Thread Number: 46021
Whirlpool washer won't drain |
Post# 672700 , Reply# 1   4/14/2013 at 12:35 (4,027 days old) by DADoES (TX, U.S. of A.)   |   | |
Possibly the timer. Is this a direct-drive unit (providing your model number would clear up the details)? The two shafts on the motor both turn any time the motor is running, it can't spin just one or the other. The motor runs one direction for agitation, reverses for drain/spin. The pump runs all the time with the motor but turns the "wrong" direction during agitation so doesn't move the water out then. Reversing the motor is done by cams & contacts in the timer. |
Post# 672701 , Reply# 2   4/14/2013 at 12:38 (4,027 days old) by thefixer ()   |   | |
Could be a bad timer, timer contacts reverse polarity of power to the motor start winding between agitate/drain-spin to reverse direction of the motor. Need your washer model number to better help you out though. Eric |
Post# 672704 , Reply# 3   4/14/2013 at 12:45 (4,027 days old) by pierreandreply4 (St-Bruno de montarville (province of quebec) canada)   |   | |
Post# 672706 , Reply# 4   4/14/2013 at 12:49 (4,027 days old) by thefixer ()   |   | |
"Agitator works so motor must be good" |
Post# 672724 , Reply# 5   4/14/2013 at 15:23 (4,027 days old) by Sluffmeister ()   |   | |
Whirlpool model LSQ9564JQ0. Thanks for feedback! |
Post# 672747 , Reply# 7   4/14/2013 at 17:26 (4,027 days old) by Sluffmeister ()   |   | |
I removed motor and then reassembled. Now everything is working. I guess I had a loose wire or an intermittent timer issue. Not sure what changed, but it is working. Thanks much for the advice! |
Post# 672754 , Reply# 8   4/14/2013 at 17:45 (4,027 days old) by DADoES (TX, U.S. of A.)   |   | |
