Thread Number: 44934
Raytheon Made Unimac UW50 |
Post# 659055   2/8/2013 at 20:24 (4,088 days old) by Pulsator (Saint Joseph, MI)   |   | |
Does anyone have any interest in these machines? I think they are absolutely fascinating! The fitness center I work at over the summers just got this Raytheon made version (50lb) as a loaner until their new 80lb Alliance version arrives. I have to say that I was absolutely shocked at how effective the spray rinse is on these machines and MAN do they fill up with water fast! The fill lasts about 35 seconds for the initial wash fill and has no need to top off after that. The spray nozzle directly onto the load is VERY effective! I'm quite impressed with this machine! At 300Gs for the spin, it's very quiet. This machine I'm told is from the early to mid 90s and the bearings still sound pretty good considering! Here's a vid of the spray rinse, I pan over to the drain trough to see the sudsy water coming out and just as I did, the other set of fill solenoids banged open and the machine began filling. Took about 23 seconds to fill for this rinse! And look how high the water level is! Almost halfway up the window! I was very impressed with how solid this machine feels!!!
CLICK HERE TO GO TO Pulsator's LINK |
Post# 659056 , Reply# 1   2/8/2013 at 20:28 (4,088 days old) by Pulsator (Saint Joseph, MI)   |   | |
Here's a vid of the end of the 720RPM 300G final spin. You can hear the bearings rumbling a bit but it's still very quiet compared to the old 75lb Unimac soft-mount machines we used to have. I can't wait to see how the new 80lb machine compares! The electronic brake near the end of the video is pretty awesome!!!
Post# 659091 , Reply# 2   2/9/2013 at 01:03 (4,088 days old) by qualin (Canada)   |   | |
Why is there a pipe running to the center of the viewing glass? |
Post# 659092 , Reply# 3   2/9/2013 at 01:08 (4,088 days old) by arbilab (Ft Worth TX (Ridglea))   |   | |
Post# 659183 , Reply# 4   2/9/2013 at 12:53 (4,087 days old) by frontloaderfan (Merrimac valley, MA)   |   | |
Post# 659184 , Reply# 5   2/9/2013 at 12:55 (4,087 days old) by Pulsator (Saint Joseph, MI)   |   | |
Post# 659187 , Reply# 6   2/9/2013 at 13:25 (4,087 days old) by whirlykenmore78 (Prior Lake MN (GMT-0500 CDT.))   |   | |
These are excellently built high performace Washer-extractors. The spin spray through the door works great and saves a ton of time and water. These are built on a full angle iron frame with all SS inner and outer tubs. The oversized motors and bearings last many years of extreme service. As well as dual fill valves they also have dual dump valves to drain the machine faster and keep up with the water and suds load during the spray rinse. Reminder to anyone wanting one for home use. They are gravity drain usually 3 phase and are hardmount machines. All being said I can think of few washers modern or vintage that are made this well or wash this well.
WK78 |
Post# 659299 , Reply# 7   2/10/2013 at 00:17 (4,087 days old) by qualin (Canada)   |   | |
My guess is that these washers cost as much as a Cadillac when new.. |
Post# 659304 , Reply# 8   2/10/2013 at 00:44 (4,087 days old) by whirlykenmore78 (Prior Lake MN (GMT-0500 CDT.))   |   | |
