Thread Number: 46884
who thinks on modern washers of today the temp option hot wash with warm rinse shloud be offerd |
Post# 682608   6/5/2013 at 17:49 (3,971 days old) by pierreandreply4 (St-Bruno de montarville (province of quebec) canada)   |   | |
hello to all aw members who thinks that on modern top load washers of today and modern frontload washer of today as well as the warm wash warm rinse water temp there should also be the option of a hot water wash with warm rinse option as sometime not all cold water rinse can be efficiant because sometime i have notice this on my old direct drive inglis superbII direct drive washer when the cycle was complete i had to set it on another full cycle to fully remove suds from the clothes in warm water?see pic of this old belt drive top load washer for exemple.
Post# 682666 , Reply# 1   6/5/2013 at 23:53 (3,970 days old) by tolivac (greenville nc)   |   | |
Yes-the warm rinse should still be available. |
Post# 682669 , Reply# 2   6/6/2013 at 01:02 (3,970 days old) by arbilab (Ft Worth TX (Ridglea))   |   | |
Post# 682673 , Reply# 3   6/6/2013 at 04:22 (3,970 days old) by chestermikeuk (Rainhill *Home of the RailwayTrials* Merseyside,UK)   |   | |
Post# 682732 , Reply# 6   6/6/2013 at 09:39 (3,970 days old) by golittlesport (California)   |   | |
Post# 682773 , Reply# 7   6/6/2013 at 15:15 (3,970 days old) by jerrod6 (Southeastern Pennsylvania)   |   | |
I also doubt this will happen since most regular wash cycles are now using 105F and less as the hot temperature. |
Post# 683281 , Reply# 11   6/9/2013 at 19:33 (3,966 days old) by pierreandreply4 (St-Bruno de montarville (province of quebec) canada)   |   | |
i know for a fact that in the case of on older top load direct drive washer in the case of my 1993 inglis superbII washer if i use a liquid detergent i had no trouble with a cold rinse but if the detergent is a powder then i was require to restart a full cycle so that the warm water would remove the suds in the fabric but other wise it was a great washer that only had 2 minor repairs 1 in 1996 a new motor and in 1998 a new timer if it was not for the agitator breaking i would still have this set today rather than my duet set
Post# 683354 , Reply# 12   6/10/2013 at 10:52 (3,966 days old) by dj-gabriele ()   |   | |
Totally second what Matt/Hoover1100 said! Plus I wouldn't wash in an LG machine regardless as they're simply "laudry offenders" with poor performances and quality :S |
Post# 684739 , Reply# 14   6/20/2013 at 14:59 (3,956 days old) by whirlcool (Just North Of Houston, Texas)   |   | |
Since I have a severe detergent allergy now we rinse everything with warm water. I want to ensure that I get every bit of soap out of the clothing. Clothes seem to rinse better in warm water rinse anyway. Towels rinsed in warm water and dried on the "gentle/knits" setting come out way softer. |
Post# 684778 , Reply# 15   6/20/2013 at 19:58 (3,955 days old) by pierreandreply4 (St-Bruno de montarville (province of quebec) canada)   |   | |
Post# 684874 , Reply# 17   6/21/2013 at 11:14 (3,955 days old) by logixx (Germany)   |   | |
Miele's AllWater washers allow the option to take in warm water for the wash and the rinse. Warm rinses take place on Cotton cycles with a 50C or above main wash and Perm Press with a 40C+ wash. The manual says,warm rinses save ten percent in water. Probably because a warm rinse does a better job removing detergent.
RE:drying. Well, many washer/dryers run a Thermospin during the drying cycle to get even more water out of the clothes. I guess heated fibers release water more easily than cold ones. |
Post# 684902 , Reply# 18   6/21/2013 at 14:48 (3,955 days old) by logixx (Germany)   |   | |
Post# 711906 , Reply# 19   10/28/2013 at 15:28 (3,826 days old) by maytaga806 (Howell, Michigan)   |   | |
Post# 711912 , Reply# 20   10/28/2013 at 15:42 (3,826 days old) by frontloaderfan (Merrimac valley, MA)   |   | |
Post# 711915 , Reply# 21   10/28/2013 at 15:55 (3,826 days old) by gorenje (Slovenia)   |   | |
Hello,
well, these are just "my two cents" or a momental thinking about this argument... When I wash something in my front loader at high temperature (for example 95°C or 60°C) the laundry itself and the tub are so hot that the first rinse is consequently a warm rinse indeed. And than the following are cold rinses. Well, this applies only for the mentioned hot washes and is not so when the wash water is cold. ... I was just thinking out loud :) Ingemar |
Post# 711929 , Reply# 23   10/28/2013 at 16:31 (3,826 days old) by whirlcool (Just North Of Houston, Texas)   |   | |
I wish they would put a "Normal" & "Energy Star" switch on washers. Let the end user be the one to decide if they want to be green to the point of uselessness. In normal mode the washer would have all the water use and functionality of the washers we had in the 70's. In Energy Star mode you'd get the max savings. |
Post# 711930 , Reply# 24   10/28/2013 at 16:34 (3,826 days old) by Washman (o)   |   | |
Post# 712004 , Reply# 25   10/29/2013 at 00:25 (3,825 days old) by tolivac (greenville nc)   |   | |
Amen-Iam for the USER and OWNER deciding what type of energy loads he wants-get the go'vt out of it-get them out of my laundry room,kitchen,car,and so forth--lets go back to indivudual liberties--let YOU decide!!!! |
Post# 712069 , Reply# 26   10/29/2013 at 09:51 (3,825 days old) by JeffG ()   |   | |
+1 on the last few comments. 95% of what we wear these days is cotton, and cold water (for either washing or rinsing) stinks for cotton. Sometimes literally. |
Post# 712072 , Reply# 27   10/29/2013 at 10:45 (3,825 days old) by logixx (Germany)   |   | |
Post# 712092 , Reply# 28   10/29/2013 at 13:13 (3,825 days old) by frontloaderfan (Merrimac valley, MA)   |   | |
