Thread Number: 45246
More progress on my KDS-58C
Post# 662865   2/27/2013 at 16:35 (4,065 days old) by barcoboy (Canada)
barcoboy's profile picture
With some great advice from this site, I've now been able to change the o-rings in my KDS-58C's detergent dispenser as it was dripping and had shown evidence of it doing so for a little while. Was able to drive out the pins with a punch and hammer after a little squirt of WD-40 on each, and found that once the pin was close to being flush with the shaft, I grabbed them underneath with linesman pliers and twisted back and forth while pulling down at the same time, and they came out fairly easy. Was able to find new o-rings the first place I looked... at my local Canadian Tire store (an automotive/hardware store for those that don't know). The old o-rings were in pretty bad shape and dried up, and I brought them with me to match to new ones. Because on the back of the new o-ring box there is a circle with the actual size, matching them was simple. (For reference, the size I got was 1/4" inside diameter x 3.8" outside diameter x 1/16" thickness.) After cleaning everything up, I installed the new o-rings and re-assembled. No more dripping!!!
I also noticed at the same time that one of the terminals for the pre-wash bi-metal was corroded, and the plastic had gotten brittle and was breaking off. Crimped a new connector onto the wires and sanded the bi-metal terminal clean.
I really love this machine!!!
Post# 662866 , Reply# 1   2/27/2013 at 16:37 (4,065 days old) by barcoboy (Canada)
Much cleaner than before. (I didn't take the dispenser out of the machine because it didn't appear to be dripping, although it must have a bit at some point.)
Post# 662867 , Reply# 2   2/27/2013 at 16:38 (4,065 days old) by barcoboy (Canada)
New connector on pre-wash bi-metal.
Post# 663847 , Reply# 3   3/4/2013 at 17:17 (4,060 days old) by PhilR (Quebec Canada)
philr's profile picture
I should do that on a friend's KDS 18 as one of the dispensers leaks a bit...
Post# 663932 , Reply# 4   3/5/2013 at 07:26 (4,060 days old) by barcoboy (Canada)
Very simply procedure PhilR if there is no leaking around the dispenser itself and you only need to change the o-rings. Neat as well as to how the dispensers work by the timer routing power through each bi-metal temporarily to the motor so that the amperage draw of the motor causes the bi-metal to heat and flex thus opening the dispenser door. For that reason, it's a good idea to inspect the bi-metal wiring and change anything that is corroded from the dripping. I'm sure if I hadn't worked on mine, I would have had problems in the near future.
