Thread Number: 46986
For sale in VT: Maytag 35 lb commercial washer |
Post# 683776   6/13/2013 at 12:53 (3,967 days old) by frontloaderfan (Merrimac valley, MA)   |   | |
Damn, I wish I had a truck to go get this....
CLICK HERE TO GO TO frontloaderfan's LINK on Maine Craigslist |
Post# 683781 , Reply# 1   6/13/2013 at 14:43 (3,967 days old) by revvinkevin (Tinseltown - Shakey Town - La-La Land)   |   | |
Post# 683787 , Reply# 3   6/13/2013 at 15:59 (3,967 days old) by whirlykenmore78 (Prior Lake MN (GMT-0500 CDT.))   |   | |
Post# 683795 , Reply# 4   6/13/2013 at 17:47 (3,967 days old) by Yogitunes (New Jersey)   |   | |
wouldn't there need to be a 3 phase power installed for this to run in a home environment?......
I found a big load dryer from a hotel laundry once....timer settings for drying and cooling.....a gas unit....but couldn't get it thru the doors into the house....what rotten luck....but it did operate off regular 110... |
Post# 683800 , Reply# 5   6/13/2013 at 18:20 (3,967 days old) by kb0nes (Burnsville, MN)   |   | |
Tag shows it as single phase 240v service. An inverter or phase converter isn't too hard to rig up if one really wants to run something 3-phase at home in any case.
Seems to have a slow spin speed. The brochure I have for Huebsch soft mount machines shows their 35lb class machine spinning at 1000RPM. |
Post# 683828 , Reply# 6   6/13/2013 at 23:57 (3,967 days old) by tolivac (greenville nc)   |   | |
Just have an electrician wire a 15-20A 240V outlet in your homee to run the machine.The nameplate indicates the machine is for single phase 240V-should be fused for 20A.Bet it would work on a standard 15A 240V line. |
Post# 683887 , Reply# 7   6/14/2013 at 14:35 (3,966 days old) by mrb627 (Buford, GA)   |   | |
Post# 683902 , Reply# 9   6/14/2013 at 15:54 (3,966 days old) by kb0nes (Burnsville, MN)   |   | |
I suppose one could construct a heavy pedestal to bolt it to. But with a machine this size you'd likely need concrete to get enough weight so it would be like pouring a slab. The drainage requirements would be easier, just need a big transfer pump.
The better solution would be to get a big commercial soft mount machine. Huebsch has a line from 18 to 165 lb. They all spin quite a bit faster then this machine also. I'd have to bet the cost for the soft mount is a lot higher though. I got a quote for an 18lb machine and it was over $4000! They sure are attractive though... |
