Thread Number: 46186
Frigidaire WO-65-2 rescued |
Post# 674806   4/22/2013 at 21:57 (4,014 days old) by gansky1 (Omaha, The Home of the TV Dinner!)   |   | |
Ben found a CL listing in St. Joseph, MO for a Frigidaire washer and found it was a WO-65-2! We had family in town this weekend but, when the pulsator beckons... I picked it up Sunday morning, only 1.75 hours from me. The poor dear was pretty filthy but seemed to perk up a bit and smile when I gave her a first wipedown. The first step in restoration is to bring back a little dignity!
It's in lovely condition, no oil leaks, motor shaft and pump are free and easy to turn. I tried a quick test but the motor capacitor is bad. Rather than stab at each individual issue, I'm going to put the time into a full-on restore so will try to get into it this weekend. |
Post# 674808 , Reply# 1   4/22/2013 at 21:58 (4,014 days old) by gansky1 (Omaha, The Home of the TV Dinner!)   |   | |
Post# 674810 , Reply# 2   4/22/2013 at 21:59 (4,014 days old) by gansky1 (Omaha, The Home of the TV Dinner!)   |   | |
Post# 674818 , Reply# 3   4/22/2013 at 22:08 (4,014 days old) by alr2903 (TN)   |   | |
Congrats Greg, that is a very nice save. arthur |
Post# 674819 , Reply# 4   4/22/2013 at 22:09 (4,014 days old) by jetaction (Minneapolis)   |   | |
Post# 674842 , Reply# 5   4/23/2013 at 00:09 (4,014 days old) by Northwesty (Renton, WA)   |   | |
Hope the restoration is a smooth one (still using those 51's) |
Post# 674885 , Reply# 6   4/23/2013 at 06:05 (4,014 days old) by turquoisedude (.)   |   | |
Post# 674889 , Reply# 7   4/23/2013 at 06:19 (4,014 days old) by Tomturbomatic (Beltsville, MD)   |   | |
I see the original pulsator was replaced with a Three Ring Pump Agitator. Pretty neat. |
Post# 674912 , Reply# 8   4/23/2013 at 09:01 (4,014 days old) by swestoyz (Cedar Falls, IA)   |   | |
Post# 674916 , Reply# 9   4/23/2013 at 09:22 (4,014 days old) by Unimatic1140 (Minneapolis)   |   | |
Post# 674931 , Reply# 10   4/23/2013 at 11:08 (4,014 days old) by revvinkevin (Tinseltown - Shakey Town - La-La Land)   |   | |
Post# 674953 , Reply# 11   4/23/2013 at 12:33 (4,013 days old) by Jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
Post# 674956 , Reply# 12   4/23/2013 at 12:42 (4,013 days old) by retromania (Anderson, South Carolina)   |   | |
love...love...love...old vintage appliances!!! |
Post# 674969 , Reply# 13   4/23/2013 at 13:58 (4,013 days old) by goatfarmer (South Bend, home of Champions)   |   | |
Post# 675034 , Reply# 14   4/23/2013 at 19:26 (4,013 days old) by appnut (TX)   |   | |
Post# 675067 , Reply# 15   4/23/2013 at 22:15 (4,013 days old) by lebron (Minnesota)   |   | |
Post# 675121 , Reply# 16   4/24/2013 at 07:32 (4,013 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Great save Greg, it is amazing how many of these have turned up over the years, I got the same machine from my cousins about 15 years ago and it has only had minor problems, it seems to me by the time Frigidaire built the WO-65-2 model they had improved a lot of items and the Unimatic Mechanism was really about as good as it was going to get. It also seems that a lot of these early Unimatics were often put aside for newer machines with little often really wrong with them, people that could afford this washer in the first place often were in a better position to buy a newer fancier machine than most consumers. And many other users just got tired of the tangled wrinkled clothing and the vibration problems that these washers sometimes had.
I really like this washer for washing really dirty loads of cleaning towels, white socks, underwear, etc., these loads I always wash hot and add LCB near the end of the wash cycle. And while this was the first FD model to have the overflow rinse instead of two deep rinses I converted mine back by using an older timer and timer dial because the two rinses do a much better job rinsing away the LCB smell that the overflow rinse does. The overflow rinse was a good idea for many users as it largely solved problems of soap scum residue on clean clothing when these washer were used with soap or in hard water areas. |
Post# 675353 , Reply# 18   4/25/2013 at 01:46 (4,012 days old) by stan (Napa CA)   |   | |
Post# 676355 , Reply# 20   4/30/2013 at 00:50 (4,007 days old) by rollermatic (cincinnati)   |   | |
Post# 677530 , Reply# 21   5/5/2013 at 19:47 (4,001 days old) by gansky1 (Omaha, The Home of the TV Dinner!)   |   | |
Post# 677531 , Reply# 22   5/5/2013 at 19:51 (4,001 days old) by gansky1 (Omaha, The Home of the TV Dinner!)   |   | |
Never come across this before, a previous servicer had tapped the soft pot metal pump impeller around the screw to keep the screw from loosening and causing loose impeller syndrome and acute fan chatter.
This is a viable solution while replacement parts are widely available, but that is no longer the case for a 60 year old washer so I won't be doing it, but thought it was interesting. I simply cut away the extra pot metal with a Dremel. This washer has sat dry for many years so the parts are coming apart pretty easily. |
Post# 677534 , Reply# 23   5/5/2013 at 19:58 (4,001 days old) by gansky1 (Omaha, The Home of the TV Dinner!)   |   | |
Current state of the workbench. The transmission parts are ready for cleaning, the pump gasket is cut and ready, water valve rebuilt. A long process, but it will be worth it to have a very reliable washer in the end.
I will put a new clutch torque spring in, a new oil pump and seal assembly and probably a new (or better) water pump impeller. More to come! |
Post# 677569 , Reply# 24   5/5/2013 at 23:14 (4,001 days old) by golittlesport (California)   |   | |
Post# 677589 , Reply# 25   5/6/2013 at 01:55 (4,001 days old) by Jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
thorough work Greg, as always. But how did you cut such a nice round pump gasket?? It looks original. I wonder if it was a run of them sold in the MidWest.
You splurged on the royal purple - good on you! You won't regret how smooth it will run after 5-7 washes are done and its worked all in! Stuff is amazing in my GE , Bendix Duo's & Charcoal machines.
Those oil pump kits are scarce as hens teeth!!
Are you gonna change out the spin bearing now that its all apart??
Post# 677598 , Reply# 26   5/6/2013 at 06:03 (4,001 days old) by toploader55 (Massachusetts Sand Bar, Cape Cod)   |   | |
Post# 677612 , Reply# 27   5/6/2013 at 07:39 (4,001 days old) by gansky1 (Omaha, The Home of the TV Dinner!)   |   | |
I will change the spin bearing but the only tool I don't have is the bearing removal tool! Robert & Fred will bring that with them next week and I'll have him inspect my work before we fire it back up.
Jon, it's easy to cut the pump gasket from new cork when the pump is apart as the templates are right there. I used the cover plate for the outside cut and the impeller for the inside cut. |
Post# 677618 , Reply# 28   5/6/2013 at 07:45 (4,001 days old) by Jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
Post# 677658 , Reply# 29   5/6/2013 at 11:49 (4,000 days old) by swestoyz (Cedar Falls, IA)   |   | |
Yet another broken torque spring! They do make nice paper weights. ;)
I did some digging on Royal Purple's website, and they now make a synthetic version of the Non-detergent SAE 30 Air Compressor oil - 01513 Synfilm Recip 100. This would be the synthetic comparison to the standard Air Compressor oil we've been using in the Unimatic mechanisms for years. Now if they only made an SAE 60 and SAE 70 versions for the belt drive Whirlpool/Kenmore and Maytag transmissions.
I'm not an fluid engineer, but I'd be curious to know if the variation of oil viscosity would cause the oil pump efficiency to change. I know that automotive guys mention that seals can be more leak prone with synthetics.
Ben CLICK HERE TO GO TO swestoyz's LINK This post was last edited 05/06/2013 at 12:08 |
Post# 677681 , Reply# 30   5/6/2013 at 14:31 (4,000 days old) by rickr (.)   |   | |
Post# 677703 , Reply# 31   5/6/2013 at 15:43 (4,000 days old) by gansky1 (Omaha, The Home of the TV Dinner!)   |   | |
Post# 677734 , Reply# 32   5/6/2013 at 17:00 (4,000 days old) by kb0nes (Burnsville, MN)   |   | |
since there are no religious or political discussions here, but why Royal Purple?
Any oil today you put in that transmission is scads better then lubricants of the 50's. I've been an oil geek since the 80's with total belief in synthetics, I even send out used oil for analysis at least once a year. I've just never seen the RP people back up their claims... Awesome looking restoration Greg, looking forward to seeing/hearing a video of it running! |
