Thread Number: 47260
My $50.00 Maytag |
Post# 686554   6/30/2013 at 21:36 (3,951 days old) by sambootoo (Moody, AL)   |   | |
Found on Craigslist. Very good condition without rust, dirt, dings. Runs smooth and quiet without leaks. Model #LAT9824AAE Ser. # A0102281 KB When was this one made? |
Post# 686555 , Reply# 1   6/30/2013 at 21:38 (3,951 days old) by sambootoo (Moody, AL)   |   | |
Money shot. I added the dual action agitator |
Post# 686557 , Reply# 2   6/30/2013 at 21:41 (3,951 days old) by sambootoo (Moody, AL)   |   | |
Does this one have the old reliable center seal or the newer likely to leak one? |
Post# 686558 , Reply# 3   6/30/2013 at 21:43 (3,951 days old) by norgechef (Saint George New Brunswick )   |   | |
January of 1994 |
Post# 686575 , Reply# 4   6/30/2013 at 23:22 (3,951 days old) by appnut (TX)   |   | |
Post# 686583 , Reply# 5   6/30/2013 at 23:51 (3,951 days old) by beekeyknee (Columbia, MO)   |   | |
Well, if you had the agitator off you should have been able to see the seal at that time. It would most likely have the newer integrated rubber lip seal built into the mounting stem instead of the older kind with the insertable drive shaft seal, washer and spring retainer. Take off the agitator and look again.
Post# 686616 , Reply# 6   7/1/2013 at 08:08 (3,950 days old) by sambootoo (Moody, AL)   |   | |
Thanks, will do. Thanks for the dates, too! |
Post# 686690 , Reply# 7   7/1/2013 at 15:51 (3,950 days old) by joefuss1984 (Little Rock, AR)   |   | |
I have the LAT8814? I think, my memory fails me now. Mine is the same control panel design with infinite water level, 4 wash/rinse temps, and tho it has the 2 speed motor does not have the speed selector or the load sensor agitator. I really like the performance of mine. It does need a new brake tho.
Post# 778960 , Reply# 8   8/23/2014 at 22:20 (3,532 days old) by sambootoo (Moody, AL)   |   | |
UPDATE: Now that I've found the matching dryer, my washer has poured it's oil onto the floor. I have a transmission that I can transplant, but would it be more advisable to just replace the oil seal in this one? |
