Thread Number: 45641
spray rinse in FL washers |
Post# 667792   3/23/2013 at 01:11 (4,050 days old) by spinspeed (Far North New South Wales Australia (originally London UK))   |   | |
So I have this really cool new LG steam washer. The water and soap from the soap dispenser enters the heart of the wash directly thru a portal by the door rather than directly in to the outer tub. So I was wondering why no one has used spray rinsing in FL washers. As the tub spins water poring directly on to the spinning load would give a great rinse before a deep rinse or two. Anyone know if there are an FL washers that utilize spray rinsing?
Cheers Simon |
Post# 667814 , Reply# 1   3/23/2013 at 06:59 (4,050 days old) by Haxisfan (Europe - UK / Italy)   |   | |
The main purpose of the water jets in this front loader is to to spray a high concentration of water+detergent solution over the load at the beginning of the wash cycle ... but the jets are also used on rinsing on every possible cycle (even on the 14 minute one) to facilitate the same.
When the link opens, go straight to 13:10 to see the 1st rinse on the Dynamic. CLICK HERE TO GO TO Haxisfan's LINK |
Post# 667817 , Reply# 2   3/23/2013 at 07:06 (4,050 days old) by Haxisfan (Europe - UK / Italy)   |   | |
Post# 667826 , Reply# 3   3/23/2013 at 07:25 (4,050 days old) by mrb627 (Buford, GA)   |   | |
Post# 667890 , Reply# 4   3/23/2013 at 12:30 (4,050 days old) by logixx (Germany)   |   | |
The LG/Kenmore washers with TurboWash/AcellaWash spray rinse clothes, as do the Samsung Speed Spray models (I think).
My washer will fill water directly into the drum with the drum spinning at a low speed - but it's not a spray rinse as such. RE: Speed Queen. Is the jet aimed at the clothes? When I used commercial SQ, the jet just hit the back of the drum and that was it. |
Post# 667903 , Reply# 5   3/23/2013 at 13:04 (4,050 days old) by rp2813 (Sannazay)   |   | |
Post# 667923 , Reply# 6   3/23/2013 at 14:26 (4,050 days old) by arbilab (Ft Worth TX (Ridglea))   |   | |
Post# 667946 , Reply# 7   3/23/2013 at 16:57 (4,050 days old) by jaxsunst ()   |   | |
During rinse spins, My Samsung pours water down the door that gets sucked into the spin. Quite fun to watch. |
Post# 668090 , Reply# 8   3/24/2013 at 13:46 (4,049 days old) by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
Front loading washing machines do not normally require spray rinses or any such. However as efforts to reduce water consumption lead to restrictions on water use, spray rinses can help bridge the gap.
For instance many commercial/laundromat washing machines have a period of flushing/slucing where water enters the moving tub whilst the drain valves are open. This serves to flush out/rinse laundry in the tub but also clears the sump area of suds after rinses. The largest SQ front loader at our local *used* to do this between one or two of the rinses, but from what one can see that option may now have been turned off. On the domestic side our older Miele washer will send water down the front/glass during the final rinse filling as well as the normal between the tub filling. IIRC this is to clear any suds or whatever away from the front of the tub after the preceeding spin cycle. |
