Thread Number: 45821
Early HOH Door Gaskets |
Post# 670177   4/3/2013 at 08:57 (4,034 days old) by elginkid (Cincinnati, OH)   |   | |
Since the Early HOH door gaskets are getting increasingly scarce, is this something that could potentially be replicated like the seals that were done for the Westinghouses? Volvoguy87 and ClassicCaprice, and I all have the early HOH dryers and they all need that particular seal. I have one new unused one that could be used for that purpose, and frankly there are a lot of these machines still left, and I've never encountered one that didn't need that seal.
Wes |
Post# 670182 , Reply# 1   4/3/2013 at 09:27 (4,034 days old) by turquoisedude (.)   |   | |
I don't remember where I heard or read this, but I believe the original ozone lamps in these dryers caused the gaskets to deteroriate (some kind of reaction is my best guess...). I'd bet that a 'Tag dryer that's made it this long is likely on its second gasket already, hence the rarity of the part...
I have the same situation on my DE700 that's out on loan in a store display - I didn't have an ozone lamp in it but was able to sub a C9-base bulb that would be used in a bathroom vanity fixture. |
Post# 670360 , Reply# 2   4/3/2013 at 21:58 (4,033 days old) by classiccaprice (Hampton, Virginia)   |   | |
Post# 670367 , Reply# 4   4/3/2013 at 22:50 (4,033 days old) by Bluejay (Havre de Grace, MD)   |   | |
I had to replace ours. I'm not quite sure what was holding it together. It fits many of the DG/DE models (I have a DE700, which isn't listed but seems to fit okay). I don't think our dryer has had an ozone lamp in quite some time, but I'm pretty sure our seal (or what remains of it) is the original.
CLICK HERE TO GO TO Bluejay's LINK |
Post# 670369 , Reply# 5   4/3/2013 at 22:57 (4,033 days old) by classiccaprice (Hampton, Virginia)   |   | |
Post# 670370 , Reply# 6   4/3/2013 at 22:59 (4,033 days old) by Bluejay (Havre de Grace, MD)   |   | |
Post# 670378 , Reply# 7   4/4/2013 at 01:01 (4,033 days old) by d-jones (Western Pennsylvania (Pittsburgh Area))   |   | |
Parts like this gasket should be easier to make than most others. Since the part is extruded the die is very simple, being little more than a plate with the desired profile cut into it through which the gasket material is then forced. Remember those Play doh devices we had when we were kids that squeezed the Play doh into all kinds of interesting shapes? These gaskets were made using the same principle, though obviously with more complex machinery. Just for grins I measured one of my gaskets to see what the approximate dimensions were and this is what I came up with, though I didn't cut it in half to get a clear view of the profile so it's not completely accurate. But in spite of that it's such a simple shape it's hard to believe there's nothing out there already that would work as a substitute. The part in Jason's link is your basic 06 series gasket, so I'm surprised to hear that he was able to make it work. I have a few of those laying about at my folks house, so now I'm going to have to have a closer look at them.
Post# 670405 , Reply# 8   4/4/2013 at 07:49 (4,033 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
I dough the deterioration of these has much to due with the O-Zone lamps that were used of some models of these dryers, it is much more likely that the old type rubber that was used is just old, also on this dryer design the door seal is also in a fairly hot location.
I should think that it would not be that difficult to come up with something that works for these dryers, after all it does not have to be watertight. The wide flange is somewhat important to protect tumbling clothing from excessive wear and this area often wears away first, I have had success by turning gaskets over so they can continue to be used. But unfortunately the cost of making rubber parts like these is going to be very expensive, so it will likely be better if one of us can come up with a workable substitute. Fortunately the 1/2 dozen older MT dryers in our collection all have decent door seals and since I do not intend to try to use one of these slightly dangerous dryers as a daily driver I dough that I will ever have to replace any of them. |
Post# 670414 , Reply# 9   4/4/2013 at 08:26 (4,033 days old) by gansky1 (Omaha, The Home of the TV Dinner!)   |   | |
Post# 670421 , Reply# 10   4/4/2013 at 09:55 (4,033 days old) by qsd-dan (West)   |   | |
Post# 670424 , Reply# 11   4/4/2013 at 10:05 (4,033 days old) by Kenmore71 (Minneapolis, MN)   |   | |
In looking through the parts lists it appears as though the 6(7)41s had them but the 6(7)42s did not.
Also, it appears as though the early d700s has them but the d701s & d702s did not. I could not find any reference to their elimination in the 1960-62 "Let's Talk Service" bulletins, but that doesn't mean anything. I would say that 1960-61 would be correct and that it was feature that just kind of silently "went away"! |
Post# 670471 , Reply# 12   4/4/2013 at 15:43 (4,032 days old) by danemodsandy (The Bramford, Apt. 7-E)   |   | |
Post# 670527 , Reply# 13   4/4/2013 at 20:46 (4,032 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
I never heard of any problem with these other than they could cause nasal irritation, and WP still used these on a few dryers as late as the 1974 models, Hamilton still had one in 1968 in its dryer. But more likely it was an almost useless feature so I believe that is the major reason for their disappearance. |
Post# 670800 , Reply# 14   4/6/2013 at 07:05 (4,031 days old) by Jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
using my 1957 Charcoal dryer with the ozone lamp-knock on wood! Neither has Robert for that matter! I can't speak for Greg or Skyler yet.
Good point about how they just "slipped" away into oblivion. They weren't even offered as an expensive option after the fact! Actually the nasal thing you speak of was only the tip of the iceberg. Ozone works by oxidizing , it will oxidize germs into oblivion however that also makes it very caustic to your lung tissue, something you won't feel until real damage is done. Ozone is heavy so it stays near the ground, in the 70's they used to issue ozone alerts and people were told to stay indoors on heavy days. So use your bulbs sparingly, for the basement vented dryers probably blew most of it outdoors but that vent was right beside little Johnny's swingset and all the neighborhood kids were told to stay around there so mama could keep an eye on them.
Perfect Storm |
Post# 670923 , Reply# 15   4/6/2013 at 18:11 (4,030 days old) by gansky1 (Omaha, The Home of the TV Dinner!)   |   | |
