Thread Number: 45066
Age and manufacturer info request on a kenmore wringer washer. |
Post# 660711   2/16/2013 at 18:58 (4,085 days old) by 2011hoovermatic (owosso michigan)   |   | |
Hello, I'd like to know the approxtamate age and the manufacturer of my kenmore wringer washer 110.6202300 Pictures will be posted upon request. This is my first official wringer washer. |
Post# 660717 , Reply# 1   2/16/2013 at 19:22 (4,085 days old) by Kenmore71 (Minneapolis, MN)   |   | |
Post# 660725 , Reply# 2   2/16/2013 at 20:28 (4,085 days old) by kenwashesmonday (Carlstadt, NJ)   |   | |
110. is Whirlpool, |
Post# 660738 , Reply# 3   2/17/2013 at 00:50 (4,085 days old) by whirlykenmore78 (Prior Lake MN (GMT-0500 CDT.))   |   | |
Post# 660779 , Reply# 4   2/17/2013 at 11:00 (4,085 days old) by 2011hoovermatic (owosso michigan)   |   | |
Here is one picture. Also, the serial number is 08280052. |
Post# 661455 , Reply# 5   2/21/2013 at 12:24 (4,081 days old) by mickeyd (Hamburg NY)   |   | |
You might want to clamp a small pair of vise grips on to the post. That way you can see if the wringer works. Your wringer looks similar to the one on Bradross' new find. Maybe he can tell you better what to do as he does his restoration.
So nice to see a pump and the rare 3 vane. Can't tell if your agitator is aluminum like Brad's or poly. More pix would be wonderful too. Good luck on starting your collection. |
Post# 661474 , Reply# 6   2/21/2013 at 14:25 (4,080 days old) by bradross (New Westminster, BC., Canada)   |   | |
I see from the pic that the wringer control lever is missing. Hope you can find a replacement somewhere. In the meanwhile, I guess you'll have to do like Mike says and use a pair of vice-grips or something similar to activate the wringer.
The wringer assembly on mine is quite different, as you can see from the attached photo. |
Post# 661825 , Reply# 7   2/23/2013 at 06:17 (4,079 days old) by 2011hoovermatic (owosso michigan)   |   | |
I do know that the wringers work. the agitator I believe is a plastic , (I'll have to check again). I will want to save up and look for a wringer knob as it is listed as a dream machine. I'll keep you guys posted. |
Post# 661869 , Reply# 8   2/23/2013 at 12:02 (4,079 days old) by mickeyd (Hamburg NY)   |   | |
Post# 661960 , Reply# 10   2/23/2013 at 18:14 (4,078 days old) by mickeyd (Hamburg NY)   |   | |
Hi Jim, Thank You. If you look at the first two pix of Brad's wringer in his thread, then pop over to this thread and look at Damien's wringer, you'll notice that the rollers, the opening or "mouth," and the feed tray are all an even match. Then if you study the side panel and the control lever, you might see where I'm coming from.
I have a hunch that Damien's control level will be the same as Brad's. So the part number for Brad's may work for Damien, and thus make it easier for him to find it. Jim, I could be completely mistaken, and faulty eye-sighted, but please take another look, and see if you can envision the possibility. The more men we have successfully wringing, the better. LOL. |
