Thread Number: 46570
Vintage 1975ish Caloric Dishwasher |
Post# 679027   5/12/2013 at 21:21 (3,994 days old) by ovrphil (N.Atlanta / Georgia )   |   | |
Post# 679051 , Reply# 1   5/13/2013 at 00:29 (3,994 days old) by rp2813 (Sannazay)   |   | |
Post# 679076 , Reply# 2   5/13/2013 at 04:59 (3,994 days old) by appnut (TX)   |   | |
Actually these performed better than the comparable Kenmore because the Hot Water Scrub cycle was actualy temp-delayed water heat while water circulated main wash and helped tremendously. 150 degree sani wash was simply the final rinse heated to that where as the other button did heat the main wash to that too.
Post# 679086 , Reply# 3   5/13/2013 at 05:58 (3,994 days old) by alr2903 (TN)   |   | |
For D&M to label the Caloric button "warm dry" is misleading if it was anything like the Kenmore model that was labeled "hot dry" an extremely accurate description. |
Post# 679091 , Reply# 4   5/13/2013 at 08:30 (3,994 days old) by countryguy (Astorville, ON, Canada)   |   | |
Post# 679100 , Reply# 5   5/13/2013 at 10:10 (3,993 days old) by Tomturbomatic (Beltsville, MD)   |   | |
The first is no water heating while the second is no drying. |
Post# 679178 , Reply# 6   5/13/2013 at 19:43 (3,993 days old) by whirlykenmore78 (Prior Lake MN (GMT-0500 CDT.))   |   | |
NO! YUCK! They are poorly built, noisy and prone to rusting out and leaking. The water that dosen't leak out has to be sucked out with a turkey baster when the damn thing dosen't drain. My folks had a 75 Caloric and it was a complete trainwreck. The only good thing about these clunkers is that they can be torn out and replaced with a usefull DW. WK78 |
