Thread Number: 46987
85 maytag washer spin noise |
Post# 683777   6/13/2013 at 12:57 (3,967 days old) by queeny77 (BERWYN, ILLINOIS)   |   | |
Post# 683784 , Reply# 1   6/13/2013 at 15:34 (3,967 days old) by geoff (Cape Coral, FL)   |   | |
Post# 683788 , Reply# 2   6/13/2013 at 16:11 (3,967 days old) by Kenmoreguy89 (Valenza Piemonte, Italy- Soon to be US immigrant.)   |   | |
Post# 683806 , Reply# 3   6/13/2013 at 19:14 (3,967 days old) by bendixmark (Winchester Mass)   |   | |
I here a noisey stem and seal,very common in that vintage. |
Post# 683813 , Reply# 4   6/13/2013 at 20:25 (3,966 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
It could be one of many things, a bad top spin bearing, a loose suspension support bolt where it attaches to the outer tub [ this will usually result in a leak also ], could be a damper pad that has come loose and be sure to look at the main drive belt carefully just a small bad spot can sometimes make a similar noise. If the washer is working fine otherwise and not leaking there is no problem continuing using it till the problem becomes more apparent.
John. |
Post# 683825 , Reply# 5   6/13/2013 at 23:12 (3,966 days old) by queeny77 (BERWYN, ILLINOIS)   |   | |
Post# 683829 , Reply# 6   6/14/2013 at 00:06 (3,966 days old) by DigAPony ()   |   | |
Seems slow getting up to speed on the spin as well. |
