Thread Number: 4665
Dishwasher in Central Illinois? |
Post# 104423   1/18/2006 at 12:16 (6,670 days old) by awooff (Peoria, Illinois)   |   | |
Post# 104565 , Reply# 2   1/18/2006 at 23:55 (6,669 days old) by awooff (Peoria, Illinois)   |   | |
Post# 104589 , Reply# 3   1/19/2006 at 06:13 (6,669 days old) by christfr (st louis mo)   |   | |
hey there awooff, this is chris im in st louis..dont have any to get rid of right now but i hit the sales almost every weekend..what are you looking for? any old dishwasher? do you like built ins or portables? those are usually easy to find. mail me sometime if you like at rombachcc@juno.com i send you a few pics or if i remember ill post some this eve
Post# 104590 , Reply# 4   1/19/2006 at 06:14 (6,669 days old) by christfr (st louis mo)   |   | |
Post# 104629 , Reply# 5   1/19/2006 at 10:35 (6,669 days old) by awooff (Peoria, Illinois)   |   | |
Chris, I sent you an email on this too- I'm interested in years around 1970 -1985 Portable or built in. Specifically looking for a Maytag or KA or a upper end Whirlpool/Kenmore with the Power Clean/Ultrawash modules. Maybe you know the answer to this..........I've been trying to find a user guide to a Maytag of those years to find out if all or some have a heated wash/and or rinse. Earlier someone posted some model numbers for a maytag, but the maytag website wants a 10 digit or the .pdf doesn't exists. I've searched elsewhere on the web but no luck. Also, looking for a Fridgidaire Spray Tube, or the next 5 or so year models after this. You may know the models I'm talking about, the ones with the big black dial on the upper right hand corner that were made by GM, I believe most of these also had a toggle switch for rinse hold/regular cycles. One of these would have to be a portable. Also looking for a 1-18 in good working condition. Thanks Aaron Wooff |
Post# 104672 , Reply# 6   1/19/2006 at 15:31 (6,669 days old) by gansky1 (Omaha, The Home of the TV Dinner!)   |   | |
Maytag only offered the Sani-Cycle on their top of the line (TOL) models until the early 80's when the TOL and next model down offered the option. My WU-601 dishwasher has the sani cycle, it is a double wash cycle with a final rinse heated to 155-160F. The heater is energized during most circulation periods of the cycle, but only to maintain water temp, not specifically boosting temps to a pre-determined level as in the sani-rinse.
Post# 104676 , Reply# 7   1/19/2006 at 16:44 (6,668 days old) by swestoyz (Cedar Falls, IA)   |   | |
Post# 104707 , Reply# 8   1/19/2006 at 20:52 (6,668 days old) by gansky1 (Omaha, The Home of the TV Dinner!)   |   | |
Post# 104735 , Reply# 9   1/19/2006 at 22:57 (6,668 days old) by awooff (Peoria, Illinois)   |   | |
gansky1 That machine is beautiful, im jealous, but Im confused ....also its been a 16 hr day too What your saying is most model maytags of that era have no water heating being done by the machine, or are all the machines heating the water (sani or not) continuously!.? I guess what Im asking is If you'd have a lower end model w/no sani cycle, is the machine heating any water at any given time? |
Post# 104739 , Reply# 10   1/20/2006 at 00:06 (6,668 days old) by gansky1 (Omaha, The Home of the TV Dinner!)   |   | |
Yes, the heater is on during all wash and rinse circulation phases but will continue to run through the cycle time regardless of the water temperature. The sani-rinse cycle actually stops the timer until the proper temp is reached. The TOL model has a China/Crystal cycle that does not use the heater at all, washing, rinsing or drying.
Post# 104804 , Reply# 11   1/20/2006 at 12:35 (6,668 days old) by duetboy ()   |   | |
I'd love to find some old top loader portables to go along with my GE PowerShower! Keep me in mind if you're somewhere in the OK, MO, KS, TX, TN area guys! jeff |
Post# 104815 , Reply# 12   1/20/2006 at 14:51 (6,668 days old) by awooff (Peoria, Illinois)   |   | |
I've got a PowerShower too, two things I dont like about it, (actually 3 but I can live w/o water filtering if I have too) I dont like that there is no insulation of any kind, the inside of the DW is the same sheet of metal that is exposed to the outside of the DW. Also lacks a heated wash. Mine needs a new fill valve, as I get a loud buzzing sound when the water valve cuts off (currently the faucet must be turned off then on again after each fill). On a positive note, it seems these older water guzzeler DW's seem to produce better results with hard water than the newer DW's.....anyone have an idea as to why? |
