Thread Number: 45957
Correcting "dumbed down" hot water flow |
Post# 671892   4/11/2013 at 00:29 (4,025 days old) by RevvinKevin (Tinseltown - Shakey Town - La-La Land)   |   | |
I know there has been a lot of discussion this recently and I believe there is little you can do with the computerized and temp controlled machines. However the "more basic" washers you can do something about.
This is a pretty BOL machine we have at work, a single speed, 2 knob wonder that's about 4 years old. It's used for washing towels, shop rags, buffing pads (and the occasional load of someone's personal laundry, EEWWW).
Last weekend the poor thing was getting a REAL work out! It was run non-stop, load after load, for 9 hours each day. I have to say this thing is proving to be a real work horse! After going all day Saturday, by noon on Sunday I had run 22 loads through it and we weren't done yet. By midday Monday things were going at a bit slower pace and today I >only< did 7 loads.
So, last week I was telling a co-worker I could modify the lid switch so it would run with the lid open, she said "OK!" so I did. (it would only fill with the lid open, nothing else.)
Now to get to the point of this post. When set to "HOT" the water trickles on and it takes like 10 minutes (or more?) to fill the tub for the wash. Of course the "COLD" flows like gangbusters... and when set to "WARM" the water is STILL cold, just not quite as cold as "cold".
I think it was the weekend (after I finish out this week, it will be 14 days straight and UGH, I'm more then ready for a day off!) I pushed the washer away from the wall, removed the fill hoses and looked inside the fill valve inlets. On the HOT side I couldn't even see the orifice the water flowed thru. So yesterday I decided to remove the inlet valve at the end of the day, take it home and see if there was a way to modify it to flow more hot.
Note on the "Don't use low water level" warning. I put that on there because there were 3 occasions I can remember when I walked into the "laundry room" to find water all over the floor around the washer. I was puzzled until the 3rd time when it was still washing and on the "low" setting. The "low" water level is SO LOW, that with the hyper agitation speed, water was splashing SO aggressively, it was going UP AND OVER the top of the outer tub and running down the inside of the cabinet! This post was last edited 04/11/2013 at 00:47 |
Post# 671893 , Reply# 1   4/11/2013 at 00:32 (4,025 days old) by RevvinKevin (Tinseltown - Shakey Town - La-La Land)   |   | |
Here is the inlet valve AFTER the modification. Cold is on the right and Hot the left. The orifice in the hot side was so small, the shaft of a "Q-Tip" (after removing all the cotton) would NOT fit in it.
I used a drill bit to make the orifice larger. As this is plastic, use gentle force as you are "drilling" and make sure not to go "too far". This post was last edited 04/11/2013 at 01:22 |
Post# 671894 , Reply# 2   4/11/2013 at 00:35 (4,025 days old) by RevvinKevin (Tinseltown - Shakey Town - La-La Land)   |   | |
Post# 671896 , Reply# 3   4/11/2013 at 00:37 (4,025 days old) by RevvinKevin (Tinseltown - Shakey Town - La-La Land)   |   | |
Post# 671897 , Reply# 4   4/11/2013 at 00:39 (4,025 days old) by RevvinKevin (Tinseltown - Shakey Town - La-La Land)   |   | |
The COLD water flow is still more than the HOT, but now the hot is much stronger than it was before!
This is filling with cold for the rinse. This post was last edited 04/11/2013 at 01:18 |
Post# 671899 , Reply# 5   4/11/2013 at 00:42 (4,025 days old) by RevvinKevin (Tinseltown - Shakey Town - La-La Land)   |   | |
Post# 671902 , Reply# 7   4/11/2013 at 01:28 (4,025 days old) by RevvinKevin (Tinseltown - Shakey Town - La-La Land)   |   | |
Hi Arthur,
Believe me I would never have this washer for personal use. Fortunately this belongs to my company so I don't have to worry about it.
And yeah... this "intermittent agitation".... UBER FAST....nothing.... uber fast.... nothing. Sounds like a great way to really tear up your delicate unmentionables, or what ever you would wash on a "gentle cycle".
Kevin |
Post# 671909 , Reply# 8   4/11/2013 at 03:44 (4,025 days old) by alr2903 (TN)   |   | |
LOL, Gentle ripped most of the backing off my bathroom rugs. Probably a combination of ice water rinse and that strange cycle. :-( |
Post# 671918 , Reply# 9   4/11/2013 at 06:35 (4,025 days old) by JeffG ()   |   | |
Thanks Kevin. Has anyone done a similar tutorial for a flow restricted Speed Queen valve? |
Post# 671922 , Reply# 10   4/11/2013 at 06:50 (4,025 days old) by Yogitunes (New Jersey)   |   | |
Great investigation work...and now your on to something....this alone is a big issue for many machines in addition to the temp control....
I have done the SQ's, at the advice of JohnL, it really is simple to do just like Kevin's work, granted he had to remove it and take it home, I did mine right on the machine, takes minutes, .....like Kevin said though, it's plastic, go gentle and not all the way thru... other valves have restrictors inside the valve itself, that are easy to remove....but these type restrict all water flow... I was working on a machine like this one, needed a simple drain hose.....the temp control you can't override.....Regular cycle, Hot wash, HI fill level.....60 seconds of HOT fill, and the rest is COLD...and you can't get past this.....how many people are not realizing they are not getting a full HOT fill, not even WARM?....I too would not have one of these machines... |
Post# 671931 , Reply# 11   4/11/2013 at 08:28 (4,025 days old) by RevvinKevin (Tinseltown - Shakey Town - La-La Land)   |   | |
Thanks Martin!
A couple notes for clarification:
~ I removed the inlet valve because: #1 when I removed the hoses I couldn't see the hole the water flowed through (no flash light), #2 I wanted to see how the back of the valve was constructed before I did anything and #3 I didn't have all the tools I needed at work (drill, drill bits, etc).
A WORD OF CAUTION: When you drill out the hole, plastic shavings can get in the valve, which can cause it to NOT close completely, meaning the water won't completely stop dribbling. This happened to me even though I tried to get all the shavings out. I had to "cycle" the valve (on and off) 6 times before the water would stop flowing completely. |
Post# 671937 , Reply# 12   4/11/2013 at 09:13 (4,025 days old) by Yogitunes (New Jersey)   |   | |
no need to explain Kevin....not everything we do is easy and simple....preceed with caution, always!
when I did the SQ, it was just luck of while drilling the shavings came towards me and easy to clean out, used a wet vac to be sure..... one thing Kevin, if I can ask.....whats that gray piece on the end of the valve which the hose attaches to?.....is that straight thru, or a restrictor inside?...looks like your getting good pressure, but could be better maybe?....just curious it's been mention as well, that you can just reverse the hot/cold hoses and the wires to get a warmer wash.......but Kevin's method gives an equal mix.... these factors can change according to incomming COLD water temps, by season, and the water heaters setting.....with both at full flow, a simple adjustment at the wall valves can suit your personal taste... |
Post# 671958 , Reply# 13   4/11/2013 at 10:50 (4,025 days old) by RevvinKevin (Tinseltown - Shakey Town - La-La Land)   |   | |
Martin, the photo above is the "before it was drilled out". After enlarging the hole the water sprayed hard against the side of the tub and splashed all over the place.
The "gray thing" on the valve outlet end is straight thru and not restricted. Though it does have some sorf of sensor or something as the "yellow" is where a plug connects. I don't know what it could be for because this is such a BOL machine, it does not have any sort of temp control (that I know of). |
Post# 671960 , Reply# 14   4/11/2013 at 10:57 (4,025 days old) by DADoES (TX, U.S. of A.)   |   | |
I don't know what it could be for because this is such a BOL machine, it does not have any sort of temp control (that I know of).It apparently does have ATC if there's a thermistor on the valve assembly. There may be a PCB in the control panel, follow the wires back to see ... and check a parts listing for the model. |
Post# 671965 , Reply# 15   4/11/2013 at 11:25 (4,025 days old) by RevvinKevin (Tinseltown - Shakey Town - La-La Land)   |   | |
Perhaps, but of all the loads I've run through this washer, I've not witnessed ANY sort of "active" control, cycling of the inlet valves or anything like that.
I just opened up the control panel again and the yellow wires from the thermistor go into the one large plug (with all the other wires) into the timer.
And..... the model# is WTW5200SQ0 |
Post# 672000 , Reply# 16   4/11/2013 at 15:09 (4,025 days old) by kb0nes (Burnsville, MN)   |   | |
Having a machine with electronic control of water temperature could actually be a benefit! Blasphemy you say??
Imagine this, by simply altering the feedback loop of the control it may be possible to add an easy way to dial in the temperature desired. It all depends on the nature of the sensor they use to sense the water temperature. If its a thermistor then the control is simply looking at resistance of the sensor to determine water temperature for blending. One could easily add series or parallel resistance, perhaps with a variable potentiometer, to game the system. Just think more of less infinite control of temperature! Of course altering the water restrictor in the valve may still help fill times seeing as how they throttle the hot flow so drastically. |
Post# 672009 , Reply# 17   4/11/2013 at 16:10 (4,025 days old) by RevvinKevin (Tinseltown - Shakey Town - La-La Land)   |   | |
Well yeah Phil, you smart ones with edjamakashuns that know how to do all that thermos-meister stuff by adding a parallel loop of potent-meter variables or series resistinators to make it an infinite sensor game control system!
I'd have no clue how to do all that stuff. This post was last edited 04/11/2013 at 17:22 |
Post# 672012 , Reply# 19   4/11/2013 at 16:18 (4,025 days old) by thefixer ()   |   | |
I believe I am correct on that. After searching around with the part number for that valve, I see it listed on some sites as "Bi-Metal water inlet valve". Eric |
Post# 672016 , Reply# 20   4/11/2013 at 16:31 (4,024 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 672020 , Reply# 21   4/11/2013 at 16:56 (4,024 days old) by thefixer ()   |   | |
Yep, didn't notice that temp select was part of the timer. That is a bare bones washer. How nice. Just leave that connector disconnected if you don't want your washer deciding how hot your hot water will be. Eric |
Post# 672025 , Reply# 22   4/11/2013 at 17:17 (4,024 days old) by RevvinKevin (Tinseltown - Shakey Town - La-La Land)   |   | |
Hi Eric,
Thanks for all the info... and yes you are correct. That is the correct wiring diagram DADoES, I just opened the console to look at it. I took photos, but cannot post them until I get home.
I guess the water temp from the little 30 gal electric water heater isn't hot enough to cause the bi-metal switch to trigger, because I've never witnessed it turning off or cycling the valve solenoids.
Kevin |
Post# 672057 , Reply# 23   4/11/2013 at 19:09 (4,024 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 672415 , Reply# 24   4/13/2013 at 09:15 (4,023 days old) by tecnopolis (Ocala/Dunnellon, Florida 34481)   |   | |
Post# 672416 , Reply# 25   4/13/2013 at 09:16 (4,023 days old) by tecnopolis (Ocala/Dunnellon, Florida 34481)   |   | |
Post# 672691 , Reply# 27   4/14/2013 at 11:18 (4,022 days old) by tecnopolis (Ocala/Dunnellon, Florida 34481)   |   | |
Post# 672744 , Reply# 28   4/14/2013 at 17:09 (4,021 days old) by yogitunes (New Jersey)   |   | |
