Thread Number: 45673
old maytag a112 |
Post# 668142 , Reply# 1   3/24/2013 at 20:04 (4,043 days old) by Kenmore71 (Minneapolis, MN)   |   | |
It's the correct part number. Was there any literature that came with the timer? Sometimes (and I don't fknow or certain in this case) a different manufacturer's timer will will require you to add or remove a jumper to use on certain machines. This timer was also used on the A412. You may already have this schematic, but if not maybe you can trace out what the problem might be.
