Thread Number: 47470
Look What I Bought Home! |
Post# 689267   7/14/2013 at 06:18 (3,936 days old) by ian_p61 (Melbourne Australia)   |   | |
Last night when i was trolling through ebay i found a miele set i have wanted for a little while now - the best part was it was only 30 mins away and it was only $50 for the pair with a stacking kit! yay |
Post# 689398 , Reply# 3   7/14/2013 at 19:13 (3,936 days old) by ian_p61 (Melbourne Australia)   |   | |
Bearings where do I go from there? Also the washing machine seems fine when I first start the cycle then gradually through the cycle the water pressure in the main wash part of the draw drops? Thanks All |
Post# 689443 , Reply# 4   7/14/2013 at 22:26 (3,935 days old) by ian_p61 (Melbourne Australia)   |   | |
Hi again, I have noticed that the washing machine during spin cycle is louder than I would expect but I don't think the bearing are worn? |
Post# 689481 , Reply# 5   7/15/2013 at 05:10 (3,935 days old) by RichNZ (New Zealand)   |   | |
Sometimes it is the motor bearings. I have had a w828 with tired motor bearings. Very cheap to replace also much easier than replacing the tub bearings. |
Post# 689482 , Reply# 6   7/15/2013 at 05:21 (3,935 days old) by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
Sounds like the cold water valves may need replacing, at least that was the source of the problem with our Miele.
The cold water valve is a triple thiny IIRC and if you are handy can be a DIY job, just order the part from Miele OZ. You'll need your the model number and perhaps the serial code. Water valves can also become gunked up with mineral deposits if the local water is hard. |
Post# 689483 , Reply# 7   7/15/2013 at 05:30 (3,935 days old) by ian_p61 (Melbourne Australia)   |   | |
Thanks For your help all i will check those things soon! when turning the dryer by hand it only makes a rumble sound (not the normal quiet sound ) when turning anti clockwise? |
