Thread Number: 46097
Here's an odd one, a 1965 Lady K washer..... in avocado??? |
Post# 673623   4/17/2013 at 23:49 (3,997 days old) by RevvinKevin (Tinseltown - Shakey Town - La-La Land)   |   | |
Yes that is correct and here's the photo to prove it!
I picked up just over 3 weeks ago along with a '72 Lady K dryer.
I thought it was rather odd because I didn't think "avocado" was a color option in 1965 and I still don't believe it was. Well boys & girls, it turns out this 1965 model washer was built in late April of 1967 and that would explain it!
The seller said they've both been sitting in the garage for the last 20 years. OK, works for me.
Post# 673624 , Reply# 1   4/17/2013 at 23:52 (3,997 days old) by RevvinKevin (Tinseltown - Shakey Town - La-La Land)   |   | |
Closer-up of the control panel and those fabulous push buttons!
The fluorescent bulb needs to be replaced because after 8-10 minutes it starts trying to come on, but never quite makes it. This post was last edited 04/18/2013 at 00:19 |
Post# 673625 , Reply# 2   4/17/2013 at 23:53 (3,997 days old) by RevvinKevin (Tinseltown - Shakey Town - La-La Land)   |   | |
Post# 673627 , Reply# 3   4/17/2013 at 23:55 (3,997 days old) by tolivac (greenville nc)   |   | |
Roto-Flex agitator-also sort of looks like one of those rockets in the 50's Sci-fi movies. |
Post# 673628 , Reply# 4   4/17/2013 at 23:56 (3,997 days old) by RevvinKevin (Tinseltown - Shakey Town - La-La Land)   |   | |
Very clean and Gordon says this is a "low use" machine because it still has the ORIGINAL PUMP!
Yes the pump has a date stamp of "April 17 1967" on it! This post was last edited 04/18/2013 at 00:21 |
Post# 673629 , Reply# 5   4/17/2013 at 23:58 (3,997 days old) by tolivac (greenville nc)   |   | |
Base area looks very nice-they don't look that nice from around here-the humidity corrodes the equipment in the base of the machine. |
Post# 673632 , Reply# 6   4/18/2013 at 00:08 (3,997 days old) by RevvinKevin (Tinseltown - Shakey Town - La-La Land)   |   | |
So after unloading it I decide to test it. I fill it with water, it starts agitating and everything seems fine. I toss in a 5 "garage rags" which includes a couple towels and the agitation starts really laboring. After tightening the belt it's fine. I drain it, then spin out the rags and quit for the night.
Weekend comes and I decide to do my load of whites in this washer. I fill it with hot, add the clothes, detergent and with 5 - 6 minutes to go, I add some bleach.
It goes through the wash fine, stops and starts to drain. Within 30 seconds of starting to drain, this poor washer got sick and puked ALL of the hot soapy, bleachy water all over the garage floor and after looking to see what in the hell was going on, I realized there was nothing I could do to stop it.
The bottom of the filter blew out, allowing the full tub water and all of the filter beads to pour out onto the floor.
So, here is my call for help. Does anyone out there have one of these "beer keg" type of filters they don't need? I can't do anything with this washer without the filter.
The red arrow below shows where they filter blew out, right inside that ring. |
Post# 673634 , Reply# 7   4/18/2013 at 00:12 (3,997 days old) by RevvinKevin (Tinseltown - Shakey Town - La-La Land)   |   | |
Post# 673635 , Reply# 8   4/18/2013 at 00:13 (3,997 days old) by RevvinKevin (Tinseltown - Shakey Town - La-La Land)   |   | |
Post# 673636 , Reply# 9   4/18/2013 at 00:15 (3,997 days old) by RevvinKevin (Tinseltown - Shakey Town - La-La Land)   |   | |
Post# 673637 , Reply# 10   4/18/2013 at 00:17 (3,997 days old) by RevvinKevin (Tinseltown - Shakey Town - La-La Land)   |   | |
Post# 673643 , Reply# 11   4/18/2013 at 01:01 (3,997 days old) by PhilR (Quebec Canada)   |   | |
Post# 673663 , Reply# 14   4/18/2013 at 03:35 (3,997 days old) by retromania (Anderson, South Carolina)   |   | |
I thought the gold/amber colored agitators were from the 70's. Obviously I don't know my Lady Kenmore washer trivia. Learn something new all the time! |
Post# 673682 , Reply# 15   4/18/2013 at 07:21 (3,997 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
WOW I did not know that they kept making the 65 LKM that long either, I knew that they were continued through into 1966 as evidenced by the turquoise 1965 dryer [ made in mid 1966 ] that I picked up for Paul the other week.
Kevin I looked and did not have any extra SCFs for this machine, I know in all the years I have repaired washers I never had to replace this style filter, they were almost completely problem free, so I apparently never saved them or stocked new ones. You can bypass it by connecting the two hoses together, but if you wash really linty loads you may clog the water pump. Even though these nylon filters have metal clips around them they are heat welded together so they cannot be dissembled without cutting the thing apart. { I think that they used the clips to reinforce the connection between the two halves, heat welding was still fairly new technology in 1965 when the plastic bodied filter was introduced ]
Kevin the original style WP SCF will fit [ 1964- 1969 ] without changing any hoses and if you modify or change some hoses any rear mounted SCF from any WP or KM BD washer will work just fine. |
Post# 673689 , Reply# 16   4/18/2013 at 07:57 (3,997 days old) by gansky1 (Omaha, The Home of the TV Dinner!)   |   | |
Post# 673714 , Reply# 17   4/18/2013 at 12:07 (3,996 days old) by norgeway (mocksville n c )   |   | |
Thats my daily driver except mine is white! |
Post# 673950 , Reply# 19   4/19/2013 at 11:39 (3,995 days old) by roto204 (Tucson, AZ)   |   | |
Post# 673953 , Reply# 20   4/19/2013 at 11:59 (3,995 days old) by swestoyz (Cedar Falls, IA)   |   | |
Post# 673968 , Reply# 21   4/19/2013 at 13:27 (3,995 days old) by Kenmoreguy64 (Charlotte, NC)   |   | |
I do have to admit to having seen this machine before (someone...hmmm, not sure who THAT would be...pushed you toward getting these, LOL) but I was quite surprised to see the Avocado in a '65 LK. I should have remembered Don's in Minneapolis...
The Avocado 1965 KM 800 I had was built in 1968, so there's no tellin how long these were in production. The first version, 110.6504900, was superceded by five revisions. One of those added the 1966 style lid handle. Very cool machine, though I wish I knew what caused so many of those cabinets to turn gray. I think it can be improved with a buffer? Oh, btw - someone I know, lol, just found a NIB 84905 filter for a pending restoration of a '63 KM. If it isn't needed, it can be had. It wa$n't cheap but I was really glad to find it. G |
Post# 674000 , Reply# 22   4/19/2013 at 15:57 (3,995 days old) by Yogitunes (New Jersey)   |   | |
Post# 674011 , Reply# 23   4/19/2013 at 16:14 (3,995 days old) by Kenmoreguy64 (Charlotte, NC)   |   | |
Actually, the simplest thing to do for a filter for now is to take the working filter out of the 1963 KM 70, Kevin.
When I worked on the '63 last April, the filter was already bypassed, and just sitting there. I got some large lint clods out of it, and un-bypassed it. Whoever did that bypass cut at least one of the hoses, which I had to mend. Instead of doing a repeat of that, if you want to swap the filter for a while, that'd be the easiest thing. Since the 63 70 needs its centerpost POR15'd BADLY anyway, and we need to solve that pesky leak, its not good for much right now, so the filter might as well be used in the '65. I think your washer service buddy we visited who had the stach of old parts has one of these, but that's just a hunch. Gordon |
Post# 674018 , Reply# 24   4/19/2013 at 16:47 (3,995 days old) by RevvinKevin (Tinseltown - Shakey Town - La-La Land)   |   | |
Thank you everyone for all of your great comments.
Thank you Gordon for you filter swap suggestion, I didn't think of that, great idea!
Ben: I don't know that this control panel lens is discolored from ciggy smoke, but I'll have to find some of that stuff and try it out.
I find it really interesting that for what ever reason, Kenmore continued to build and sell "A" model year washer a year or two or even three years AFTER said model year! Especially when they brought out their NEW or updated model each and every year!
Kevin |
Post# 674445 , Reply# 26   4/21/2013 at 14:16 (3,993 days old) by shawn (Waterford Ct)   |   | |
Just how does this filter work? Thanks for any info. |
Post# 674447 , Reply# 27   4/21/2013 at 14:21 (3,993 days old) by mrb627 (Buford, GA)   |   | |
Post# 674459 , Reply# 28   4/21/2013 at 14:58 (3,993 days old) by bendixmark (Winchester Mass)   |   | |
I know that machine well and have never seen it here.My sisters boyfriends family had one and I sold a few at one time.That machine had a narrow belt,had the soap dispenser and is a machine I would love to have for my collection. |
Post# 674464 , Reply# 29   4/21/2013 at 15:12 (3,993 days old) by RevvinKevin (Tinseltown - Shakey Town - La-La Land)   |   | |
James: THANKS much!
TIM (Shawn): The pump is pumping anytime the motor is running. During agitation water is pumped continuously from the bottom of the tub, through the filter and back in to the bub through a port on the side. When the washer is draining the flow through the filter is reversed, which is supposed to flush any collected lint down the drain.
I hope this helps!
On Malcoms question: Where is Gordon when we need him? OOOH GORDON!?!?
Kevin |
Post# 674497 , Reply# 30   4/21/2013 at 17:15 (3,993 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Your explanation is correct Kevin except the filtered water renters the tub at the bottom and the unfiltered water enters the water system through the side check valve.
1970ish KM washer and dryer with the timer dials only exposed at the top behind a window. My business partner Jason has a white pair of these [ electric dryer ] that he and restored to like new mechanical condition a couple years ago [ they look great also ] This washer has the regular wide belt, Jason may be willing to sell these if the price is right, let me know. Jason did a post here several years ago featuring this washer that we photo-shopped a orbital Kelvinator agitator into. |
Post# 674502 , Reply# 31   4/21/2013 at 17:22 (3,993 days old) by RevvinKevin (Tinseltown - Shakey Town - La-La Land)   |   | |
Post# 674886 , Reply# 32   4/23/2013 at 06:08 (3,992 days old) by turquoisedude (.)   |   | |
Post# 675097 , Reply# 33   4/24/2013 at 04:47 (3,991 days old) by alr2903 (TN)   |   | |
Malcom is this the one ? #2 Harvest pair.(second set down) alr |
Post# 675115 , Reply# 34   4/24/2013 at 06:59 (3,991 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Mark you were correct that this 2nd version of this style washer did have the narrow Quite PAC drive belt, the earlier ones we have only have an incandescent dial light and no detergent dispenser. These later 1973 machines were very good looking machines, I especially liked the way that the control consoles were color matched to the cabinet color. |
Post# 675153 , Reply# 35   4/24/2013 at 10:33 (3,991 days old) by Kenmoreguy64 (Charlotte, NC)   |   | |
The Tawny Gold 800 set was pretty close to TOL for the time, though they are 1972 models. I think these had the gold Vari-Flex since they are not LKs, whereas the Lady K had the white Vari-Flex.
This console is actually dimensionally the same as the console on the 1972 Kenmore 700, though the 700 had an incandescent light not the flourescent. I too like the console and the color-match feature, however I've never been a fan of the windows. The Kenmore 800 version doesn't seem to be around much these days, though I think Dick_S has or had one (chech his photo album). I saw a few of these in my travels with Kenmores in the 1990s, but have seen far more of the 700 here on the site. Here's a picture of a dryer I have in the original window style. This is a 1970 model. It is available should anyone want it, I'd love to find it a home. Gordon This post was last edited 04/24/2013 at 11:09 |
Post# 675169 , Reply# 36   4/24/2013 at 11:14 (3,990 days old) by mrb627 (Buford, GA)   |   | |
