Thread Number: 47345
Holy boot Batman! |
Post# 687627   7/6/2013 at 15:19 (3,940 days old) by CleanteamofNY ((Monroe, New York)   |   | |
You got s hole at a very young age! Today was a day to order new parts for my Electrolux washer from 2009 (EWFLW65IRRO). Also my refrigerator water dispenser stopped working and I brought a multi-meter to find out if the water solenoid was defected and it is and I thought it maybe the computer board went bad. Lucky me! 134616100 DOOR BOOT ($81.85) WR57X10032 WATER VALVE ($52.00) WR02X11705 BYPASS PLUG ($16.71) Item total $150.56 Shipping $15.99 Sales tax $13.53 Order total $180.08 |
Post# 687840 , Reply# 1   7/7/2013 at 15:43 (3,939 days old) by frontloaderfan (Merrimac valley, MA)   |   | |
Post# 687843 , Reply# 2   7/7/2013 at 16:28 (3,939 days old) by Yogitunes (New Jersey)   |   | |
Post# 687847 , Reply# 3   7/7/2013 at 17:02 (3,939 days old) by CleanteamofNY ((Monroe, New York)   |   | |
Post# 687862 , Reply# 4   7/7/2013 at 20:29 (3,939 days old) by Yogitunes (New Jersey)   |   | |
oh it can happen from rubbing, back and forth, in and out, constantly over and over, never having a rest break at the same spot from simple friction....anywho
now, about your door boot...also check to make sure something inside the outter cabinet area is not rubbing against it...once fixed, you don't want it to happen again.... try repairing it...or just slip on a new one, being careful in the future of not to let your clothing drag against it while pushing them in and pulling out with too much force.......and toss that old one in the trash....these things can be delicate....and yet others can take a licking with never having a problem.... |
Post# 687919 , Reply# 5   7/8/2013 at 07:36 (3,938 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Many DBs fail from the friction of the back or outside of the DB rubbing against itself. SQ had quite a problem with DBs doing this on their Big Door FL washers, now when we replace them SQ has us apply a special silicone grease to the OUTSIDE of the DB in areas where this friction can occur. This seems to have solved the problem on SQs. |
Post# 688114 , Reply# 6   7/8/2013 at 21:49 (3,937 days old) by laundromat (Hilo, Hawaii)   |   | |
My newer Duet washer's boot leaks at the center base where it frayed.It was abused prior to my ownership but started after a few loads were washed. I had to replace it with a new one. My second Duet,an older one,is dry rotting.I looked at it earlier today and noticed it's torn in multiple areas.I leave it ajar to eliminate any mildew but never saw this happen.
Post# 688204 , Reply# 7   7/9/2013 at 11:57 (3,937 days old) by mark_wpduet (Lexington KY)   |   | |
Post# 688457 , Reply# 8   7/10/2013 at 12:43 (3,936 days old) by CleanteamofNY ((Monroe, New York)   |   | |
I can't see how the boot got poked but all I can say, WHY ME? LOL BTW, parts for the fridge arrived, installed and what...... NO Water..... Why? Because of frozen water line! My hair dryer is on the job in Manhattan and I used a drop light with a 100 watt bulb right in the door area leaning 1/2 inch away from the plastic bezel and heard the ice break free and whoosh we got water flowing again! Now I wonder should I get a refund for a used water valve??? |
