Thread Number: 45371
This was a smart Idea for FL's filters!!! |
Post# 664588   3/8/2013 at 16:10 (4,060 days old) by kenmoreguy89 (Valenza Piemonte, Italy- Soon to be US immigrant.)   |   | |
Post# 664589 , Reply# 1   3/8/2013 at 16:11 (4,060 days old) by kenmoreguy89 (Valenza Piemonte, Italy- Soon to be US immigrant.)   |   | |
Post# 664658 , Reply# 2   3/9/2013 at 01:28 (4,059 days old) by StrongEnough78 (California)   |   | |
Post# 664674 , Reply# 3   3/9/2013 at 06:18 (4,059 days old) by kenmoreguy89 (Valenza Piemonte, Italy- Soon to be US immigrant.)   |   | |
The first commercial advertise about a Fagor machine having the particularity of having the filter on the top panel instead of the bottom like almost all of the machines had and still have nowadays...
In FL's it's very common that small objects like buttons, zips, coins and big lint strips pass through the boot of the drum and clog or get stuck in the pump, potentially burning pump motor if they do get stuck in it or anyway blocking drain hose if they pass over the pump... This means that if you get a clogged filter in the middle of the wash you're not able to drain water, and nor manually by placing drain hose lower that tub level thank to gravity if it is completely clogged, even in the case you manage to drain most part of the water manually it requires alot more of messy job then... Unloading wet clothes spilling water all over, and, anyway spilling all the water that is left in the pump and tub while opening filter to inspect it...... But the Fagor was different and had a smart idea of putting the filter on the top... Infact, with this, theorically you could just open and clean it without all the messy job and resume cycle... The gag of the first one: A lady is attempting to clean the filter of her machine complaining and muttering about the messy job of cleaning filter, a friend meanwhile just came to visit the Lady . The friend tells her she does not have these kind of problems since she has a Fagor having filter on the top.... The Lady tells her husband then: "I would not have had to pass through all this if you bought me a Fagor"... The second commercial is about a Fagor Solaris, a combo machine, it does not advertise by mentioning the fact it does have the filter on the top, just that is a combo machine, only reason I showed it is because it shows well how the pump on the top is made.... I think the fact of filter on the top was already a well known particularity of Fagors so no reason to repeat it..... |
Post# 665016 , Reply# 4   3/11/2013 at 01:42 (4,057 days old) by StrongEnough78 (California)   |   | |
Post# 665052 , Reply# 5   3/11/2013 at 08:14 (4,057 days old) by Jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
Post# 665066 , Reply# 6   3/11/2013 at 09:06 (4,057 days old) by gansky1 (Omaha, The Home of the TV Dinner!)   |   | |
Post# 665093 , Reply# 7   3/11/2013 at 12:13 (4,057 days old) by Tomturbomatic (Beltsville, MD)   |   | |
Greg, Thank you. My thoughts exactly. |
Post# 665128 , Reply# 8   3/11/2013 at 14:51 (4,057 days old) by kenmoreguy89 (Valenza Piemonte, Italy- Soon to be US immigrant.)   |   | |
Gan: No...this is not a lint filter for recirculating water like filter flos.....
This post was last edited 03/11/2013 at 17:48 |
Post# 665131 , Reply# 9   3/11/2013 at 15:31 (4,057 days old) by kenmoreguy89 (Valenza Piemonte, Italy- Soon to be US immigrant.)   |   | |
Anyway I just asked a question to a spanish guy on youtube about how actually the thing is....to be 100% of my theory... I used to do small repairs as school boy to get some tips...small things like pumps, boots things... |
