Thread Number: 46467
Easy Spin Drier in Rhode Island |
Post# 678024   5/7/2013 at 19:53 (4,004 days old) by toploader55 (Massachusetts Sand Bar, Cape Cod)   |   | |
Post# 678025 , Reply# 1   5/7/2013 at 19:54 (4,004 days old) by toploader55 (Massachusetts Sand Bar, Cape Cod)   |   | |
Post# 678026 , Reply# 2   5/7/2013 at 19:55 (4,004 days old) by toploader55 (Massachusetts Sand Bar, Cape Cod)   |   | |
Post# 678038 , Reply# 3   5/7/2013 at 20:27 (4,004 days old) by kenmore58 (Rhode Island)   |   | |
Post# 678157 , Reply# 4   5/8/2013 at 12:23 (4,004 days old) by mickeyd (Hamburg NY)   |   | |
You don't usually see a control panel in such mint condition on a 60 year old Easy! This is a beauty.
Figures it's for sale in an antique shop. This is the faucet-less version, really sleek and clean styling if that's what you're looking for. The rinsing is similar to the early Hoover: you need a hose to either spin rinse or flush rinse. The Easy flush has two versions and they're both interesting. In one version, you fill the spin tub up to the rim while the load is still loose before the first spin. Then you flush (fast drain) 2/3's of the water. Then you close the drain, and engage the spin lever. The load sloshes around, then you open the drain for full extraction. Repeat as needed. This model has the famous ceramic fist in the spinner rather than the tapered rinse cone with 1500 small holes for the needle jet sprays. There are powerful, dramatic machines, Eddie. Maybe some day you'll catch the Easy Bug. Thanks for putting it up--what fun to see! |
Post# 678180 , Reply# 5   5/8/2013 at 15:50 (4,004 days old) by laundromat (Hilo, Hawaii)   |   | |
Post# 678181 , Reply# 6   5/8/2013 at 15:50 (4,004 days old) by laundromat (Hilo, Hawaii)   |   | |
Post# 678465 , Reply# 8   5/9/2013 at 22:11 (4,002 days old) by NewVista58 (Northern NJ)   |   | |
