) by chestermikeuk (Rainhill *Home of the RailwayTrials* Merseyside,UK)   |   | |
The lower priced Maytag UK washers and dryers are TOL Whirlpool branded products.
The higher end are Askos, Whirlpool now own all of Maytag worldwide!! CLICK HERE TO GO TO chestermikeuk's LINK |
Post# 664206 , Reply# 49   3/6/2013 at 13:59 (4,062 days old) by micks1979 ()   |   | |
new machine comes tomorrow yay!!!!! same as paulinroyton. |
