Thread Number: 44996
Speed Queen AWN542 - washing new jeans |
Post# 659752   2/11/2013 at 21:51 (4,063 days old) by danmantn (Tennessee)   |   | |
Last year someone on here asked me to film the SQ washing jeans, and I did. However, the video was lost in the shuffle. I found the video on a data backup over the weekend and have published. Not sure who requested it, but here it is...in a belated sort of way. :) Enjoy!
CLICK HERE TO GO TO danmantn's LINK |
Post# 659762 , Reply# 1   2/11/2013 at 22:43 (4,063 days old) by DirectDriveDave ()   |   | |
Cool to see that the tub has indeed stopped indexing after the initial break-in. I never fully understood just how that works... |
Post# 659770 , Reply# 2   2/11/2013 at 23:28 (4,063 days old) by danmantn (Tennessee)   |   | |
Post# 659832 , Reply# 3   2/12/2013 at 07:33 (4,062 days old) by billiedyer1954 (Ohio, USA)   |   | |
your vidios on youtube was the reason i bought a speen queen and found this site. thank you so very much. |
Post# 659888 , Reply# 4   2/12/2013 at 12:25 (4,062 days old) by mrb627 (Buford, GA)   |   | |
Post# 659923 , Reply# 5   2/12/2013 at 15:14 (4,062 days old) by Jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
Post# 661519 , Reply# 8   2/21/2013 at 18:35 (4,053 days old) by nmassman44 (Brooksville Florida)   |   | |
Post# 661529 , Reply# 9   2/21/2013 at 19:31 (4,053 days old) by Yogitunes (New Jersey)   |   | |
first of all great videos....as usual, great info
now a couple things I have come across as well.... as for the indexing.....mine has stopped, and I kind of miss it, the little increments seemed to help during the wash.... I also have a Raytheon model, the indexing tub helped with the rimflo filter ring, its movement helped scoop the lint into little piles, rather than just fill the holes, and filter action stopped...... also, over time, an annoying "squeek" developed from the brake, trying to hold the tub completely still......2 drops of 3n1 oil on the disc caused it to do a minimum index, and kill the noise.... one last thing, as Mike has pointed out, the spin on a large load did not seem to reach top speed for me as well......I stretched the spring about 1/2 inch more tighter, gave a better grip for wash and spin.....this slippage is similar to what I had with the Maytag's, but in this case a 3rd spring was added to correct the excess slippage....this may help you guys as well.... |
Post# 661530 , Reply# 10   2/21/2013 at 19:36 (4,053 days old) by nmassman44 (Brooksville Florida)   |   | |
Post# 661554 , Reply# 11   2/21/2013 at 21:19 (4,053 days old) by Yogitunes (New Jersey)   |   | |
to a Maytag, theres slots to add another......
for the SQ.....I just pulled the spring about 1/2 inch tighter, and put a bend in it around the strap that holds it...you never actually remove it, just pull thru the hole and bend into place....it's a stiff wire, vice grips worked best to grab and bend.... |
Post# 661557 , Reply# 12   2/21/2013 at 21:32 (4,053 days old) by DADoES (TX, U.S. of A.)   |   | |
