Thread Number: 45967
Shaft seal install gauges for KitchenAid KDI-19 |
Post# 672075 , Reply# 1   4/11/2013 at 21:00 (4,030 days old) by qsd-dan (West)   |   | |
Not sure about the third party parts, but when I installed new seal and impeller kits in my KDS 18 and 19 dishwashers with genuine Hobart parts, reusing the same shims in the same places with the new parts got the clearances right on the money.
The main clearance you want to the be concerned about is the wash impeller. The drain impeller just has a single fat washer underneath it. |
Post# 672116 , Reply# 2   4/11/2013 at 23:15 (4,030 days old) by OldKitchen (planet earth)   |   | |
Hobart no longer has the shaft seal kit available. Any trick to installing the seal? Do I just press it in? And it looks like the flat side goes down? |
Post# 672128 , Reply# 3   4/12/2013 at 01:03 (4,030 days old) by qsd-dan (West)   |   | |
The seal and impeller kit is still very much available from Hobart, they just don't know it, lol. Hobart sold off the consumer end of their appliances back in the mid 80's and practically nobody that works for Hobart anymore is aware of it. Their modern day SR-24 commercial dishwashers use the the same 435102 seal and impeller kit as the KD18 - KD20 dishwashers.
Correct. The dot indentations face up into the impeller housing. The soap/shampoo will cause LOTS of suds, so run a couple of cycles with an empty tub and some detergent since dishwasher detergent contains anti foaming agents.
Keep us updated.
Post# 672152 , Reply# 5   4/12/2013 at 07:33 (4,030 days old) by barcoboy (Canada)   |   | |
Post# 672171 , Reply# 6   4/12/2013 at 09:51 (4,030 days old) by Jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
Post# 672243 , Reply# 7   4/12/2013 at 15:42 (4,030 days old) by firedome (Binghamton NY & Lake Champlain VT)   |   | |
Post# 673970 , Reply# 10   4/19/2013 at 13:37 (4,023 days old) by OldKitchen (planet earth)   |   | |
I have the Hobart seal kit 00-435102- and it has the shim washers but does not have the gauges. Does the washer that fits on the underside of the impeller want to have the metal side exposed or the rubber side? |
