Thread Number: 45362
HELP WITH A MAYTAG A606 WASHER PLEASE |
Post# 664471 , Reply# 1   3/8/2013 at 02:54 (4,060 days old) by WaterWitch (Pomona, Calif.)   |   | |
Post# 664472 , Reply# 2   3/8/2013 at 03:50 (4,060 days old) by Ultramatic (New York City)   |   | |
Post# 664515 , Reply# 3   3/8/2013 at 08:09 (4,060 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 664521 , Reply# 4   3/8/2013 at 08:35 (4,060 days old) by Kenmore71 (Minneapolis, MN)   |   | |
Post# 664529 , Reply# 5   3/8/2013 at 09:11 (4,060 days old) by rollermatic (cincinnati)   |   | |
as well. something in the transmission has seized up. i'm assuming a complete overhaul would be what is required to fix it.
i know a lot about frigidaire rollermatics but nothing about maytags. i have 2 more rollermatics just patiently waiting for me to work on them this year. so i guess the best thing to do is to store this maytag away and replace it with one of my rollermatics that i do know how to tear down and put back together. bummer! i like that maytag! oh well, that's the way it goes in appliance collecting! |
Post# 664530 , Reply# 6   3/8/2013 at 09:16 (4,060 days old) by Kenmore71 (Minneapolis, MN)   |   | |
You actually have several options. You can tear this one down, crack open the transmission and take a look and decide if it's worth rebuilding. You can find a donor transmission from ANY 1966-1989 machine OR you could even replace the transmission with the later fast-stroke transmission as long as you also change out the agitator.
Post# 664533 , Reply# 7   3/8/2013 at 09:36 (4,060 days old) by rollermatic (cincinnati)   |   | |
i'm sure if i took the time to learn and tear into it i could probably fix this machine with help from guys like you who know these machines. but up till now the only washers i have completely torn down and rebuilded are frigidaire rollermatics. that's why i won't get rid of this machine, i will store it in my barn out back and will come back to it at some point.
i was hpoing for some easy fix when i posted this thread. i thought maybe if i turned the machine over and really put some force on that center pulley i could free it up, like said the last time i used it all was well! that was 2 years ago at least. do have a question. does the agitator just pull off, i don't see a nut or anything holding it on? |
Post# 664536 , Reply# 8   3/8/2013 at 09:49 (4,060 days old) by Kenmore71 (Minneapolis, MN)   |   | |
Post# 664616 , Reply# 9   3/8/2013 at 21:28 (4,060 days old) by rollermatic (cincinnati)   |   | |
that details a maytag transmission rebuild and it was excellent for it's pics and info.
however it's not something i can see myself ever doing. like said above i have several rollermatics i have bought in the past 3 years still waiting on me to tear them down and rebuild them and this i do know how to do well! my time is pretty limited when it comes to appliance work anymore so i'm gonna concentrate on my frigidaires, not this maytag. so i'm gonna do this. i will turn washer over and see if i can free up the center pulley that drives the transmission. who knows, maybe it will loosen up for me, stranger things have happened in my "appliance miracle" experience! if i cannot get it freed up and agitating i will store it in my barn out back and it will be free for the taking to anyone who wants it here! however i will not part it out. someone may want it and put the time and care into it to get it running again. i will know in a couple days if i am giving it away or not. thanks for all the info and if anyone is interested e mail me at soberleaf@yahoo.com. |
Post# 664618 , Reply# 10   3/8/2013 at 21:35 (4,060 days old) by rollermatic (cincinnati)   |   | |
just found ur e mail to me today. this is exactly what i was thinking too. maybe a siezed up pulley due to a frozen bearing. as i said above i'm gonna tip washer back and get to this pulley and try to loosen it up.
also thought i would check oil in transmission itself if i can find where it goes in and comes out. i agree in ur e mail i don't think transmission itself is bad, it worked great until i stored it in my appliance room here in the house for about 2 years! will not be able to try any of this till next week, my weekend is booked solid with work and non appliance stuff i must get done! thanks again, will post a reply here when i check it. |
Post# 664621 , Reply# 11   3/8/2013 at 22:06 (4,060 days old) by rollermatic (cincinnati)   |   | |
IT WORKS!!!! and i didn't even have to tip it over or move it!
all i did was fill it up tonite and turn it on and off a few times to try and break that drive pulley bearing loose or whatever was frozen. i saw the agitator attempt to move a tiny bit with each try. then, with motor off i pulled back on the motor tightening it's tension on the belt and turned it on and it broke free and began to agitate. i am doing a load now!!!!!!!! gonna use this machine frequently to keep it loose. question???? would it help if i did tip machine over and remove drive pulley and attempt to put some oil or wd 40 on area where drive pulley shaft enters transmission, oiling that bearing???? if you tip machine completely over will oil run out of top of transmission? |
Post# 664799 , Reply# 12   3/9/2013 at 21:35 (4,059 days old) by electronicontrl (Grand Rapids, MI)   |   | |
Post# 664817 , Reply# 13   3/9/2013 at 23:23 (4,059 days old) by 70series ( Connecticut.)   |   | |
I'm glad you were able to get it working again. It must of read your mind about it going back to the barn. LOL. James |
Post# 664902 , Reply# 14   3/10/2013 at 13:33 (4,058 days old) by goatfarmer (South Bend, home of Champions)   |   | |
Post# 665174 , Reply# 15   3/11/2013 at 18:04 (4,057 days old) by rollermatic (cincinnati)   |   | |
that bearing goatfarmer! and yes 70 series maybe i did put the fear of God into her! once they go to the shed (barn) out back they usually don't come back in!
and it's running fine! i lubed the motor slider and i'm thinkin maybe the belt is worn but i am using it everyday to keep it active and it's running great! i love that simple design for the spin clutch, mounting the motor on a slider! electronicontri, good luck with yours! maybe try turning that pulley with some type of home made wrench apparatus, i have worked wonders on washers with 2X4 lumber before! as for mine i'm not flipping it over as yet. i just got it installed in my laundry room next to 3 other washers and don't want to have to pull it out if i don't have to. i'm gonna keep using it almost everyday with a small load to keep it active! and i will replace the belt later this year, i found them on partselect.com where i get most of my stuff. |
Post# 665236 , Reply# 16   3/11/2013 at 20:34 (4,057 days old) by qsd-dan (West)   |   | |
The bottom bearing usually isn't the one that causes the problem. It's the top bearing that seizes. |
Post# 665254 , Reply# 17   3/11/2013 at 22:07 (4,057 days old) by rollermatic (cincinnati)   |   | |
your profile pic qsd-dan!!!!
it's so, jackie kennedy! i bet she washed her dishes like that for jack! i haven't laughed that hard in ages!!! as for the maytag being stored in a damp location, not really. it was in an unheated room for the last couple of years here in the house and i do live in a very swampy section of cincinnati (goshen ohio) and there is some moisture in the house but not that bad. i think it just stuck a bit from lack of use and the belt is probably worn and the motor slider wasn't oiled up yet so maybe the belt tension was too loose. as said it's working fine now! |
Post# 703428 , Reply# 18   9/15/2013 at 17:02 (3,869 days old) by maytaga806 (Howell, Michigan)   |   | |
Post# 707505 , Reply# 20   10/6/2013 at 07:04 (3,848 days old) by electronicontrl (Grand Rapids, MI)   |   | |
So Soberleaf (who opened this thread) and Rollermatic are the same (?)
My 806 with the frozen tranny also has a seal issue. I filled it to the med load level and left it for a few hours. Came back to puddle on floor. Slow water leak into transmission. This was months ago. So I know there is a major issue here. I'm going to swap out the 806 set for the Kenmore set. SOMEday maybe learn how to take the transmission apart LOL. But my A712, I'm going to find another working machine and have someone swap trannies for me. - someday - right now other life events to tend to. Glad to hear Soberleaf found his was fixable. I may fill my A712 to medium load level and look for a trickle leak. If I don't find one, I'll look at the options posted here. ALL of my vintage Maytags have an issue: A806S (from Goatfarmer) needs to agitate several min before I put clothes in due to sluggish agitation - prolly needs new tranny fluid and clean-up. But once it warms up - its sweet! A806 (from Capt Moody) - I got a few years of use from this B4 the tranny seizure A712 (from local CL) was a workhorse until it seized A906 (from TrainGuy) UGH! my biggest disappointment I added a 3rd spring to the motor carriage to allow it to spin correctly. Otherwise is ramps up to a fast spin (like there was no clutch action) causing the motor to kick out on thermal overload. The 3rd spring helps with the clutching and it spins correctly. however the agitation is slow. It likely also has thick tranny fluid and needs to be taken apart. I let it agitate empty for 10 min before adding clothes to let it get up to speed. but then the clothes load it down and it agitates sluggish again. |
Post# 707511 , Reply# 21   10/6/2013 at 07:49 (3,848 days old) by goatfarmer (South Bend, home of Champions)   |   | |
