Thread Number: 4725
A606S |
Post# 105331   1/23/2006 at 22:24 (6,666 days old) by sudsmaster (SF Bay Area, California)   |   | |
Post# 105334 , Reply# 1   1/23/2006 at 22:31 (6,666 days old) by sudsmaster (SF Bay Area, California)   |   | |
This one has no trace of grease or oil in the bottom, but there is some sign of slight water leakage through one of the tub support bolts. You can also see a damper pad peeking out from under the damper. I wonder if I can release the springs, lift the tub, slide the pad back in place, maybe glue it down, and give it a coat of silicone grease... You can see there is an old-style water pump, complete with complementary dessicated spider ;-). The hose leads to the back where the suds saver diverter valve resides. A closeup of this diverter valve from the back will follow. |
Post# 105335 , Reply# 2   1/23/2006 at 22:32 (6,666 days old) by swestoyz (Cedar Falls, IA)   |   | |
Post# 105336 , Reply# 3   1/23/2006 at 22:33 (6,666 days old) by swestoyz (Cedar Falls, IA)   |   | |
Post# 105337 , Reply# 4   1/23/2006 at 22:34 (6,666 days old) by sudsmaster (SF Bay Area, California)   |   | |
Post# 105340 , Reply# 5   1/23/2006 at 22:37 (6,666 days old) by frigilux (The Minnesota Prairie)   |   | |
Post# 105343 , Reply# 6   1/23/2006 at 22:48 (6,666 days old) by sudsmaster (SF Bay Area, California)   |   | |
Here's a shot of the diverter valve from the back of the machine. Note the two drain hoses. I don't think they are original - they are cheesy poly plastic, with modern wormdrive clamps. I will be looking for more original hoses. I'm assuming that when the button is pushed for "Save Suds" and the dial is set to "Suds Return", then the other hose is opened up and sucks the suds back into the washer. I think!
Post# 105344 , Reply# 7   1/23/2006 at 22:51 (6,666 days old) by sudsmaster (SF Bay Area, California)   |   | |
Post# 105345 , Reply# 8   1/23/2006 at 22:58 (6,666 days old) by sudsmaster (SF Bay Area, California)   |   | |
Post# 105346 , Reply# 9   1/23/2006 at 23:03 (6,666 days old) by sudsmaster (SF Bay Area, California)   |   | |
Ben, This is another '67 machine (S/N suffix DK). The belt area of the machine is squeaky clean - no sign of oil or grease. As you can see from the photos, the outside of the machine isn't in as good shape as the other A606; plus the tub shows signs of abrasion (but no rust or chipping). I'm going to have to get a laundry tub (preferably a dual tub) to really get the most from this machine, but meanwhile I'm planning on hooking it up outdoors for testing with a plastic barrel for saving/sucking suds. |
Post# 105414 , Reply# 10   1/24/2006 at 15:35 (6,666 days old) by polkanut (Wausau, WI )   |   | |
Post# 105417 , Reply# 11   1/24/2006 at 16:05 (6,665 days old) by goatfarmer (South Bend, home of Champions)   |   | |
Post# 105419 , Reply# 12   1/24/2006 at 16:13 (6,665 days old) by bobbyderegis (Boston)   |   | |
Hey Suds! Looks like you're hooked! Told Ya. Bobby in Boston |
Post# 105429 , Reply# 13   1/24/2006 at 16:47 (6,665 days old) by swestoyz (Cedar Falls, IA)   |   | |
Rich, Nice score, looks like she should clean up pretty easy. This unit appears to be a May of '67 machine. Does it have the same lint filter and agitator as your non Suds machine? These machines are like pups - always following you home! Ben BTW - working on bringing home another Suds machine myself... more details to come! This one is a dream machine. |
Post# 105456 , Reply# 14   1/24/2006 at 19:59 (6,665 days old) by sudsmaster (SF Bay Area, California)   |   | |
ben, Yep, the machine is pretty much identical to the other A606, except for the original pump and the suds saver valving and controls. Same agitator, same lint filter. Let me guess, you found an 806S? I'm keeping my eyes peeled for a 806; needn't be a suds saver though. Interestingly, here's what Doug Emley has to say about suds saver washers (not that I agree with him - at this point I have no opinion on the matter): "A few old machines were built with so-called "suds saver" features. They are characterized by having TWO drain hoses. On is supposed to lead to an external "suds" tank (usually a laundry tub-sing) where the wash water from a first load can be re-used for a second load. There is a suds diverter valve in the washer, and sometimes a suds return pump separate from the main washer pump." "If you have one of these washers (not likely; they're pretty rare) do yourself a favor and disonnect the suds pump and/or diverter valve. Route all pump disharge out theough the drain." "Or else get a gun and shoot the boomin' thing. They're just about impossible to get parts for." Of course, this is from the same guy who claims that Maytags have clutches built into their transmissions. |
Post# 105467 , Reply# 15   1/24/2006 at 20:38 (6,665 days old) by frigilux (The Minnesota Prairie)   |   | |
More ideas for suds-saver container: At one point, I had a 1959 Kenmore washer with suds-saver. Not having a sink in my small laundry space, I bought a big, heavy duty garbage can (the kind you drag to the curb, not the light-duty type you'd have in your kitchen) and it worked perfectly. It was rectangular and fit right between the washer and the wall. At the end of wash day, I'd pull it out and empty the inch of water at the bottom of the can into the kitchen sink or the bathtub.
Post# 106030 , Reply# 16   1/26/2006 at 21:21 (6,663 days old) by sudsmaster (SF Bay Area, California)   |   | |
Post# 107534 , Reply# 17   2/3/2006 at 08:37 (6,656 days old) by polkanut (Wausau, WI )   |   | |
When my wife and I purchased our home in '98 the washer and dryer were included. The old laundry sink had been changed out for a suds tub. The washer was a suds-saver. The suds tub was made by the W.P. Johnson Co. of Des Moines IA. When we remodeled we moved the washer and dryer upstairs and the tub came with, and works GREAT!
Post# 107630 , Reply# 18   2/3/2006 at 19:02 (6,655 days old) by sudsmaster (SF Bay Area, California)   |   | |
Post# 107696 , Reply# 19   2/3/2006 at 22:00 (6,655 days old) by bpetersxx (laf in on the banks of the Wabash River)   |   | |
this is a special suds saver tub Sears sold them for years suds water drained into the tub thru one hose hookup and the rinse water drained thru another hose hookup to the tub correct me if wrong but is this tub missing the pipe that diverts the rinse water to the drain in the tub dalangdon posted this and I saved the post |
Post# 107714 , Reply# 20   2/3/2006 at 23:27 (6,655 days old) by sudsmaster (SF Bay Area, California)   |   | |
Post# 107716 , Reply# 21   2/3/2006 at 23:49 (6,655 days old) by launderess (Quiet Please, There´s a Lady on Stage)   |   | |
Post# 107847 , Reply# 22   2/4/2006 at 19:52 (6,654 days old) by bpetersxx (laf in on the banks of the Wabash River)   |   | |
Post# 108310 , Reply# 23   2/7/2006 at 07:47 (6,652 days old) by polkanut (Wausau, WI )   |   | |
