Thread Number: 46465
GE Dryer Drum Bearing Grease
Post# 677992   5/7/2013 at 17:01 (4,000 days old) by DigAPony ()
Anyone, familiar the correct grease/lube to use, or not use, on the rear nylon drum bearing in a GE dryer: www.appliancepartspros.com/ge-bea...
The factory papers found in the dryer control panel area calls for GE part # WE25X94 (Silic oil) on the drum bearing, drum slides and felt seals, # WE25X46 grease on the idler pulley.
No doubt, if these can be found they will cost a small fortune from GE.
What are some suitable substitutes?
