Thread Number: 4664
A108 |
Post# 104421   1/18/2006 at 12:08 (6,670 days old) by awooff (Peoria, Illinois)   |   | |
I recently acquired a Maytag A108 and it works great but, the basket sits about 1/2 inch off on one side which is no big deal but with a full load, I believe this is making the load spin in a slight oval, and not spin as smoothly as this machine could. I read somewhere (cant remember where) that it is quite easy to realign the tub on these. I've never taken a maytag apart but im quick on picking up on things like this, just inquiring on a quick lesson. |
Post# 104445 , Reply# 1   1/18/2006 at 15:03 (6,669 days old) by goatfarmer (South Bend, home of Champions)   |   | |
Unplug the machine,and remove the two screws near the bottom of the front panel.Pull the bottom towards you,and unhook it from the top. There are I think 3 springs which help center the transmission assy.They go from the base of the washer,to the supporting arms on the trans assembly.Make sure none of them are missing or broken.If they seem OK,it's possible the dampening pads are worn,and need replaced. kennyGF |
