Thread Number: 46779
Hotpoint twin tub double trouble! |
Post# 681392   5/28/2013 at 15:21 (3,956 days old) by sesteve (London, UK)   |   | |
Post# 681393 , Reply# 1   5/28/2013 at 15:24 (3,956 days old) by sesteve (London, UK)   |   | |
Post# 681394 , Reply# 2   5/28/2013 at 15:27 (3,956 days old) by sesteve (London, UK)   |   | |
Post# 681395 , Reply# 3   5/28/2013 at 15:28 (3,956 days old) by sesteve (London, UK)   |   | |
Post# 681396 , Reply# 4   5/28/2013 at 15:31 (3,956 days old) by sesteve (London, UK)   |   | |
Post# 681397 , Reply# 5   5/28/2013 at 15:33 (3,956 days old) by sesteve (London, UK)   |   | |
Post# 681399 , Reply# 6   5/28/2013 at 15:42 (3,956 days old) by sesteve (London, UK)   |   | |
That revealed a weakness with these machines in that you can't drain the tub like you can in the Hoover (by lowering the drain hose) without the wash pump running. Anyway, I got I up and running again and was making good progress until the electric kept tripping. A screw holding the wash deck on was missing and this was dripping water onto the motor coils which in turn stopped the spin motor from starting once I dried the inside enough to keep the electric on. Happy to report that it is now all sorted out.
Here it is all up and running and ready for a good clean. Will have to get round to doing some videos next time it is out of the shed S |
Post# 681419 , Reply# 7   5/28/2013 at 17:45 (3,956 days old) by optima (Cumbria England)   |   | |
Post# 684279 , Reply# 8   6/17/2013 at 17:11 (3,936 days old) by sesteve (London, UK)   |   | |
Thanks Craig. I've had great fun washing with this twinny which is down in the kitchen so I've been using it for the last few weeks.
Anyway before I got stuck into the Quartz issues, I decided to drag the 9404 out of the shed seeing as I'd sourced a second hand wash pump. However, on close inspection I think I need to look at the wash gearbox before I add oil as there is quite a bit of play in the drive shaft. Are the gearboxes sealed units or can you take them apart like you can on the top loaders? I have a service manual for the machine as a whole but it looks quite time consuming to take is out as you have to take the cabinet off so I gave up. |
Post# 684287 , Reply# 9   6/17/2013 at 18:18 (3,936 days old) by optima (Cumbria England)   |   | |
Post# 684630 , Reply# 10   6/19/2013 at 16:08 (3,934 days old) by sesteve (London, UK)   |   | |
