Thread Number: 47057
Fridgemore Final Spin Issues |
Post# 684456 , Reply# 1   6/18/2013 at 14:44 (3,961 days old) by Frigilux (The Minnesota Prairie)   |   | |
Calling John (combo 52)! Any ideas of how to help this guy out?
Hang in there, Greg; hopefully someone around here can offer advice. I had the 2002 Frigidaire version of your washer and the bearings finally started to make noise so I replaced it with one of the new 2010 Frigidaires---which I like a lot. |
Post# 684583 , Reply# 2   6/19/2013 at 10:19 (3,961 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
The problem is likely the stiffness in the bearings, the board can sense the extra load and think that there is a suds-lock or other problem and slow down. You should take the belt off and the tub should turn with almost no effort and coast for a while when you give it a good spin. Unfortunately it sounds like you may have to tear it down again, you can get the bearings and seals separately, however if you bought new parts they will replace the parts at no charge for 90 days. |
