Thread Number: 45852
HELP with New Transmission in KA Direct Drive Washer |
Post# 670533 , Reply# 1   4/4/2013 at 21:18 (4,010 days old) by Pulsator (Saint Joseph, MI)   |   | |
It's possible that the transmission is engaged at the moment. If you shut the machine off while it's agitating, you can't move the agitator. Only when the motor reverses and the machine shifts into drain or spin mode will the agitator move freely. Try turning the transmission shaft by hand to see if you can get it to agitate and then turn it the other way to disengage the transmission from the agitator. |
Post# 670537 , Reply# 3   4/4/2013 at 21:58 (4,010 days old) by DirectDriveDave ()   |   | |
When you reattach the motor, leave the pump off temporarily and turn the motor shaft counterclockwise by hand. If you see the agitator move with your turns, you should be fine. |
Post# 670546 , Reply# 6   4/4/2013 at 22:55 (4,010 days old) by squeenjj ()   |   | |
It filled up but won't do anything-- I hope i just forgot to hook the motor back up- about to remove the cabinet see |
Post# 670547 , Reply# 7   4/4/2013 at 22:56 (4,010 days old) by whirlykenmore78 (Prior Lake MN (GMT-0500 CDT.))   |   | |
Post# 670925 , Reply# 10   4/6/2013 at 18:16 (4,008 days old) by whirlykenmore78 (Prior Lake MN (GMT-0500 CDT.))   |   | |
