Thread Number: 47459
Maytag A606 Rinse Cycle stalls! |
Post# 689182 , Reply# 1   7/13/2013 at 19:02 (3,932 days old) by Yogitunes (New Jersey)   |   | |
water trickling in......is this only during "rinse"? as in cold water side only?....or during wash fill too, at warm or hot setting?
did you pull the hoses off and place them in a bucket and turn the water on?... or put a bucket directly under the faucet and turned completely on? is there good water pressure from those two sources? you said you checked the valves, meaning you cleaned out the screens? your next idea would to also check the hoses leading from the valve to the splash shield inlet! let's get to the source of the "trickle" and not full force! |
Post# 689244 , Reply# 2   7/14/2013 at 02:24 (3,932 days old) by arbilab (Ft Worth TX (Ridglea))   |   | |
Post# 689415 , Reply# 3   7/14/2013 at 19:46 (3,931 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
